Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Washer
We have a Calypso washer it will not complete the wash cycle it will get to the last of the cycle and will stop and display a fault Ld which is long drain we can put it on extra spin and most of the time it will finish Sometimes the timer will get to six min. left and will not change We can start and stop machine a couple times and it will go on and make the rest of the cycle The model is GVW9959KQ
SOURCE: Whirlpool Calypso - Will not start
We just experienced the same problem with the buttons! I just kept pushing all the buttons until it switched over-delicate cycle was actually the one that got it going-what a piece of work this machine is!
Posted on Dec 17, 2007
jsrock516
  • 5911 Answers
SOURCE: Fault code C1
"C1" is known as an Instantaneous Current Limit Error. This will occur when the Motor Controller detects a current spike of 26 amps or greater at the motor windings. Overloading the washer, excessive water and/or excessive suds can cause this problem.
The manufacturer recommends the following:
- Wash smaller loads and use the correct detergent (HE only for Calypso machines). NOTE: Make sure the HE detergent is not double or triple concentrated as this will also cause suds problems.
- Check for objects under the nunate plate. This is the wash plate. Sometimes clothing can get stuck under the plate and cause the motor to bind up. To remove the nunate plate, follow these instructions:
1. UNPLUG THE WASHER.
2. Open the washer top. Look along the front seam of the washer where the top meets the front. There are a couple of retaining clips (about 2" in from each side) that you will need to push in on with a putty knife while gently lifting up on the top to get the top to release. Carefully open the top and lay it back against the wall in a resting position. Make sure you support the lid so it doesn't fall open when you tilt the top back.
3. Remove the tub ring. This is the plastic donut shaped ring that sits on top of the wash tub. There will be a tab on either side of the outer tub near the back that you can use a screwdriver to release the tub ring. The ring is filled with fluid and is used to balance the tub. So, if you hear liquid sloshing around, this is normal.
4. Remove the center cone from the wash plate. Use a flat blade screwdriver and insert it into any of the slots available along the sides. Gently pry until it pops off. I say "gently", but you may have to use a little muscle to get it to come off. Sometimes they stick. Once the center cone is removed there will be a series of nuts under it.
5. Remove the nuts and the wash plate should lift out. Be careful not to damage the gasket under it. Clothing can get tangled in the leveler under the wash plate. This leveler should have a key on it. The wash plate will only go back in with this key mating to a slot on it. So, remember how you took it off. In addition, when putting the wash plate back on, make sure you tighten the nuts in a cross pattern and evenly tighten them as you go. This will ensure the gasket seats properly. Don't forget to put the tub ring back in.
- Check for objects stuck between the inner wash tub and the outer basket. NOTE: It is best to do this with the nunate plate removed. Use a flashlight to peer through the holes in the wash basket to see if anything is catching on the tub.
- Check the Motor Controller. You will need to determine if there is power getting the the board first and that the fuse on the board is good. If any components on the board are defective, the board has to be replaced. If you have power to the board and the fuse checks good, check for continuity between the Machine Controller and Motor Controller.
There is a tech sheet inside your washer along the interior cabinet (usually the front panel) that explains all these procedures to you. I would advise you to research the tech sheet for exact locations of the pin outs for the circuit boards. Its easier for you to view it rather than me explain it. If you need further assistance, please post back and let me know. I hope this helps you.
Posted on Jul 03, 2008
SOURCE: What does ld mean on my washer?
op is probably ob, off balance, the ld is long discharge, most likely the pump is bad or full of junk, the origional pumps were updated to a better design so as not to get stopped up.
Posted on Sep 02, 2008
praky16
  • 744 Answers
SOURCE: Whirlpool Calypso: LD error message
hi replace the hall sensor... this will remove ur LD error code...
thank u
rate me!!
Posted on May 24, 2009
samson39
  • 32 Answers
SOURCE: Calypso washer - LD Code - clothes still wet
harborstuff,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. I would bet that the bath mats left a bunch of stuff stuck in the recirculation pump hose, or pump itself, and the water cannot be drained fast enough. Check the intake and exit hoses of the recirc pump. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. Hope this helps.
(Definitely get under there and check to make sure the pump hoses are not clogged. At $129 it's an expensive fix for a $10 bath mat that clogged up the hose with fuzz. 'know what I'm sayin'' :o) )
-samson39
BTW, I have the maintenance manual & have experience at replacing the recirc. pump, control board, motor board, touchpad, & lid switch so far.
Posted on Jul 24, 2009
Whirlpool Calypso Washer Mdl#30942 gets stuck during rinse cycle. Machine runs, then stops, but does not rinse completely. Last 35-38 min cycle is problematic. What is wrong and how to fix it?
It's hard to tell by your description of the problem, but it sounds like it could be the timer If it's not running while in spin mode, or as simple as a belt if it's running and not spinning fast enough.
Nov 28, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
My calypso washer does a start/stop and won't complete the cycle. no error code. does it no matter what type wash is started.
main computer board then once you get it fixed put it on a surge protector it just like your computer,part cost about 100 to 150.00
Jan 24, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
I have a Whirlpool Calypso washing machine, model
communication error. changing the MCU. sometimes a bad pump could be the problem
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer display is freaking out.. It
change the panel. buttons are shorted wool button
Feb 01, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer is not completeing "normal" was cycle
could be or you may have a problem with the lid switch ( Ld )
Aug 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Code pf came up and the washer does nothing
PF Power failure "PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost.
OR
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Apr 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Won't run
found a pf not an a fp
PF Power Failure PF flashes if the washer loses power during a running cycle. The washer does not flash PF when it is first plugged in.
Press START to continue the cycle from the moment that power was lost -OR-
Apr 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
107 people viewed this question
Dan Webster
Dan Webster
Sal De
