Question about Kenmore 44042 Front Load Washer
Our front loading Kenmore MODEL 41742042100.has begun sounding like a jet enjine when it is spinning,someone told me that it is probably bad bearings, is it worth having this 7yr old machine repaired or could it be something different.
  • Kenmore Master
  • 19,396 Answers
Hi.
I
f you get a very loud noise coming from the machine, and this noise islouder when it spins faster, then it is often because of a problem with the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
You can find parts and diagrams for most models here.
Posted on Nov 13, 2009
Washer has begun to sound like a four wheel drive vehicle going down the highway at 60 mph. The matching dryer had been squeaking and now has begun a thumping sound.
if it sounds like a jet plane taking off its the drum bearings and you need to replace these bearings,if your lucky you can find just the bearings and lip-seal,if not you will need to but the tub with the front bearing installed already and this gets expensive,otherwise to just replace these bearings and seal alone its about $500.00 to $900.00do it soon as the longer you wait the more labor intensive it gets
Aug 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a kenmore front load washer model 970-c42072. I'm experiencing a loud noise in the drum on the spin cycle even when it is empty no matter what setting (slow normal fast) What would be the...
If you turn the inner wash drum by hand, what kind of noise do you hear? If it is a thumping kind of noise, it would mean that the spider support arms are broken. If the noise is a loud rumbling sound, similar to a jet engine when it is spinning, it would mean that you have a bearing seal failure and the bearings need to be replaced. Either problem is a big job to fix since the entire washer needs to be taken apart. Get a few estimates before deciding whether it is worth fixing. Sorry.
Sep 01, 2010 | Kenmore 44072 Front Load Washer
Kenmore front load washer when spinning sounds like a jet engine. It actually hurts you ears and you cannot shout loud enough to be heard. Spins out fine but is so loud.
It's probally the bearings are going bad. If you try to turn the drum by hand and it does not turn smoothly or has a rumbling sound, it means the bearings are bad. I had the same thing happen to my washer. Water seeped past the seal and the water started to rust out the inner bearing. You need to pull the washer apart to get to the bearings if you are handy. If not, the parts and labor are more than the price of a new machine.
Nov 19, 2009 | Kenmore 44102 Front Load Washer
Kenmore washer 3.5 super capacity. Machine spins
It sounds like your tub bearing is bad or going bad. It could be the adjustment on your spin cycle. Does your unit allow you to adjust this. Also are you overloading. Can you send me the brand and model of your unit and I help you more.
JimmyC
Oct 05, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Buzzing/Ratcheting sound while drying
Hi, Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 19, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore 41742042100 front load washer
IT IN THE SAME PLACE AS THE FRIGIDAIRE YOU HAVE TO TAKE THE FRONT LOWER PANEL OFF
Jan 02, 2008 | LG WM2688H Front Load Washer
Kenmore Elite Heavy Duty Washer
Whirlpool is still made in USA, I think. Avoid electronic timers and geegaws you don't need.
Dec 22, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore washer 41742042100
the filter maybe blocked! or something caught in the pump or hose's going to it!
Dec 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Kenmore 44042 Front Load Washer Logo
669 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
