Question about Linksys Wireless-G Broadband Router
Wont connect with my computer says cant get ip address
  • 2,260 Answers
Are you trying to connect the computer to the wireless network ?
first check the wireless settings of the router and then connect to the network.
For this you will need to open the set up page of the router .
Click Here to know more
Posted on Nov 14, 2009
  • 131 Answers
Setup dhcp pool for 10 or so adresses or go to "attached" devices and setup each to be static. you have to change your comp. adapter to the same type ip range , i.e. if router is 192.168.0.1, set your card manually to 192.168.0.5 to configure then after setup setup pc to auto for tcpip auto and give it a go .
2 Suggested Answers
LASITHA-VEGA
  • 428 Answers
SOURCE: i had to assign my router a new IP address and
That is easy. You have to change the Default Gateway. Make sure you are running DHCP in the Router as well. Otherwise you may have to change the IP Address of the Computer to suite the New IP Address and its Subnet.
  1. You have to go to "Network Connections" in the Control panel.
  2. Go to the Wireless Adapter Section and Choose the Local Connection.
  3. Right Click on Properties and the Double Click on Internet Protocol (TCP/IP).
  4. If you are using a "Static IP Address", Please change the IP Address of your Machine to suite the IP Address and Change the Default Gateway to the New Address (And then the DNS Server Address as well, if you are running DNS from your Router).
  5. If you are running DHCP (You will see that the boxes are Blank and "Obtain IP Address Automatically" and "Obtain DNS Address Automatically" selected) this cannot happen. Then you have to check your Router's DNS Settings for the Internal Network. Make Suitable Changes.
  6. If you have tried this only once and if you have the DHCP running try changing only the DNS in the TCP/IP settings. It may work. Or try to Release the IP and Renewing it.
  7. Use ipconfig /release and then ipconfig / renew on a Command Prompt.
  8. If you are running DNS and DHCP Locally, then you have to change their settings to Point to the Router.
Hope this will solve the issue. If it helped you so, please be kind enough to Rate the answer with a Testimonial.
Feel free to contact again if the problem Persists.
Thanks for contacting Fixya!
Posted on Jun 12, 2010
Can get configuration addess to work
Connect your computer to your router.
It should automatically get an IP-address.
Click the Windows "Start" button (Windows 7).
Type 'cmd' into the search-box.
Press ENTER.
Type 'IPCONFIG /ALL'.
Look for the IP-address of the "gateway", or the IP-address of the "DHCP-server".
That is the IP-address that you want to type into your web-browser.
Mar 01, 2014 | D-Link Computers & Internet
Linksys NH1005 V2.2 Ethernet 10/100 5 Port Hub Router. I cant get the other computers connected to the hub to connect to the internet. I've tried everything.
Hello!
I will just illustrate on how to configure or to set the correct IP addressing;
Assuming that we will manually put IP address on each computer:
PC1:
IP Address: 192.168.1.13
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.1
Preffered DNS server: 192.168.1.1
***note that 192.168.1.1 is the IP Address that your ISP gives to you, so on the other computer (see below)
PC2:
IP Address: 192.168.1.18
Hope I was able to help.
Oct 09, 2010 | Linksys (NH1005) 5x10/100 Mbps Networking...
Computer sees router, but wont connect to internet
Check if your computer is getting an IP address from the router. Try to ping the router from the computer. If you are not getting an IP addresses check the config of the router and correct it accordingly.
Please rate if helpful.
Thanks
Apr 12, 2010 | Linksys Wireless-G Broadband Router
My vista laptop wont connect through the router
you said it says connected to the network but not oline.
Check the IP address on the wireless network connection.
there might be nay static IP address on the wireless connection.
If yes then set to obtain IP automatically.
Click here for more information about routers
Jan 01, 2010 | Linksys Wireless-G WRT54G Router
I bought a dlink n router 655 yesterday to replace my old belkin router. When i connect the modem to the n router and try to setup with the cd, it wont detect the internet. The modem i'm using is westell...
I Think you ISP must be DSL.
Your internet is working with the old router when it is in bridge mode.
Check the IP address of your computer when it is connected directly to the modem and NOT in the bridge mode. Suppose the IP address is 192.168.X.Y. After that connect your computer to the ethernet port of the router. DO NOT connect the modem to the router. check the IP address of the computer again. Suppose the IP address of the computer is 192.168.A.B. Now make sure that both the IP addresses are not in the same range that means X is NOT equal to A. If they are same, then open the set up interface of your router and change the Local IP address of the router. that will help.
For More information Click Here
Oct 05, 2009 | Computers & Internet
Computer says connected to internet,, wont display page
usually routers are setup using DHCP... on your second computer. try going to
start, control panel,  networkconnection,  "your LAN connection",\ properties Internet Protocol (TCP/IP) (should be checked)
Obtained Ip address automatically should be selected
Obttained Dns server automatically should be selected.
then click OK, OK to save settings...
if your router is not setup as a DHCP,it would require you to setup your ip address manually... let me know if this dont work, so  i can help u setup manually...
if it helps, try comparing the settings of your pc1 and pc2 (the network connection settings)
Feb 02, 2009 | D-Link DSL 604+ (DSL-604+) Wireless Router
Cant get xbox live without an ip address
An IP address or internet protocol address is a unique address that certain electronic devices use in order to identify and communicate with each other on a computer network utilizing the internet protocol standard (IP) n simpler terms, a computer address
is given by your provider (Who provides the Internet connection)
I recommend voting ;)
Jul 01, 2008 | Microsoft Xbox 360 Console
This sucks balls
Are you connection to a router? directly to the modem? Is your PC getting an IP addresse?
Nov 16, 2007 | Video Game Consoles & Games
Network
as long as you are not using your own router to connect to your neighbours, as this wont work only one router on the network can connect to the net Im assuming your pc is trying to connect to the neighbours router, so you need to reset the router if you cant access it, it should have no password as default and the ip address of the router should be 192.168.2.1. get into your network cards properties and ensure obtain an ip address automatically on the TCP/IP line is selected. Go into the router settings and make sure enable DHCP is set to allocate ip addresses automatically and that the router transmits on mixed mode b and G, turn off any wep or wpa encryption until you have a connection. Do not use windows connection repair as it will totaly mess up your pc's ip addresses and stop you from connecting to the routers ip address.
Aug 28, 2007 | Belkin (F5D72304F5D7000) Router
Problem connecting to the net
You router may be set to be DHCP enabled so that it allocates the ip addresses automatically to each pc, so check that the pc's network card with connection problems is set in the properties on the TCP/IP line is set to obtain an ip address automatically. You can also try, Start>run then type ipconfig /flushdns to clear the pc ip address and dns. and restart pc. Lastly if you pc is both network cabled and wireless, ensure one or the other is dissabled as this can confuse the ip adress alocation.
Apr 29, 2007 | Linksys Wireless-G WRT54GR Router
Linksys Wireless-G Broadband Router Logo
76 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
