Question about Odyssey Steel 2 Ball Srt Putter
I am trying to remove the shaft from an Odyssey 2-ball putter and can't get it off. I have used a heat gun and a tourch to no avail. It appears to be an "over the hosel" attachment but none the less the shaft will lnot come off.
Rosemary, I found a broken Ping putter in the trash can and took it to a golf repair place and they put a new shaft in for not too much money and it was a great putter for many years before I needed a belly putter to help me keep the putter more steady.
Posted on Dec 17, 2009
Husqvarna chainsaw replacing crank shaft bearings.
you may have to use a puller, you may be able to chill the assembly in a freezer then quckly heat the bearing with a tourch
Oct 12, 2014 | Garden
2k 13 cheat codes on xbox 360
    +3 Ball Handling Enter "spriteeffect" as a code to get +3 Ball Handling for your player in MyCAREER mode. 2013 All-Star uniforms Enter "mwpzoslqov" as a code to unlock the 2013 All-Star uniforms. Christmas uniforms Enter "mnspxuwmdy" as a code to unlock the Christmas uniforms. Heat White Hot uniform Enter "kqpxmzodqb" as a code to unlock the Heat White Hot uniform. Secondary road uniforms Enter "ypzbnwolaw" as a code to unlock the secondary road uniforms. Under Armour Tourch shoe Enter "underarmour" as a code to unlock the Under Armour Tourch shoe. ABA ball Enter "payrespect" as a code to unlock the ABA ball.
    At the main menu, select the "Features" option, choose the "Codes" selection, then enter one of the following codes
Sep 04, 2014 | Video Game Consoles & Games
Cheat codes for nba2k13
At the main menu, select the "Features" option, choose the "Codes" selection, then enter one of the following codes to activate the corresponding cheat function:
    +3 Ball HandlingEnter "spriteeffect" as a code to get +3 Ball Handling for your player in MyCAREER mode. 2013 All-Star uniformsEnter "mwpzoslqov" as a code to unlock the 2013 All-Star uniforms. Christmas uniformsEnter "mnspxuwmdy" as a code to unlock the Christmas uniforms. Heat White Hot uniformEnter "kqpxmzodqb" as a code to unlock the Heat White Hot uniform. Secondary road uniformsEnter "ypzbnwolaw" as a code to unlock the secondary road uniforms. Under Armour Tourch shoeEnter "underarmour" as a code to unlock the Under Armour Tourch shoe. ABA ballEnter "payrespect" as a code to unlock the ABA ball.
Jan 29, 2014 | Microsoft Xbox 360 Console
Have anyone out there ever change inner tie rods on a1995 honda odyssey?,if so simply explain,THANKS
Procedure on replacing the inner tie rod ends:
1) Raise and safely support the vehicle.
2) Remove the front wheel/tire assembly.
3) Clean the steering rod between the steering boot and outer tie rod end lock nut with a suitable penetrating lubricant and a clean cloth or shop towel.
4) Loosen the outer tie rod end locking nut 1/8 turn.
5) Loosen the steering boot clamp(s), and slide the small clamp off the boot.
6) Carefully loosen the boot and slide outward off the steering rack and onto the shaft to expose the inner steering rod mounting fastener.
7) If necessary, position the inner steering rack shaft in or out to allow for additional access.
8) Relieve the steering rod nut locking tab from the inner steering rack shaft, then loosen the steering rod ball socket nut 1 turn.
9) Matchmark the tie rod end to the threaded shaft.
10) Remove the cotter key and castle nut from the outer tie rod end threaded spindle, and using a tie rod end removal tool, remove the tie rod from the steering knuckle.
11) Hold the tie rod with a wrench, and remove the outer tie rod end from the threaded rod, counting the number of complete turns it takes to remove the tie rod end from the shaft. Write the number of turns on a piece of note paper.
12) Remove the tie rod end lock nut from the threaded steering shaft.
13) Slide the steering rack boot off the shaft.
14) Remove the inner steering rod ball socket nut from the inner steering rack shaft.
To install:
1) Inspect the tie rod end for looseness, and the steering rack boot and tie rod end boot for cracks deterioration or damage and replace as necessary.
2) Clean steering rack shaft and apply a light coating of Genuine Honda Power steering fluid as necessary.
3) Apply a medium strength locking agent to the threads where the inner steering rod ball socket mounts. Use a new locking washer and a new stop washer, and install the inner tie rod onto the steering rack shaft.
4) Tighten the inner tie rod end fastener by 58 ft. lbs. (78 Nm)
5) Peen the lock washer over the nut or onto the flat surface of the steering rack shaft.
6) Apply silicone grease to the outer circumference of the inner tie rod end ball socket, and onto the groove just outside of the socket.
7) Apply silicone grease to the inside of the small end of the steering rack boot, and slide the boot over the steering shaft and onto the rack and install the boot clamps. If the boot has air hose fittings make sure they are installed as removed.
8) Apply a light film of an anti-seize compound onto the threaded tie rod end, and install the tie rod end lock nut.
9) Install the tie rod end onto the tie rod, turning it in exactly the number of turns it took to remove it.
10) Install the tie rod end following the tie rod end installation procedure.
11) The balance of installation is the reverse of the removal procedure.
12) Check the front end alignment and adjust as necessary.
Sep 10, 2012 | 1995 Honda Odyssey
Fixing a worn-down putter face
most golf stores can replace the face plate for about $25 but you can buy the part and do it yourself part $7 and a bottle of contact cement $3
Sep 04, 2012 | Odyssey Steel 2 Ball Srt Putter
I've lost one of the "balls" on a two ball putter and would like to find a replacement ... do you know where I can get one?
I would suggest you go to your local vinyl sign maker get him to cut a new pre stick disc and stick it on
Dec 27, 2010 | Odyssey Steel 2 Ball Srt Putter
Where can i get replacement white disc's for my 2
where can i get replacement white disc for odyssey 2 ball putter?
Dec 14, 2009 | Odyssey Steel 2 Ball Srt Putter
Drivers seat is tilting back and forth, a bar underneth is broken
it can be a spring that came loose from its spot under the seat look to where it should be or the seat could be back to far and it depends on how old it is if it has just broke down make sure nothing it in the way and the lever id not stuck hope this was helpful:)
Nov 16, 2009 | Odyssey Steel 2 Ball Srt Putter
Dodge ram 99 4wd cv bolt cant remove
A lot of heat (glowing if possible), and heavy air impact. I've never been able to break one without air impact, and sometimes have had to use a lot of heat as well.
Jun 03, 2009 | 1999 Dodge Ram
Odyssey Steel 2 Ball Srt Putter Logo
290 people viewed this question
Top Odyssey Sport & Outdoor - Others Experts
Are you an Odyssey Sport and Outdoor - Other Expert? Answer questions, earn points and help others
