Question about Dishwashers
My KitchenAid dishwasher model KUDS01LBS5 stopped working. no lights on, wont respond to start button or cancel. Water was left in the tub from last successful wash. breaker panel looks ok. Any ideas?
  • 4 more comments
  • deepak226 Nov 14, 2009
    • Dishwasher is receiving 125v where mains is connected to dishwasher in small metal box behind kick panel. Everything underneath looks clean -- except what might be a few mouse droppings are present
    • Door path and seal looks good.
    • Door closes and latches nicely. Nothing looks like it is jamming door.
    • Tried holding 'energy-saver-dry' button down for 4-5 seconds to reset... no result. pressed each button - they all seem to click properly when depressed except 'delay-hours' button which does not click when pressed.
    Next test?
    no. The panel has nothing lit up at all.
    I have no problem with using the ohm meter... To take the door apart, I presume I undo the screws on the inside of the dishwasher door.... do you have any advice for doing that?
  • deepak226 Nov 15, 2009
    It looks like the No2 fuse does not have continuity through it. I'll buy one tomorrow and let you know if that fixes issue.
    best regards
    Deepak
  • deepak226 Nov 17, 2009
    Success! All went well and dishwasher is working properly. Thank you, and I accept the solution.
    One recommendation... I think I could have accessed the fuse (and electronic board etc) without having
    to remove the stainless panels (front and rear)-- the door has 6 screws on the left and right stainless back
    and a pair of screws at the top on either side of the door opener, plus a pair of screws on the left and
    right sides securing the door to the hinges.
    I am pretty sure that I could have released the control panel by just removing the top pair of screws on
    the inside back left and right, and the pair of screws adjacent to the handle at the top. I think that would
    have released the control panel. I am not absolutely sure as I had taken all of the screws off....
    It went back together without any issues.
    You saved me a couple of hundred dollars...
    Much appreciated!
    I'll be back when some other appliance needs attention. Your instructions were clear, making it possible to do the repair myself. You saved me a couple of hundred dollars by avoiding a service call by a repair service. Thanks.
  • 350 Answers
First thing to always do on a dead dishwasher complaint is to verify that power is available at the power junction box in the dishwasher. Remove the kickplates (at bottom of dishwasher), then open the junction box cover and, see if the wire connections are still connected with wire nuts. If they are intact carefully (pull the wires out of the box) and unscrew the wire nuts, then test to make sure you have power to the connection between the house circuit and the dishwasher wires. If the wires are burnt when you open the box behind the kickplate, it is because loose electrical connections generate heat– these wire nuts were probably not installed correctly and loosened enough over time to cause the connection to burn. Because the circuit breaker didn't trip, the connections were contained by a grounded metal box, so there was little fire danger.If you have power to the dishwasher and the connections are good, screw the wire nuts back on and test the dishwasher again to see if there is power. This is the first step to check to make sure that you have power to the dishwasher and that the connections are done properly and secure. Next make sure there are no obstructions in the doors path/seal or locking mechanism and that nothing fell into the bottom of the dishwasher creating a jamb that could cause a malfunction. I hope this helps and good luck!
Posted on Nov 13, 2009
  • 6 more comments
  • CURT
    CURT Nov 14, 2009
    Do you have any indication of power to the touch panel?
  • CURT
    CURT Nov 14, 2009
    Here are a few more things to check. Obviously since you checked the voltage with a volt meter, I think I'm safe in assuming that you should have no problems with an Ohm meter. I hope this helps and good luck.
    Check #1 Bad Door Latch Switches
    These cause more problems than any other single
    component on this dishwasher. To check 'em, first cut the circuit
    breaker to the dishwasher 'cause the wires that attach to the switches
    are hot and if you touch 'em, they'll shock you. Anyway, you'll have to take the door apart to the get to 'em. When you pull out the whole door latch assembly.
    Now, if one of these door switches are bad, you'll usually be able to
    see a burnt wire and one of the switches will be obvious because
    it won't click when actuated. 'Course, it's always a good idea to
    verify with your ohm meter. If one of the switches are fried, don't just change
    the bad switch. Save yourself some trouble down the road (and avoid an
    unpleasant dishwasher fire) by changing both switches and the wire
    harness.
    Check #2 Blown Thermal Fuse
    The thermal fuse is located in the control panel, You can check it with a simple continuity test (ohm meter). Or you can jumper it out to see if the dishwasher will start running normally.
    Check #3 Blown or Oversensitive Electronic Control Board
    Control
    board problems can stem from **** and noise in the dishwasher's
    electrical supply which make the electronics on the control board go
    flakey. . Or, it could just be a bad control board, plain n' simple.
  • CURT
    CURT Nov 14, 2009
    Sorry here is #2 Thermal fuse
  • CURT
    CURT Nov 14, 2009
    I figured you wouldn't have a problem with the Ohm meter. But to take the door apart take the screws out from the inside (check bottom edge and sides of door as well). It's pretty straight forward.
  • CURT
    CURT Nov 14, 2009
    here's another
  • CURT
    CURT Nov 16, 2009
    Very good. I hope that is the fix to your problem, and thanks for the update.
  • CURT
    CURT Nov 17, 2009
    Deepak,
    I'm glad it all worked out for you and thank you for the kind works.
    Hawk...
  • CURT
    CURT Nov 17, 2009
    I mean words not works.
Kitchenaid dishwasher kuds30ixssa has pump running but have no lights on control panel with door closed.
Did you have a power outage recently? They are notorious for damaging circuit boards--usually about 3-4 weeks after the power interruption strange things will either start happening or *not* happening with appliances due to damaged computer chips on the boards starting to fail. Your symptoms indicate either a blown user interface(push button panel) or a defective main control board(board with the brains on it) or both!
Aug 11, 2015 | KitchenAid Dishwashers
Control panel will not light up, the dishwasher was running and now it has stopped mid cycle and will not do anything. I just replaced the control panel (black plastic with buttons, not control...
I have a kitchenaid dishwasher model # KUDC10FXBL1 I went to start it and none of the buttons were working. I have checked the breaker and the wiring and everything seems to be in order.
Jan 13, 2011 | KitchenAid 34 in. KUDP01FLSS Stainless...
Kitchenaid normal cycle light and cancel light both blinking. Dishwasher wont start
Thanks for writing to Fixya.com.
Please do the following to reset the washer. Normally the clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again
Thanks for contacting Fixya and please accept the solution if it has helped you.
May 28, 2010 | KitchenAid 24 in. KUDI01DL - Multiple...
KUDS01FLSS0 Dishwasher - tub slwoly filling with
Slow fill of water is due to the strainer clogging. Strainer is located on the body of the machine where the inlet water hose is connected.
Clean all the water flow tubes in the machine.Clean the solenoid valve opening also.
May 26, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
Kitchen Aid dishwasher will not start
Can not start KitchenAid dishwasher..."child lock" light keeps coming on. Help!
Aug 24, 2009 | KitchenAid Dishwashers
Cancel Light Flashing on Kitchen Aid Dishwasher
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Sep 21, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid Normal light stays on
check to see if its a draining problem,blockage under the sink etc ive not worked on this brand before.hope this helps.Ian
Mar 19, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Diswasher won't start
Try holding the reset button in for about ten seconds.
Nov 26, 2007 | KitchenAid 24 in. KUDP01IL - Multiple...
Clean Light Flashes
Oct 07, 2006 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
90 people viewed this question
Top Dishwashers Experts
Owen Barnes
