Question about Nintendo Wii Console
I dont want to sync my remote each time i play the wii how can this be resolved?
  • 127 Answers
A lot of times the controller starts acting strange once the battery starts to get low. (and if you drop it!)
so if you know someone borrow their WII controller and test it. if the controller works fine then your other controller is probably damaged. a new WII controller is about $40 so you could either buy a new one or get a used one from wherever like craigslist or something.
Posted on Nov 13, 2009
Why can't I play the Wii there are new batteries.
You have to sync the remotes to the Wii. Open the battery compartment on the Wii Remote.There should be a little red button. Press this button.Now, on the front of the Wii, there should be a little door compartment where the SD cards etc. go. Open this door and press the red button there, after you have pressed the red button on the Wii Remote.
Your Wii Remote should now be synced with the Wii Console.
Feb 24, 2012 | Nintendo Video Game Consoles & Games
I dont know how to sync my wii and its nanchack>> not sure of thats whats it called
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
    Standard Mode Synchronization
    Note: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote addedto your system.
    Go to the Next Step (Playing Game Discs) >
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Set Up and Use of the Nunchuk
  1. Feed the cord on the Wii Remote's wrist strap through the connector hook. nunchukwristattach.gif
  2. Insert the Nunchuk plug into the Enternal Extension Connector on the bottom of the Wii Remote.
  4. nunchukhold.gif nunchukclipclose.gif Note: Place your hand through the wrist strap of the Wii Remote and hold the remote firmly in your hand. Slide the strap lock up so that the strap will not fall off of your wrist. Do not over tighten the strap lock so that it's uncomfortable. It should just be light enough to hold the wrist strap in place. (For more information on using the wrist strap, click here).
May 04, 2011 | Toys
Wii hand will not show up we tried syncing, taking out batteries, unplugging and plugging sensor bar and nothig works
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
Jan 27, 2011 | Nintendo Wii Console
I have a problem with wii console.. I can choose everything in the menu, wii recognizes while I am in the menu part but when I am entering to wii sport I can not play the games.. It doesnt capture the...
1- Try to press home button ,if it loads u can sync the remote from there.
or
2- Try to re-sync your remotes by pressing both sync (from remote and wii at same time) in the game.
or
3- You can get a new remote and see if it works during playing . If it does your previous remote isn't working properly, but if it doesn't there is a problem in either the game or wii (bluetooth module)
Feb 27, 2010 | Nintendo Wii Console
Lites flash on remote and thats all
Your Wii must be on to be able to Sync the controllers.
Press the power button on the Wii, then press the red sync button located behind the SD slot door. Once this button has been pressed, locate your controllers, take off the battery cover, and press the red button inside the battery compartment. The blue lights on the front will flash a few times, a chime will be heard, and your controllers will now function with that Wii.
Every different Wii you use these controllers with, you must sync them every time to that other Wii
Jun 21, 2009 | Nintendo Wii Console
Can't play multiplayer games
for each individual remote you will have to sync it to your wii by opening the back of the remotes where the batteries go you should see a little red button next go to your wii and open the compartment where the sd card goes and there should be a red button in there to press the buttons at the same time and let them sync dont touch any other buttons after you press them at the same time and they should all sync do this to the other remotes and you should be playing in no time
Mar 19, 2009 | Nintendo Super Smash Bros. Brawl for Wii
I was trying to register the Wii Balance Board for my Wii Fit. I think I may have presses the sync button on the Wii console too long and caused my Wii remotes to become unregistered. How can I correct the...
Hey wva54ccc,
According to information provided by the manufacturer, holding the sync button down for a prolonged period does clear all synced devices from the Wii's memory. In order to "start from scratch" and resync your remotes, you'll want to do the following:
1) Turn the Wii off and unplug it for at least 1-2 minutes. After this time has elapsed, plug the Wii back in.
2) Turn the power on again, and press the "Sync" button on the front of your Wii console for 15 seconds when the "Health and Safety" screen is being displayed. This will clear all previously synced devices from the Wii's memory.
3) To sync a remote/accessory to the Wii, you'll need to press the small red button located just beneath the batteries. When you do so, the blue lights on the front of the remote/accessory should blink.
4) Next, quickly press the "Sync" button on the Wii console again.
5) After the "Player" LED light stops blinking and stays lit, the remote/accessory is synced and no further actions are necessary with that remote.
6) Repeat steps 3, 4 and 5 for each remote/accessory you wish to sync to your Wii.
Should following these steps not resolve the problem, I'd strongly suggest checking out Nintendo's Wii remote troubleshooting website for more information.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 23, 2008 | Video Game Consoles & Games
Setting up 2nd wii remote
Greetings mlsaenz7,
You need to resynch the second remote to the Wii console. To accomplish this you need to hit the sync button under the battery cover on the remote, and then when the lights are flashing on the remote, you hit the sync button on the Wii. The synch button is located under the small cover to the left of the cd/dvd slot.
Thank you,
Dort
Go Ahead. Use Us.
Apr 19, 2008 | Nintendo Wii Console
Wii remote
Hi Nixo, probably needs re-syncing, press the sync button on the Wii console and the button on the wiimote (under the battery cover), do it pretty much at the same time, the wiimote usually vibrates and one light wll show up.
Hope this helps
LesPix
Feb 28, 2008 | Nintendo Wii Console
Remotes not synchronising
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
Sep 15, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
