Question about LG DLG8388 Dryer
LG DLG8388WM won't heat ...
My DLG 8388 won't produce any heat - anyone know what the probable causes are? Gas supply is fine ....
  • daievans Apr 24, 2014
    I fixed it by replacing the gas valve/solenoid .... it was pretty straightforward, once i'd tried a few other potential causes!
    Problem Solver:
  • 5 Answers
It could be a clog in the supply pipes inside the dryer itself or a faulty regulator your best bet it to find a local repair shop as dealing with any gas appliance without proper knowledge can destroy your appliance or worse you PS: do you smell gas when it runs if so then it could be the igniter is faulty!
Posted on Apr 24, 2014
SOURCE: LG DLG 5988B gas dryer not heating
HELLO:
Have you looked at the over heat sensor on the left hand bottom of the burner pipe?
I found this and with a simple test with a butane lighter.
I used a cheep Digital volt meter and set it to ohms.
The sensor was open meanning that their was no connection between the terminals.
On the rear of this sensor there is a small button.
When I pushed the button I hear it click and the switch closed up.
I reinstalled it and the machine work perfect.
I think this is a fail safe if the exaust flue becomes clogged.
Otherwise why would it have a re-set button on it?
I am not a service / repair person.
Unplug the unit before you take the lid and front cover off.
the burner unit is in the lower right hand corner as you face the dryer.
The top comes off first and then the control panel and then you can remove the door and fron panel to expose the blower and burner.
Be carful and good luck.
Uncle Ed.
Posted on Dec 05, 2007
SOURCE: LG DLG 3788W not heating
can you look in one of the holes in the back and see if the inside glows orange after you turn it on? If it doesn't could be the igniter, if it does glow orange, clicks or clacks, and glows again 20-30 seconds later, click/clack and nothing, it's probably the gas valve. I'm going through the same thing with a new one and they had to order the valve and a new controller board in case it is bad too. If you are handy, have an electronic tester, and have the patience, go to http://136.166.4.200/contents/Laundry/DLG3788.htm for the service manual and disassembly instructions and see if you want to tackle the test flow for no heat. I just stumbled on the site.
MNTECH
  • 1543 Answers
SOURCE: front load gas dryer lg model dlg 5988w does not heat
This can obviously be several things, but I would first check the small safety thermostat. On the gas models, there is a small pin sticking out of it which can be pushed back in to reset it. It is located on the heater housing and is only about the size of a dime, with two wires on it. This will trip out easily if your vent was not clean, or is long or restricted in some ways (like using flex ducting)
If you need more help getting to it, let me know and I'll give you more instructions.
Posted on Dec 22, 2008
onthejob5130
  • 640 Answers
SOURCE: gas dryer no heat
defective gas vavle..replace
Posted on Feb 09, 2009
muntejaya
  • 10421 Answers
SOURCE: LG DLG 5988 B (LP), Dryer runs but no heat. Gas
You have heater problem and need to fix .
Posted on Dec 17, 2010
My LG gas dryer model DLG 2555W runs but produces no heat
Gas out. That is the problem. Refill Gas.
Aug 11, 2012 | Cell Phones
I have an LG dryer model DLG8388WM and it doesn't heat up. From looking at this website it seams to be the coil attached to the gas valve. Is this easy to install?
This is a very common problem amongst gas dryers and although some dryers vary, the coils (usually 2) are easily accessible near the front of the machine behind the bottom panel. They are inexspensive and certainly worth trying prior to calling out a repairman. Be sure to unplug the machine when installing the coils. They are generally held down by 1 bracket on the top by 1 or 2 screws and have a plug on each.
Aug 06, 2011 | LG DLG5932W Gas Dryer
I have a DLG8388WM LG dryer i have changed the ignitor and the thermostat twice now it still will not stay lit.it lites then goes out within a second what else could it be.
It's common for a problem like this with a gas dryer to be cause by a bad coil on the gas valve.
This is often a simple and cheap repair, but I looked up you model number and I don't believe you can get a replacement coil on this model LG dryer so you would then need to replace the gas valve, part # 5221EL2002A
Aug 02, 2011 | LG DLG5932W Gas Dryer
My dryer doesn't seem to function properly, it's just blowing cold air. I had it on for over one hour, my clothes are still wet and the air is still cold. The dryer model is LG Tromm DLG 3788W. The...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 24, 2010 | LG Dryers
LG DLG 2526W dryer running but no heat
heatman101
May 22, 2010 | LG D2526 Gas Dryer
Gas dryer no heat
Feb 09, 2009 | LG DLG5932W Gas Dryer
Front load gas dryer lg model dlg 5988w does not heat
Dec 22, 2008 | LG DLG5932W Gas Dryer
Dec 03, 2007 | LG DLG5932W Gas Dryer
Dryers Logo
402 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
