Question about Samsung LN-T4665F 46 in. LCD Television
Was watching tv... then the tv just shut itself off.. theres this smell like something melted inside.. I unplugged it right away.. it's been about 30min. when I plug it back it, the red standby light comes on.. but when i try to turn on the power, the standby light shuts off for about 5seconds, then comes right back on. There is also the very faint buzzing sound from inside the tv.. It buzzes for a second, then stops, then does it again.. it keeps doing that as long as the tv is plugged in.. what happened to the tv?
  • 11,361 Answers
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. It can be the capacitors are venting out.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 14, 2009
Thomson 50DSZ644. Just replaced the Lamp great picture but burned smell.. after few house it smelled verry bad..and i turned off. now when i turn on the tv the picture in middle is dark and still thi
should have unplugged it when you noticed the smell.
UNPLUG and remove and look at lamp you installed--is something in the housing where lamp goes melted? I hope you did not touch the face of the bulb with your hand or fingers.
What ever is wrong find it before trying to use set again.
Dec 22, 2012 | Thomson 50DSZ644 50" DLP Rear Projection...
I have a rca d52w23 while i was watching tv in shut off and there was like a smoke smell I mean I turn it on and it shuts off by it self is it worth fixing it and what can cause this problem
Where there is smoke something burned--unplug set for safety and if curious open rear cover and look at boards near rear of set for a burnt part--that will usually determine if worth fixing or not.
Apr 26, 2012 | RCA D52W23 52" HDTV CRT TV
I have a 54" Mitsubishi tv that turned itself off
It depends what the fault is and the cure.
Get an engineer to give you an estimate for the repair.
Mar 22, 2011 | Mitsubishi VS-45609 TV
The unit works as of right now...but there is a smell of something burning
Quite often, if you smell like a plastic burning smell, one of the capacitors is faulty, and should be checked immediately. Quite often the compressor start capacitor, will get hot and start to melt. Have it checked by qualified technician or electrician, as they are dangerous and can give a fatal shock if not experienced with handling them, even when power is shut off. $20-$30 part, and 1/2hr. labor should take care of it. The cover on roof unit, has to be removed to access the capacitors, so watch for bees, wasps, when you do so. Make sure power is off at breaker panel.
Aug 01, 2010 | Coleman Heating & Cooling
Sony KDF-50E2000 shuts down and blinks repeatedly twice.
The 2 blink error is a temperature error and the 6 blink error is a thermal fuse error. You may need to unplug the set and get you a can of canned air, take off the back lower cover and blow out all of the fans inside the set.
Oct 20, 2009 | Sony KDF-50E2000 50" HDTV
Was watching tv and it turned off by itself. I could smell something before it happened. I unplugged the tv. Now I can hear a humming noise when I plug it back on but it does not turn on. HELP
When smell are coming out then powersection and, or high voltage section burnt parts inside. Replace all and if you have look then the transformer still ok for the high voltage, if not replace it
Aug 31, 2009 | Televison & Video
My 32v434t television.
The TV was making the clicking noise and not turning on because an internal error was being detected.
Now things had got worse , and something had blown inside the TV.
The burning smell and high pitched noise is coming either from Flyback transformer or PSU board. Repair is a delicate matter and must be done by a technician.
Jul 05, 2009 | RCA TruFlat 27F520T 27" TV
Tv popped and shut off
Burnt small 2KV capacitor near flyback xformer....original is
221K....I use 271K / 2KV ...Possible burnt 1K 1/2 watt resistor
and shorted zener diode ....ECG 519..................T.
Dec 08, 2007 | Zenith B27A11Z 27" TV
Samsung LN-T4665F 46 in. LCD Television Logo
162 people viewed this question
Henry  Thomas
Henry Thomas
