Question about Craftsman Motorcycle/ATV Jack
Need a craftsman manual for 875.50190 jack - Craftsman Motorcycle/ATV Jack
Owner's manual for craftsman YT4000 model 917.288561
Bob, Check the attached links, Craftsman Riding Mowers instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://lawnandgarden.manualsonline.com/manuals/mfg/craftsman/yt_4000.html
Craftsman 28925 YT 4000 24 HP 42 Yard Tractor Manual
Apr 05, 2016 | Craftsman Garden
Need free owners manual for a 6 speed craftsman Lt 20000 17.5 HP riding mower
You normally download the Craftsman manuals @
http://www.searspartsdirect.com/
You will the model number from the serial number decal under the seat area. This number usually starts with 917.
Aug 05, 2014 | Craftsman Garden
Craftsman motorcycle jack model KT2002050642 - I
There should be some notches either in the top rails or the bottom. If I remember right they were on the bottom. Looks like peices of small round rod welded. Maybe 3 or 4.
Look for the locker arm and see where you need to lift them up from. You will have to have the jack raised enough to loosen teh arms to make them come away from the welded peices.
Aug 11, 2010 | Craftsman Original Sears Craftsman...
I'd call them and give them the product number and see if they can mail you a manual.
Oct 06, 2009 | 1979 Harley Davidson XLS 1000
Floor jack won't stay
If you are having a problem with the jack slipping...if its Craftsman , they may take it back and provide a replacement. Even if you could fix it, it never works that same. It is not worth your life. I know, I lost my husband when a jack slipped 3 years ago this month.
Jun 01, 2009 | Hand Tools
Craftsman 3 ton floor jack will not stay up
you need to bleed the air from the cylinder. there should be an air bleed or else you bleed it at the relief needle. also, if it still leaks down after you bleeed out the air, the seat for the relief valve or the seals at the relief valve cartridge are worn
Apr 01, 2009 | Home Fencing
Craftsman Motorcycle/ATV Jack Logo
195 people viewed this question
Top Craftsman Hoisting Experts
Andrew Taylor
Andrew Taylor
Jerry Kramer
Jerry Kramer
Are you a Craftsman Hoisting Expert? Answer questions, earn points and help others
