Question about Refrigerators
This Fridge is 3 years old and recently started making noise when the freezer fan is running. I pulled the ice maker and rear inside freezer panel and discovered it was the plastice freezer fan that was the culprit. It stopped just as I had made this discovery. I carefully put everything back together to ensure the palstic panel did not make contact with the fan. I thought all was well for about 2 weeks and the noise is back. It sounds as if the fan blades are barely making contact with something. It sounds like a straw in a bicycle spoke.
  • Anonymous Jun 10, 2008
    Yes, twice now. It originally happened while under warranty. After three repair attempts the technician authorized replacement of the entire fridge. Now after a year and a half the new fridge is doing the same thing. This time I note that it happens when the inside house temperature exceeds 75 F.
    Very annoying, considering how often I get extended warranty solicitations from both GE and Sears. Refrigerators shopuld last 20 years. If they don't, I won't buy that brand again, and I certainly won't buy their extended warranties!
  • bebik22 Apr 29, 2009
    noise comming from Freezer seems that ice is building up on fan and then fan starts touching it's housing ......what do I need to replace?
  • 236 Answers
Unplug your unit and check the fan blade by manually rotating it with your finger, check if the blade is not touching the fan blade frame. Check if the screws are not loose, align the fan blade and re tight the fan blade screws.
Posted on Jan 09, 2008
I have a ge adora fridge that when pressing the lever for ice makes a loud humming noise & feels like freezer wants to explode. Cab anyone tell me if they have ever run into this issue
You probably have a ice dam in your ice tray. The anger is trying to dispense if but if the cubes have frozen together and produced a large chunk of ice it cannot break up. Open the freezer door completely and lift up and pull out through ice tray. Remove ice until dam removed. Reassert tray and make sure to turn ice maker back on. It is essy to inadvertently bump switch. Try dispensing ice to see. If noise went away.
Hope this helped!
Apr 19, 2016 | GE Refrigerators
I have GE ADORA DSS25KSRDSS FREEZER FAN NOISE, how do you remove the cover panel to get to the fan that hits the cover ?
This model is quite the stinker and everything, and I mean everything has to come out to make it easy to remove the fan motor.
I have found that on GE's the blade becomes loose and that is what hits. Sometimes the blade is no longer available since Haier now owns them.
Take pictures during disassembly and lay everything out on towels so it can go back together right and take your time! This is a tough one
Feb 09, 2018 | Refrigerators
My G.E Adora refrigerator freezer is not cold enough. Ice cream is melting and refrigerator is at too cold and is freezing food, It is only 5 years old. It is a side by side. Help!
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Sep 18, 2010 | GE Adora (DSF25KGTBG) Side by Side...
Loud noise from freezer of GE model GSF25TGTB (Side by side)
Problems not related.  The first is most likely the fan, or possibly water dripping on to the fan and freezing, but usually the noise comes from the fan struggling to run.  The cube problem could be as simple as the ice dispenser being put back in wrong.  There is a metal lever under the ice tray that switches between crushed and cubed.  Make sure it is seated properly.
Dec 04, 2009 | GE GSF25XGR Side by Side Refrigerator
GE Profile stopped making ice. 2 yrs old
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath freezer needs to be 0 degree F to start ice maker
Aug 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Adora Side by Side Refrigerator Ice maker
You may ahve a problem with your freezer temp. Check your setting. Turn down a few notches to see if problem goes away. Also Pull out your fridge and vacuum out your coils underneath unit. Plug coil causes freezer temp to rise. Rus
Jul 04, 2009 | GE Adora (DSF25KGTBG) Side by Side...
GE GSL25JFR Freezer fan noise.
Replace the fan motor is my guess to cure the noise.
Mar 01, 2017 | GE Profile¿ 42" Built-In Side-by-Side...
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
Sep 12, 2008 | GE GSS25JEM Side by Side Refrigerator
Loud humming noise as fridge is running
Hey everyone-
I recently fixed a similar problem with my freezer. I searched first and found this and a few other sites which listed this and wanted to provide input for anyone in the future.
I have a GE GSH25JSRF SS. It is about 3 years old. Several months ago I noticed when the evaporator fan in the back of the freezer turned on it would make an awful howling or whistling sound. Basically sounded like what you would hear from the window of an older house if the wind outside was blowing real strong. It was loud enough to hear on the other end of the house.
I was convinced that it HAD to be the air blowing over the venting or a gap that created that sound. But I read different solutions on the internet and decided to take a chance on simply replacing the evaporator motor and attached fan blade. That solution worked and my house is quiet again, thank god.
I ordered the parts from a supplier on the internet. Keep in mind, though, if you're not real handy it may be more than you bargain for. Might be easier to have a service guy come out.
I'm still not sure exactly what aspect of these parts caused the howling sound. It could be a bearing within the motor or perhaps the fan blade slipping due to wear. Either way, it's fixed now. Just wanted to share. Thanks.
Oct 04, 2006 | Samsung RS2630WW Side by Side Refrigerator
Refrigerators Logo
791 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
