I have lost the code number to my wireless - G 2.4 GHz 802.11g
I have lost the code number to my wireless - G 2.4 GHZ. IS IS POSSILE THAT I CAN USE THE SERIAL NUMBER TO GET IT WORKING? IT IS A WIRLESS - G BROADBAND ROUTER LINKSYS WITH SPEEDBOOSTER .
  • Chris Hingee
    Chris Hingee May 11, 2010
    I do not understand the code number you are referring to. I think you are referring to the encryption code, am I correct? If so, please confirm and I can advise you what to do.
    Scholar:
  • 38 Answers
Try connecting directly to the hub using a CAT 5 cable. If you have the CD that came with it, run the initialization program to see if it will let you start from scratch. If not, open your browser and try to connect to http://192.168.0.1. It might not be secured from a hard-wired connection.
There is usually a reset button that you can use, if all else fails. Hold that button (which might be behind a small hole in the back or bottom of the case) for at least 10 seconds. The unit should restart afterwards, with all the factory defaults set.
Posted on Nov 13, 2009
Netgear wndr3400 is only pushing 2.4 instead of 5.0, my laptop and ps3 won't even pick the 5.0 up, Can anybody help?
PS3 does not have a 5.0 ghz network card so it will only see the 2.4. I suspect your laptop also lacks the hardware for 5.0 ghz.
Dec 10, 2010 | NetGear WNDR3400 N600 Wireless Dual Band...
I have defined 2 networks, one for the G and the other for the N channel, only the one for the G gets connected
You have WRT610N dual band router . it works on both 2.4 GHz and 5 Ghx bands at the same time.
Both the bands are N bands.
2.4 GHz and 5 GHz band are capable of working on N signals.
Now on your computer you are able to see only the 2.4 GHz signals but not the 5 GHz signals.
To see the wireless signal on the computer , your computer should have 5 GHz compatible wireless adapter.
If you have 2.4 GHZ adapter on your computer then you won't be able to connect to the 5 Ghz signal.
Open the Device manager and under network adapters you will see the wireless adapter. Check if it is dual band wireless adapter.
Click here for more information
Aug 04, 2010 | Linksys WRT610N Wireless Router
I lost my CD Installer for wireless-G 2.4 Ghz
You can find the software that was loaded on the CD at the linksys website.
http://www.linksysbycisco.com/US/en/support/WET54G/download
Dec 29, 2009 | Linksys WET54G 2.4 GHz 802.11g Wireless-G...
I have a Sitecom WL322 (300N Wireless ADSL modem ) router. I can connect unsecured Ok, but no connections successful yet with TKIP or AES encryption. Suggestions?
If the wireless not working with WPA TKIP or AES you can try enabling WEP aas the wireless security for your network and lets see if that will be working with that level of security....
Dec 09, 2009 | Computers & Internet
Dual band setup/wep
you have dual band router.
It must be working on the 5 GHZ and 2.4 GHZ .
if you access the router set up interface , you will find the wireless settings of the router.
For 5 GHZ , you can set up different SSID than the SSID of 2.4 GHZ.
Make sure that both the wireless network names will be different.
You use the same security settings for both the bands.
For this you will need to access the router set up interface.
Click Here for more info
Oct 31, 2009 | D-Link DIR-825 Wireless QuadBand Router
My Netgear Rangemax WND3300 has been working fine for 1 year, but in the past 2 days the 2.4 GHz wireless signal has been cutting in and out every 30 seconds, making it impossible to use my laptop. I...
Well, There seems to be an issue with the wireless network on 2.4 Ghz band. Please change the wireless channel on 2.4 Ghz to a diffrent value and check if works fine.
Let me know if you need any further help.
Oct 20, 2009 | NetGear RangeMax WPN824 Router
Wireless driver could not be installed
Did you try to update to SP3 this may have the correct driver for it......Try and hook up the computer to the router with an ethernet wire to download SP3......If this does not work remove the wireless card and read the numbers off and go to driversguide.com and look for the driver
Mar 24, 2009 | HP Compaq nc6220 Notebook
Linksys wireless-G 2.4 GHz broadband Router
Since you have problem with your router and geek squad is asking you to pay a big amount of monye just to make the router work, I suggest you contact Linksys tech support so they can help you with your concern and they are free and open 24/7, this is there number its 800-3267114.....
Nov 30, 2008 | Linksys Wireless-G Broadband Router
Setup problem
lost my set up disk so would not connect linksys wireless b 2.4 ghz 802.11b usb network adaptor
need to dwnload disk drive for linksys wireless b 2.4 ghz 802.11b usb network adaptor
Sep 08, 2008 | Linksys Wireless-G WUSB54GS 802.11g/b
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
