Question about Optoma HD7100 Multimedia Projector
Optoma projector says HDMI out of display range.
  • 2,237 Answers
Make sure the resolution matches the source.
Posted on Nov 16, 2009
  • John Dwyer
    John Dwyer Jul 29, 2014
    has any one have an idea what to do with my crap optoma HD20 as it say out of rang i had tryed making the 1.4 v hdmi lead 1 mt still say the same thing but it set up 4.3 mt with a built in booster the picture come on and then of and say {out of range }
4 Suggested Answers
rickbrashear
  • 176 Answers
SOURCE: Projector powers up as normal, bulb comes on,
There is a source lock and source button I would unlock source lock button and the push source button until you get to your hdmi input you are using. You also may just plug in one input first and once you get the input right play with the multiple hdmis
Posted on Aug 11, 2011
realbat2
  • 68 Answers
SOURCE: Optoma Projector Only Displays White Screen
did u use your function key on your laptop?or did u configure your graphic card so that the output of your computer can be recognise by your projector?or do you try to use your contrast or brightness control at your projector?
Posted on May 12, 2009
  • 8909 Answers
SOURCE: we are using windows 7
Probably FN and F5 key or whichever key controls your display routing.
Posted on Mar 07, 2011
Watch TV (Vizio smart Tv)with my projector (Optoma ML 500)
you cant connect a projector to the hdmi on a tv,you have to connect the cable box to the projector
Jul 03, 2015 | Vizio Razor Led M650vse - 65 Class 64.53...
Sound issues when connected to PS3 with HDMI
I don't think you can hook a PS3 to 350W projector. You are maxing out the PS3 output. Good luck with it
May 03, 2014 | Optoma PRO350W Projector
Optoma hd65- componant signal OK but no hdmi signal found
whats the reason for no display on hdmi to hdmi connection- to the x box display is fine-?
Jun 25, 2012 | Optoma HD65 DLP Projector
Projector powers up as normal, bulb comes on, displays Optoma logo on screen and menu will show on screen. The issue is that although I have 3 devices plugged into the HDMI port of the device using a HDMI...
Aug 11, 2011 | Optoma HD20 DLP Projector
I need a cable to connect a Macbook Pro OSX 10.6.6 to an Optoma EX540 DLP projection display machine. What do I use?
According to this site:-
http://www.projectorreviews.com/optoma/ex540/specifications-id2350.php
You could use a HDMI cable, do you have a HDMI output on your laptop?
It also mentions that the projector has Component, S-Video, Component compatibility.
If you don't have a HDMI output on your PC, you may well have one of these.
It also mentions a wired networking capability so a standard RJ45 cable should do.
and if you download the projector spec sheet .pdf file from this web site, it also mentions a wireless capability, you may not need a cable at all.
Apr 14, 2011 | Computers & Internet
Hi i want to connect a tv to my optoma hd 66 projector
hi,
You can't be able to connect a tv to your projector, because it doesn't have a monitor out.
There is only one way. If the source is a DVD player then connect the its HDMI output to the projector and the component video out to the tv. You can't be able to get video out from the composite video output of your DVD player, when you are using HDMI. When plug the HDMI it will switch off the composite video out. The component video out remain ON whether you connect HDMI or not.
ok
Mar 31, 2011 | Optoma HD72 Multimedia Projector
I just got a new Optoma HD20 and only after 1day of use it is not showing HDMI signal, although it is showing VGA signal. Why is this?
Hi miracles4all: I solved HDMI signal issue in my Optoma HD20. In my case it was the lack of contact between the HDMI cable plug male ending and the Optoma HD20 HDMI female port. My 35ft cable plug male HDMI ending was not completely "seating" in the Optoma HD20 HDMI female port. I solved the problem by purchasing a HDMI female to female coupler and adding a 3ft HDMI cable that had a slim male ending. This 3ft HDMI extension cable made better contact to the Optoma HDMI port and the projector was immediately able to detect HDMI signal. Hope this helps you... kaufmanekpr
Nov 05, 2010 | Optoma HD20 DLP Projector
I have an optoma HD20 and it connects using a 1.5m HDMI but as soon as i try a 10m HDMI connection (even with a booster it does not connect) any suggestions welcomed?
Hi kgomer782 I have similar issue. My optoma hd20 signal connection with a 3/6ft hdmi cable is perfect. However, no signal is detected when connected to a 35ft hdmi 1.4 cable. The 35ft cable is indeed working becuase I tested it succesfully when connected to a 1080p HDTV. Did you received any solution to your problem? I wonder if it has anything to do with the HD20 design of the "debossed" hdmi ports that prevents the cable plug from getting completely "seated" in the port? My 35ft cable has a flat square male ending however, the 3/6ft cables have slim male ending that seems to accomodate perfectly in the Optoma's hdmi port design...kaufmanekpr
Aug 07, 2010 | Optoma HD20 DLP Projector
My projector optoma ep719 has a blue screen went turn on with or without cumputer hook up
please check the signal and the display properties as per SVGA or XGA resolution
Jul 16, 2009 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma HD7100 Multimedia Projector Logo
1,984 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
