Question about KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher
Hi i have a Simpson dishwasher EZIset 52B850wj*05 The problem is the timer that you pull out to turn on and change the cycle will turn but won't engauge into the different cycles. I have had this fixed once and it worked for maybe 1 month and then the same problem & I refuse to pay to get it fixed again especially if it is going to happen agian and again. Toni
  • thedavos Nov 13, 2009
    I went to take the motor offthe front panel but the dial that you turn is stoping it from coming off there must be a simple knack to it?
  • 6,784 Answers
HI. This will occur when there are issues that concern the timer motor. This mechanism is responsible for the forward advancement of the timer plate over the dial cogs. if the motor is faulty, it will cause the cycle to not advance correctly. If this is a reoccurring case with the timer, there may be a fault within the production line that the manufacture is not aware of. To confirm damage, use the procedure below. These modules are not reparable. usually, the service tech will simply replace the timer module with a new one.
TIMER TESTING PROCEDURE
To service the timer motor, it is necessary to access the control panel in the door. Access varies by model; on some models you can remove just the control panel on others you must remove the interior or exterior panel of the door. Start with the door closed and locate any screws on the front that must be removed. Usually there are one or two screws near the latch; do not remove the latch itself unless necessary. Now open the door and remove the screws near the top. Start with the top screws and attempt to remove the control panel. Check for screws along the top of the door as well.
If the control panel cannot be removed, then it is necessary to remove the entire door panel. Remove the screws along both edges of the door. There may be several screws near the bottom of the door that secure the door to the door hinge mechanism, it should not be necessary to remove these screws. Carefully lift the panel off from the door. The panel may have wires connected, so check before lifting the panel out too far. If the panel does not lift out, check for other screws.
Remove the control panel cover to expose the door's control components. It may be held in place with additional screws or clips. Locate the timer motor. If you find two motors, the second is the rapid advance motor which operates when the wash cycle is canceled or reset. If you cannot determine which motor is the timer motor, test them both. The round motor housing has two wires extending from it. Follow the wires to the terminal connections.
Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a multimeter to test for continuity. Set the meter to the ohms setting X1000. Touch one probe to each wire. A reading in the range of 2,000 to 3,500 ohms is normal for most dishwashers. If a schematic of your dishwasher can be located, it should indicate the proper resistance for your timer motor. The schematic may be in one of the service areas of your dishwasher or your owner's manual. If your measurement varies substantially from normal range, the timer should be replaced.
Posted on Nov 13, 2009
  • Michael Masters
    Michael Masters Nov 14, 2009
    Ok, that is called the timer knob. you should be able to pull it right off the dial stud. Pull gently, until it slides off the dial stud.
Recently had a leak in our water pipe between mains and house.We had the pipe replaced.Then the washing machine wouldn't fill so we replaced solenoid valve-it works now. The dishwasher won't fill now
when the pipe was repaired , there is every possibility that dirt got into the pipe and will affect all solenoid operations and taps
remove all hoses and flush the pipe out well
Oct 21, 2016 | Simpson Washing Machines
Recently had leak in water between mains and house. Pipe replaced.Then washing machine wouldn't fill.Replaced solenoid valve -works now.The dishwasher Simpson EZISET 52B850WJ*03 won't fill.Same?
Could be dirt in the water lines after you repaired. You should always run your taps for a while before running machines that use water. I like to run water from my out side taps if I have outside repairs.
Oct 21, 2016 | Dishwashers
My Simpson eziset 650 won't complete a cycle it
The machine has detected that it's taking too long to fill, check the hose filters in the inlet solenoids (remove the hoses and you will see them) make sure your taps are turned up, If all seems ok then you have work inlet solenoid(s) and will need to replace 1 or both of them depending on if it does it on both hot and cold cycles.
Mar 05, 2012 | Samsung Washing Machines
I need to replace a lower door seal in a simpson dishwasher 52b850wj
Take out all the screws around the inside edge of the door and then this panel can be lifted to release the old seal.
Nov 10, 2010 | Westinghouse Dishwashers
Simpson eziset 52b850 how to power on the dishwasher??? And how to use it.
Plug in machine and turn power switch on. Then press the front left hand power switch on and the select program and finally press the large right hand start switch.If you wish to change or reset a program hold the previouly selected program button in for 10 secs and the reselect your program choice and hit sart.
Nov 06, 2010 | Dishwashers
I need a manual for a Simpson Eziset 52B870 Dishwasher
http://spares.bigwarehouse.com.au/ this website has schematic diagrams with part numbers for Simpson dishwashers.Does have some manuals for a range of goods.If not you can upload one.
Oct 17, 2010 | Dishwashers
Simpson eziset 750 manual
Hi our eziset 750 simpson washing machine has stopped working. It randomly just turns off and then will start again few days later. Cheers
Aug 28, 2010 | Washing Machines
Bad smell in Simpson Eziset 550
pour a few litres of vinegar in the machine on low level of water and do a wash with no clothes in it. should clean tub and drain hose
Sep 06, 2009 | Washing Machines
Spray arms clogged
Top: Remove the upper tray by releasing the clips on the ends of the runners. (Squeeze the top of the clip and pull upwards). Remove the spray arm by holding the round plastic clip that holds the arm and turning the arm. It will unscrew.
Bottom: Grab spray arm in centre and pull sharply upwards to unclip.
Wash in warm water and solvent-free detergent.
Jun 11, 2009 | Samsung Dishwashers
KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher Logo
178 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
