Question about D-Link DI 514 Wireless Router (DI-514)
How do I secure my network. I have a Linksys Wireless-G 2.4GHz 54Mbps broadband router?
  • 6,831 Answers
Hello
SSID you will define this to your liking so that when the computers in the house search for a wireless connection you are able to pick the one you set up. Some names you can use are like "Patrick A" or "The Incredible Pat" or "No Man's Land" - You get my drift.
WPA2 is the type of security you can specify. You will see a drop down of 4-5 others. I believe WPA or WPA2 in the dropw down will allow you to type your own password thats 8 characters long. The other options if chosen, you will be told what your password is and its usually some long 16 digit key.
This way if anyone comes over the house and asks to connect to your wireless network you are able to give them the password from memory b/c you defined it. Kind regards
Andrea
Posted on Nov 13, 2009
  • D-Link Master
  • 32,281 Answers
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 27, 2013 | Linksys Wireless-G Broadband Router
How do i set my password on my linksys WRT54GL router
Turn over router and check in the bottom default access IP address and then type that IP address in to your browser. Then it shall ask you for ID and password. Enter `Admin` or `admin` as ID and `Password` or `password` as password. You will see a web based setup opened in front of you. Go to the Wireless Lan settings and then you will SSID so change the SSID and this would be your network`s name. Then go to subsection security and select WPA2-PSK or simple WPA-PSK then enter your desired network key. Once done with all these things the click apply and reboot if prompted.
May 12, 2012 | Linksys WRT54GL 802.11b/g Wireless...
Would like to secure my network
Follow this link to download the manual that will give you set by set instructions on your router. And security setup.
http://downloads.linksysbycisco.com/downloads/WRT54GL-EU_11_UG_A-WEB.pdf
Oct 04, 2010 | Linksys WRT54GL Wireless-G 54Mbps...
I want to set up my Wireless-G 2.4 GHZ 54Mbps
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 17, 2010 | Linksys Wireless-G Broadband Router
How do I secure my laptop with linksys broadband G router
You will need to secure the wireless network. You can enable password protection on the wireless network. Do you have any computer connected to the router with the ethernet cable ? If not then you will need to connect the computer to the router . After that you can access the router set up. Once you access the router set up then you will find the wireless security. Click Here for step by step solution
Nov 17, 2009 | Linksys Wireless-G Broadband Router
Have Linksys Wireless-G 2.4 GHZ 54Mbps Broadband router. Bought a new desk top computer and it won't let me install the CD. Linksys tech support was unable to assist because the warranty had expired. I was...
Hi there, you don't need to install from the disk. Make sure your modem connects to your router and then the computer's LAN port is connected to the LAN port of the router. Open internet explorer and in the address line type 192.168.1.1 this will connect you to the router's setup. On older Linksys routers the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin." You then can find the wireless setup to configure your router. Make sure if you use a WEP code you use the same code from your computer's wireless adaptor. Good Luck...
Nov 12, 2009 | Linksys Wireless-G Broadband Router
INstallation instructions Linksys wireless-G 2.4 GHz 54Mbps broadband router Model No. WRT54G V8
By default the box will work (box is pre-configured).
For your ref. i am providing you the link with basic configuration steps.
http://www.columbia.edu/acis/networks/aptnet/linksys/index.html
Jun 04, 2009 | Computers & Internet
Router doesn't broadcast?
Make sure the brodcast light is on. and that brodcast is on in the congfig screen of the router.
Jan 29, 2009 | Linksys WRT54GL Wireless-G 54Mbps...
Unsecured network
open 192.168.1.1 in your browser.It will ask for username and password.Leave the username as blank and in password type admin.You will get the linksys pages.Now click on wireless on the black bar at the top.Click on wireless security just under wireless in the blue bar.Select security mode as WEP.In key 1 type any 10 digit no. which will be your security key.Scroll down and click seave settings.now your network is secured.
Jul 12, 2008 | Linksys WRT54GX4 WIRELESS 802.11G...
Where do i find the network key?
You can find the network key (wep key) on the web interface of your Linksys router (192.168.1.1), under the Wireless tab, look on Wireless Security.
Nov 28, 2007 | Linksys Wireless-G Broadband Router
D-Link DI 514 Wireless Router (DI-514) Logo
101 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
