Question about Home Fencing
After my garage door comes down, it reopens automatically! I can't seem to find anything that is causing this.
  • carlabunnell Nov 23, 2009
    I tried this but it did not help. What else might be wrong?
  • 150 Answers
You might want to check that the sensors mounted on the side of your garage are lined up .... Also you can check the garage opener itself, there is a screw usually in the back with a +/- .. by turning this screw you adjust where the garage door stops if it is set too far on the + side it might be opening because of this
Posted on Nov 14, 2009
Automatic Garage Door closes then Reopens and Won't Stay Closed
Check again to see if anything is blocking sensor(s).
May 23, 2016 | Building Materials
Where can i find a manual for craftman garge door?
Probably needs an adjustment. I would check Sears website as they have lots of info there for products they sell. An operators manual should give you this info.
Jul 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
When the door closes, it automatically reopens. There are no obstructions so that isn't the issue. If I disconnect the door and cycle the automatic is closes and then immediately reopens.
make sure that the auto matic reverse circuit light is being read correctly. they is a light extending a beam of infared light, you can't see it, to a reflector across the garage at the floor level at the garage opening. There should be an indicator light, usually green and red. Line up the light and reflector until the green light comes on.
Mar 08, 2011 | liftmaster Chamberlain Garage Door Opener...
Garage door loses travel settings after a day or two.Door closes then reopens after hitting the floor.I made the proper travel adjustments on the side of the unit then after 1 or 2 days the door hits the...
I have been having almost the same problem. My up limit setting is changing. I intend to replace the limit switch assembly. I know of nothing else that can cause this problem.
Dec 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have Craftsman ½ HP Garage Door Opener Model 139.18458D. It reopens immediately after closing. Sometimes it works normally, and sometimes gives this problem. I have tried adjusting the close force,...
It sounds like the door is traveling too far in the down direction. When it hits the floor the safety causes it to reverse to the open position. You need to adjust the 'down limit' not the force.
Sep 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
This is cause when there is something blocking one of the sensors. Look on each side of your garage door near the concrete when the door is closed and you will see small sensors that are facing each other.. Make sure they are not misaligned and that nothing is in front of them.
Dec 04, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Home Fencing Logo
143 people viewed this question
Top Home Fencing Experts
 Russ Hill
Russ Hill
Tom Chichester
ray gallant
Are you a Home Fencing Expert? Answer questions, earn points and help others
