Question about Magnum DeltaForce CB Radio
Blew up burned two or maybe more transistor
  • 1 more comment
  • drbonbon Nov 14, 2009
    sorry bout the lousy explanation this radio should be pumping 200 watts but one night it just went out then back on and I was missing 12watts now nobody can get the transistors around here or wanna touch this radio is there something I missed
    am not good at typing was missing 120 watts ty
  • yadayada
    yadayada May 11, 2010
    u mean it actually exploded??
    Champion:
  • 219 Answers
Check your radio power source, sounds like something is making a connection that shouldn't. Or give us more info on what its doing.
Posted on Nov 21, 2009
Determine if an analog receiver has blown a channel
When you need to replace the output transistors, do them both at the same time with a matched pair. That way you won't unbalance the power supply and will be assured of the same power out is available on both channels.
Feb 18, 2016 | Sansui Audio Players & Recorders
ALPINE MRV-T757, BRIDGED AND BLOWN
The problem is that the driver circuit is also damaged. Try powering up the unit with the output transistors disconnected. Measure each pad and report the results here. You should see something like 0.6,B+,0.0 on each set of three. Some will be negative rather than + (-0.6,B-, 0.0).
Keep us posted.
Dan
Jul 03, 2008 | Car Audio & Video
MY RADIO BLEW UP ONE OF ITS TRANSISTOR B..something please help me to know the other digits for thew repair
Transistors have their type written on them in very small print.
Look at the transistor that is faulty and read off the number printed on it.
Dec 19, 2013 | Philips AZ2555 CD Boombox
I have a Pmp5000 889406987784 Eurowpower PMP5000 1200-Watt 20-Channel Mixer and Speaker Output A has no output. What has happened?
Usual problem is the Channel A amplifier has burned and blown the switching transistors. Usually an internal board arc occurs and unless very skilled at board work of clearing the burned area and replacing the components you are better to replace the HCA2400 amplifier module... about $160
Sep 19, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Quiet Galaxy DX 44V
Sounds like you have lost a final or a driver transistor if so a shop or reputable repairman is your best answer. You should also have him check your cables and SWR on your antenna system as well as check for loose grounds. Sounds like you had a high SWR and blew out a final transistor. But it could be as simple as a loose component or cold solder joint in the radio. Get professional help.
Jul 28, 2010 | Galaxy Radios DX-44V 40-Channels Base CB...
Tech tips toshiba burns fuse
If F801 blew off then check standby power supply section and if F860 blew off on pressing power button then check inverter transistor (power out) on power supply board.
Sep 17, 2009 | Toshiba 42H81 42" Rear Projection...
No pic on the screen,the set blew up and i replace the capitors and all the burn styy yet its turn on and no pic
If you change the capacitor...Did you clean the oil of the capacitor from its surrounding area, because due to oil it could short the components, Check first Filament is lighten-up ? If yes then check ABL Voltages, if filament voltages not present check horizontal out put transistor. and check also safty resistances in surrounding area of H OUT Transistor.
Hope this will solve the problem.
Thanks for using fixya.
Jul 24, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
No Output + Burned Transistor and something else...
Depending on which circuit the IRFP064N/mosfet was in then you either have a blown output section and you will need to look at the other mosfet's that work with the one you replaced or if it is in the power supply area then you will need to check the other mosfet's that work with it in the power supply. Of course you will have to test all the driving circuitry that is associated with either output or power supply, which ever is involved and be sure that the driving voltages are correct. Of course, in the power supply it would be a high frequency square wave of about 50% duty cycle. A schematic would probably be of great help. Good luck.
Mar 23, 2007 | Concept CC-452 Car Audio Amplifier
Radio Communications Logo
Top Magnum Radio Communications Experts
AnyMHz.com
AnyMHz.com
John Porter
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
