Question about Microsoft Windows Vista Ultimate Edition
Media Center Library
Music files were on an external HD (drive H) when Media Center (on drive C) was set up. Now moved to the same laptop (D drive) and when attempting to play files, I'm tod that they are not available - the file location is still quoted as drive H. I've done setup again and trying to add a folder for MC to monitor (d:/music). However, although that folder is listed, the regular emply check box (which I would select) is not there but a faint tick mark is. I'm unable to select D drive and no folder changes are made. The odd thing is that I first moved my photos in exactly the same way and they work fine. I want them both on the laptop so I can easily view them (with music) on my TV.
  • tjohnny Jan 08, 2008
    Sorry, may have posted this in the wrong place. My Media Center is part of Vista Home Premium edition
    Genius:
  • 1,067 Answers
U dint drag drop on did u or shortcut them to d drive cuse u need to copy and paste those files into d then dl wma 11 from custum updates in microsoft ok also run updates have it cheak for add on updates not just reg secruity ones
Posted on Jan 08, 2008
  • nick helpap
    nick helpap Jan 08, 2008
    also usally u tell meadi player were they are or do scan for music on wma 11 do meadia center knows
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Tip
Moving the iTunes Music Files to a Different Hard Disk/Folder If you are low on...
If you are low on disk space in your iTunes folder then you can move these music files to another hard drive and keep your music library in tact without the need to create your music library again.
If you want to transfer your iTunes to an external USB hard drive, make sure that it is powered up and connected to your computer before opening iTunes.
Opened iTunes, click Edit and then Preferences. Click the Advanced tab.
Make sure the Keep iTunes Media folder organized checkbox is checked, and click Change.
Then select the location where you would like to move your files to. Click Select the Hard Drive and Folder or OK once you’re done.
The files will not move into their new positions by themselves –To do this – click File, Library and Organize Library. Check Consolidate Files.
When this process has been completed, go to the new location of your iTunes media and check the music files to see if they have migrated across correctly. Also play one or more tunes to test the music files.
The redundant iTunes music files can now be deleted from the original iTune location (C:\Documents and Settings\…..…\My Documents\My Music\iTunes). Delete everything from iTunes there except files titled iTunes Library.itl and iTunes Music Library.xml. These are still needed.
on Jun 05, 2010 | Computers & Internet
Tip
Make a back up of your music on an external Hard Drive or Flash Drive
Copy iTunes folder to your external hard drive
To copy all the items in your iTunes library (including the iTunes Library file that holds all your playlists, playcounts, ratings, and other data) to your external hard drive, follow these steps:
Quit iTunes.
Locate your external hard drive.
Mac: On the desktop or Finder sidebar.
Windows: In My Computer
Locate your iTunes folder:
By default, the iTunes folder is located in:
Mac OS X: /Users/username/Music
Windows XP: \Documents and Settings\username\My Documents\My Music\
Windows Vista or Windows 7: \Users\username\My Music\
If the iTunes folder is not in the default location listed above then you can find where the iTunes folder is located by following these instructions:
Open your iTunes Preferences:
Mac: Choose iTunes > Preferences.
Windows: Choose Edit > Preferences.
Click Advanced.
The location of your iTunes folder will be listed in iTunes Media folder location box, as pictured below.
Drag the iTunes folder to your external hard drive. This can take a while if you have a lot of items.
When the transfer is complete, your iTunes Library will have been successfully copied to your external hard drive.
on Apr 15, 2010 | Computers & Internet
How do I backup itunes file on external harddrive
It's a good idea to regularly back up all important files on your computer to an external source to prevent data loss. Your iTunes music, videos and other digital downloads are stored in separate files within the iTunes folder. However, if you consolidate them into a single folder, it's easier to back them up to an external hard drive.
Launch iTunes. Go to the program's Preferences menu. Click the "Advanced" tab. Check the box next to "Copy files to iTunes Media folder when adding to library" and click "OK." Click "File." Select "Library" and then "Organize Library." Check the box next to "Consolidate Files" and click "OK." Close iTunes. Connect your external hard drive to your computer. Find the iTunes media folder on your computer's hard drive. Drag the folder to the icon for your external drive to copy your iTunes media.
Back up your iTunes library by copying to an external hard drive http://support.apple.com/kb/HT1751
Mar 19, 2013 | Computers & Internet
Windows media player won't play any audio selections , says can't find files
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display. The Xbox 360 gaming console is an example of an extender.
Click on "Allow a program or feature through Windows Firewall." Click to check "Media Center Extenders." Click on "Apply."
Click on "General" and select "Windows Media Center Setup." Click on "Set Up Your Speakers." Follow the on-screen prompts to reconfigure your speakers.
and you should run the chkdsk utilty
You could run the chkdsk disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive
or an easier way i have found to run the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers operating system and hard drive.
hope this helps
Oct 23, 2012 | Toshiba Satellite A60-692...
How do I use my WD hard drive to store files so I can free up space on my laptop hard drive?
Hi:
That's an easy task:
1) Plug your Hd to your laptop and wait until the laptop recognize it as a new drive and assign a new letter to it. If you have a disc use it if your laptop ask for it.
2) Copy all files you want to transfer to the new HD and paste them on it.
That's it.
Sep 27, 2011 | Western Digital WD My Book Essential 1TB,...
Accidentally disconnected external HD while moving files
have the files been deleted from the laptop? if not i would simply do a fresh format on the external and re migrate data. if they are then you can get software such as undelete or recover my files to restore your deleted data off of your laptop drive.
Dec 09, 2009 | Western Digital My Book Essential 1TB...
I have a 1 terra bit external hard drive . I edited music from a pc to my external hard drive using cd's & lps. I've been having problems with putting my music library in my new laptop computer. One...
Your installed music library in your external hard drive might not be supported by your media center on your new laptop, try to convert the files where the software are supported by your media player. try convert Master software, you can download it free then convert your files
Nov 01, 2009 | Seagate Free Agent Go Small 12 GB USB...
Plz,help!
Oh! Right gotcha. :)
Do you have an external drive by any chance?
Or have you moved or deleted any music?
Run the library/music-file search thingy.
Sonic Stage doesn't know where your music is anymore.
(I moved mine onto an external drive and kept forgetting. I'd open it and go What!! oh. ...doh!)
Jun 19, 2008 | Sony NW-E003F MP3 Player
Saving my music
Windows media player is probably right because you have moved the music to another location. You might need to rebuild the library.
Use Windows Explorer to check that the music is on the new drive.
Can I also recommend downloading Winamp to play your music, It's free, sounds better and doesn't spy on you!
Oct 20, 2007 | SimpleTech Pininfarina 80GB External USB...
Microsoft Windows Vista Ultimate Edition Logo
48 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
