Question about Samsung WEP200 Headset
Earpiece attachment It does not want to stay hooked on the main piece.  Very difficult to get on; is there an alternative one that will hook on more securely?
  • 2 more comments
  • Baby J Feb 20, 2008
    I have a problem with my earpiece. It seems to keep falling out of my ear. I want to know how can i adjust it to make it stay in my ear?
  • gsachin20 Dec 05, 2008
    I just bought this bluetooth earphone but I am not able to figure out how it would just sty inside the ar without being loose and falling off
  • Anonymous Dec 13, 2008
    my ear piece clip broke from taking it off to charge how do i get a new one
  • Anonymous Dec 29, 2008
    earpiece often falls out, how do I solve this?
  • 92 Answers
Sir or mam
this is not technical problem
Posted on Jan 16, 2008
What happens when you hook a care battery up backwards?
Hello Glen, Bad bad things can happen when you hook up a car battery backwards. If your car has a high quality electrical system it might only blow out one or two main fuses. If not, it can cause havoc on the wiring system and burn out the alternator, computer, sensors, modules, and stereo system to name a few.
Jul 08, 2014 | 1996 Geo Prizm
Sharp r520kst door wont stay shut
If the door will not stay closed it is the spring inside door, or the small plastic piece that holds the spring which is attached to the $80.00 piece called outer door.
To fix it, it is EASY and you do not have to even take the inside cover all the way off. Just remove the three sides of cover by gently slipping a plastic putty knife around rim to release the clips. Then attach the spring to the small hole below where the plastic piece used to be, which is located in the metal on the glass frame piece, use tweezers, hold the other end of spring as you place spring onto plastic door latch and set into place!
Snap the inside cover back on and YAY! FINI!
Mar 23, 2013 | Sharp R-520KST Countertop Microwave Oven...
Door won't stay shut, microwave will not start
Contact the maker or Google the model number for "parts"
That part likely will require the unit to be taken apart to replace it.
Jun 16, 2012 | Jenn-Air Microwave Ovens
My microphone is not working. When i call anyone i can hear voice from other side bt they can't hear my voice. Plz tell me wat to do.
The first alternative i can ask you to use is the external earpiece that is attached to the earpiece port of the phone.
Then you can replace the mouth piece by turning off the phone, removing the battery cover, the battery and the sim, then you use a flat object like a knife or credit to split the phone open from the lining that is by the side of the phone, then you will see some screws by the edge of the phone, unscrew them and you will have access to the main board and the mouth piece, then you can disconnect the mouthpiece and replace it with a new one that you must have gotten for it.
After doing that, then you can reverse the process to reassemble the phone back together and your phone will be in good conditions once again.
Take care
Oct 09, 2010 | Nokia 3120 Cellular Phone
Passenger side exterior mirror is dangling by power cord.
is the part the spring has to be attached to removalable , from inside of door?may be able to take that piece off and reattach spring when not under tension , i don't know this vehicle very well but most side mirror's do attach this way , hope this is helpful
Jun 08, 2017 | 1996 Chevrolet Cavalier
My Kenmore Elite freezer door came off one of its hinges. I cannot figure out how to put it back on so that it stays. The connection has an upper hook with a lower hinged arm. It is strange.
I just spent the better part of an hour on this. There is a white flange with two phillips screws. If you take this off it is easier to see the mechanism, but you may be able to get it back on without removing the flange. I removed the flange. The mechanism attached to the door has a hook facing up and a smaller hook facing down. There is a hinged metal bar below this. The bar has a hinged piece with a loop on it. Pull the loop up. Now push down on the piece with the hooks ( it has a spring) and hook the smaller hook on the loop. Do this for both sides. Now the door should slide easily into the slots. Once in the slots, push down on the hook piece and release the loop. Push the loop back in place along the bar. Hopefully this does the trick for you, it did for me.
Oct 06, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My psp umd door wont close properly, what is the problem
maybe something on the inside is moved because ive openened a psp before and the thing in the back of the screen is like a hook that holds the screen shut. or maybe the little thing in your umd door that holds that little closing thing broke off. u can solve this also by hacking your psp and running the games trough the M33 driver. =D
Apr 19, 2009 | Sony PlayStation Portable (PSP) Console
Bluetooth repair
i have a blue tooth motorola h350 and it just quit working it's under a year old can you get me the 800 number so i can get it replaced
Dec 10, 2007 | T-Mobile 81339TMIN T?•MOBILE BLUETOOTH...
Jabra ear piece
Call the Jabra Support hot line they will send you replacement earhooks free
Takes less then 5 mins to get them sent
Sep 30, 2007 | Jabra Bluetooth Headset with Adjustable...
Samsung WEP200 Headset Logo
51 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
