Question about Saeco Magic De Luxe Espresso Machine
How do I lubricate the brew unit? I understand
How do I lubricate the brew unit? I understand that this should be done every 500 cups or so.
  • 1,089 Answers
Hi
Send me an e-amil and I will send you instructions with pics.
Posted on Nov 13, 2009
"brew unit block" medium cup in service mode dont work only the small cup works
When the alert came up- Brew unit blocked- this is before you started taking things apart, A, were you able to remove brew unit, Yes or No?
B, after turning power on and then off, Did the machine try to reset brew unit to home position Yes or no?
If Yes were you able to remove brew unit?
Aug 18, 2014 | Miele CVA615 Espresso Machine
Why are the used grinding pads on my saeco odeo giro very loose and watery
I can personally confirm this fix from another similar question works: "I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough, it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount." My manual didn't have very good info about lubricating the brew group, so I referred to some Youtube videos demonstrating the methods. A sourced a 3rd party food safe lubricant from Amazon which I applied with Q-tips, but in retrospect they also sell Saeco "maintenance kits" which would have been cheaper & easier to apply, plus it includes a new O-ring.
Jun 01, 2014 | Saeco Odea-Giro Espresso Machine
Leak whenever I make a cup of coffee
Please consider the following:
1. Descaling (Machine should be descaled every after 3 months, every 500 brews, every time the machine prompts you to do so..(whichever comes first)..)
2. Lubricate the brew unit / Clean the brew unit with running water
3. Run hot water through the nozzle / Run how water only through the spout (to check clogs)
~ if above mentioned are no good, contact the customer service for the nearest ASC
Oct 15, 2012 | Saeco Magic De Luxe Espresso Machine
Gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
The brew unit is not tamping the ground coffe properly.
Give the brew unit a good wash,then lube all the moving parts with food grade grease.
If you are able dismantle the brew unit and wash in warm soapy water,this removes coffee and any old lubricant.
Feb 21, 2010 | Gaggia Titanium Espresso Machine
Xcc-12 gevalia coffee pot wont brew.
Thermal link open. Located in base of unit mounted against the warming pad heating unit.
Oct 28, 2009 | Gevalia CM-500 12 Cup Coffee Maker
Unit will not brew when pod is inserted; works w/o pod however.
This may be one of two issues:
1. The pump is malfunctioning which can cause the internal reservior to not completely fill which causes issues during brewing. My unit dribbled random amounts of water instead of brewing for about a week before the pump died completely.
2. The puncture seal isn't in the right position. Open the Keurig fully so you can see the sharp puncture pin. Very Carefully push the black rubber gasket around it all the way up. Then pull it back down about 1/16". Brew a cup, if the problem continues, try sliding the gasket further down by increments of 1/32".
May 29, 2009 | Keurig Ultra In Home Single Cup Brewer...
Coffee takes forever to brew
normally when that hapen is the coffee is grinded to fine water has trouble filtering thrue it try corser one and coffee filter pierre
Feb 14, 2009 | Gevalia CM-500 12 Cup Coffee Maker
Saeco Magic De Luxe Espresso Machine Logo
268 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
