Question about Hamat 3-2861ST Everest Pull-Out Kitchen Faucet with Lever Handle Stainless...
I replaced the original spray head years ago and have been using cheap plastic spray heads. I would like to purchase an original spray head if possible
  • 119 Answers
I believe Price Pfister sprayheads will work on your faucet and they hold up nicely
Posted on Nov 15, 2009
ARE CARTRIDGES STILL AVAILABLE FOR THIS OR DO I NEED TO BUY A MODERN PIONEER TURNTABLE COMPATIBLE WITH MY PIONEER AUDIO SYSTEM
You don't need to get an exact replacement! Just one that will fit the head. You might even get a better sound from it by fitting another make of cartridge. Simply because some manufacturers of deck fit "cheap cartridges" to some makes of deck. They hope that people think that you can only fit there make of cartridge, even though you might be able to get a better - plus sometimes cheaper model.
Jan 10, 2016 | Pioneer Audio Players & Recorders
Brothers LC61 Series printer head purchase
yes you must remove the plastic strip before inserting the cartriges other wise the ink cant cover the head or jet
Mar 25, 2013 | Brother MFC-290C Printer
I've attached the shower head as tightly as I can but water backs up and sprays upward and outward with very little coming out as spray. Seems that a washer is needed but note came with my...
There should bea rubber gasket/washer that goes between threads on shower arm and inside of shower head. If this is a new shower head I would return it to place of purchace for exchange. If not you should be able to get the waher seperatly. If not you can get a cheap shower head and use the gasket from it. I also would recommend that you use several wraps of teflon pipe joint tape on shower arm and tighten snugly.I hop this helps you. Thank you a have a good year
Jan 02, 2011 | Water Pik Shower Head
My 6 year old Kenmore Elite DW has started leaking and has a musty smell. The dishes are clean but food residue is left on the inside door and black gunk builds up on the bottom of the dishwasher.
Use a wet/dry shop vac to clean out the strainer and drain from the inside of your machine. A musty smell is a sure sign that food particles have clogged your drain BUT can also mean that your wash/spray heads have become clogged as well. Use a pipe cleaner on the spray heads and run water over the jets to make particles flow to the big hole in the center of your wash heads, then reassemble. Don't forget to put those little plastic looking rings back exactly the way you found them or your wash heads wont turn properly. They are usually made of teflon to lubricate the spray heads.
Mar 05, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
EPSON PRINTER PRINK HEAD PROBLEM
Problem with ink flow. Use original ink or compatible? If original, ink will out and dried after head cleaning many times. If compatible, problem is ink quality. When head cleaning, ink flow to head by suction of head cleaning mech. If use to print, ink at head spray out, but ink ank ink tank not flowing good to head.
Jun 28, 2009 | Epson Stylus CX5400 All-In-One InkJet...
CAN NOT PRINT COLOR -PRINTS PINK STRIPES
Take some paper towels, fold them in half, spray them with alcohol FREE glass cleaner and set your color cartrige on the paper towels and let them soak for thirty minutes or so. DO NOT USE ALCOHOL it sets the ink. also clean the thin plastic strip in the back of the print heads this is the encoder strip and it tells the print heads when to dispense if this is dirty from overspray it will affect your print quality. Use q tips and the same alcohol free window cleaner.
Jun 04, 2009 | HP Officejet 9110 All-In-One InkJet...
1992 Lincoln Continental engine/gasket problem
These vehicles are historic for head gasket problems. Ford had issued a recall because there where so many problems. The new head gasket is a different material than the original. Cost to replace varies by shop and geographic location, plan on around 1100 bucks.
Apr 09, 2009 | 1992 Lincoln Continental
Leak where Grohe shower head attached to the threaded pipe
Hello, Many shower heads have similar problems. (Very frustrating as you now know) The problem is the threads at the end of the (cheap plastic) shower neck are not flat. They are tapered (has an edge) - so it does not seat flush with the base of the shower head. Actually cuts around the rubber washer causing a leak.
What to do about it?
File the end of the neck some to create a flat surface. However, go slow. Be sure you can still screw on the shower head. Add a flat rubber washer in the shower head and plumbers tape on neck threads too.
Or Purchase a new shower neck that has a better design. The neck should unscrew from the front. Check and make sure you have an access behind the shower just in case you need to access the plumbing.
I replace the shower neck myself if there is an access.
Rob
Jan 17, 2009 | Grohe 28.275.AV0 Relexa Plus Top 4 Spray...
Hunter sprinkler head adjusting...
I googled Hunter sprinkler heads and where to purchase them. In my area (the East bay, Tri-Valley) in Nothern California.
I went to Ewing Irrigation in Dublin, CA and found the Hunter sprinkler heads there. The man working the counter got two for me and he demonstrated how to change the head by unscrewing it from the base at or just below ground level by removing the old one and screwing in the new head. He also showed me how to adjust them with the spray pattern. You will need the little tool that comes with the sprayer head.
Making sure the center arrow is completely to the left and rotate the head to the right then back to left. They are set to a 180% spray pattern from the manufacturer. If you want a bigger pattern you turn the adjuster toward the ( + ) side and if you want less pattern you turn the adjuster to the ( - ) side. He showed me how to install the red sprayer inserts by simply pushing them in the cavity making sure the little u shaped indentation is pointing up to allow for the set screw to go through to adjust the spary.The spray varies in distance and amount of water being emitted from the head depending upon the insert used.
I was able to replace the Hunter head, adjust the spray and changed out the insert a few times until I found the one I liked. I used needle nose pliers to remove the initial spray insert that the man @ Ewing installed until I found the one that worked best.
I found using needle nose pliers makes it very easy to grasp the little inserts for replacing.
-Terry
Apr 04, 2008 | Ace Hardware Hunter& Low Profile III...
Hamat 3-2861ST Everest Pull-Out Kitchen Faucet with Lever Handle Stainless... Logo
220 people viewed this question
Top Hamat Plumbing Experts
Colin Stickland
Colin Stickland
ray gallant
Daryl Gleaton
Are you a Hamat Plumbing Expert? Answer questions, earn points and help others
