Question about Maytag Dryers
Grinding grumbling sound upon start up , continuing at a quieter sound during the cycle, loud and grumbly during shut down
  • Maytag Master
  • 19,396 Answers
Hi.
f you get a very loud noise coming from the machine, and this noiseislouder when it spins faster, then it is often because of a problemwith the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
You can find parts and diagrams for most models here.
Posted on Nov 13, 2009
2004 Chrysler pacifica, 3.5 How to Tell if your Alternator Bearings have failed or bad harmonic balancer making a loud noise that gets loud upon acceleration.
with the alternator use a long handled screw driver and place the end on the case of the alternator and cup the handle over an ear
grumbling sounds are bearings
for harmonic balancer check the rubber in the balancer and if it is shiny replace the balancer.
Mar 13, 2015 | 2004 Chrysler Pacifica
Grumbling Noise on Spin Cycle
If there is any form of grinding at all when the drum is turned than the rear bearings in the machine is going bad. This will only progress an get worse, then eventually start leaking and grinding and finally lock up.
Apr 26, 2012 | Bosch Washing Machines
2006 chevy cobalt transaxle noise , i blocked car up remove both front wheels started engine, engaged transmission to drive, listened to noise sounded a bit like a grumbling/grinding noise., no fluid leaks...
WORN FRONT BRAKE PADS WILL MAKE GRINDING NOISE IF PAD WORN DOWN TO RIVETS RUBBING AGAINST BRAKE ROTOR WILL MAKE GRINDING NOISE, IF BRAKE PADS OKAY WORN DAMAGE DRIVE SPROCKET SUPPORT BEARING .
Oct 25, 2011 | 2006 Chevrolet Cobalt
When the washer goes into the spin cycle it sounds like a loud grumbling noise when it at top speed and getting worse almost with every wash.
It sounds like your bearings are going out, they should be replaced and probably by a professional unless you really feel like taking the job on.
Jun 08, 2011 | LG Washing Machines
Just had a new 3.5 Ton Goodman GSZ13-13 SEER, heatpump installed. Its working OK in Cooling, however whe switched over to heating mode the indor unit makes a loud grumbling sound. The installer stated that...
I install them every day and I have not had one make a loud grumbling sound. Sounds like you might have a low voltage (Thermostat) wiring problem. The only thing different inside the indoors unit from heat and cool is the fan speed, electric heat when on. The fan might be loose or out of balance and it only shows up at low speeds. Either way, the noise is not normal.
Oct 13, 2009 | Goodman CLQ36AR49 Air Conditioner
Compressor makes a loud grumble an vibrates when it shuts off
There are springs inside the compressor that suspend the motor. When one or more of those springs break then the motor will knock against the casing when it shuts down and loses centrifuge motion. The compressor will continue to run up until the point the it beats itself to death, which could be next week of next year. There's no way to tell. The only solution is to replace the compressor.
Oct 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Dryers Logo
112 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
