Question about Kenmore Elite 45986 Front Load Washer
I close door, select wash, door clicks locked but water does not start running in the area where you put product. It just makes a clicking type sound. HELP?
  • Kenmore Master
  • 5,568 Answers
The clicking sound you here is an electrically control valve assembly that may have failed or is blocked by sand or other debris. You need to turn off the lines and remove both hoses from the back of the machine; have a pail ready so you can drop the disconnected hoses in to it to drain. Check for screens at the hose ends as well as where they attach to the machine to see if they are simply clogged with silt.
If not, the valve assembly (which is part of the fitting to which you attach the hoses) may need replacement.
Since it is a Kenmore brand, go to the Sears website, then their parts department and enter your complete model number. You should be able to view a line-drawing breakdown of your machine and find the part number for that inlet valve assembly. You can order it directly from that site or check with a Sears parts center if you have one nearby and pick it up there.
They are not difficult to replace and often held to the back panel with only two screws. They are also not expensive but be advised, it the problem is still present after replacement of the valve assembly, then is not getting the proper electrical control from the electronics and that will be far more costly to replace.
Good luck-
Posted on Nov 14, 2009
How to fix door on Samsung Washer model wf210anw. It makes 3 very hard clicks prior to starting.
Has the sound changed? The door lock assemble can be loud and sound like its faulty. If the washer completes cycles, then door lock is working correctly. One thing to check is the strike on the door. Look for anything that is odd or doesn't look right. A damaged strike can create extra noise. Good luck!
Jan 29, 2016 | Samsung WF210ANW 3.5 Cu. Ft. White Front...
I dont have a stop buttom
You're start/pause button should pause the cycle, cancell should completely cancell. After pressing the Start/Pause within a cycle, the door lock may require time to unlock as indicated by the lock light on the panel.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Will not start to fill with water
have you switched the water ON
Jan 25, 2014 | Washing Machines
The lid on my Cabrio washer will not lock. The washer starts the cycle with water running into the tub. But then the door will not lock. There is a click, click, click sound. And lights come on around...
There is likely to be a problem with either the lid solenoid/lock or the 'lid closed' sensor becoming apparent with the extra movement of starting a wash - requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
GE Washer, Model GBVH5140HWW. Door seal failed and water in washing machine leaked into the base of the washing machine. Removed the front panel, replaced the door seal, dried up the water in the machine...
The seal is likely not installed correctly. What is happening is the latch for the lock is trying to hook and it is being blocked so it doesn't actually lock. After so many tries the machine goes into an abort mode where it washes out all the water and stands by for it to be fixed. If you put some pressure on the door (closing it) while it is trying to lock, it likely will lock and then run. It is basically an adjustment issue. It is also possible that something with the lock mechanism is broken or out of adjustment causing the leaking to begin with and that is actually the area that needs attention rather than replacing the door seal. Door seals rarely fail unless they are physically damaged somehow.
Jun 02, 2011 | GE WSXH208A Front Load Washer
Frigidaire Front Load Washer Model LTF2140FS1. Put clothes in washer, fill detergent dispenser, close it, shut the door, set my cycle hit start then the door lock clicks, clicks again, panel shuts off....
Make sure that the switch for the door is closing properly at all times. If not, unit will not start up or will shut down while operating because the switch has opened.
Sep 12, 2017 | Washing Machines
Washer just makes clicking sound .Filled with water but won't run now just makes clicking sound.Tried all cycles it makes a little different click when I put it on drain/spin then selected no spin.but...
f the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 03, 2011 | Washing Machines
Won't run
yes at the bottom of washer remove panel shop vac water pump
Feb 01, 2010 | Samsung WF203ANW Front Load Washer
Wash cycle will not start
the door interlock is faulty, hit the door handle area with the palm of your hand, make sure machine is turned off 5 mins before hand. Replace door lock IRE bye.PS it should open when you hit it bye again. remember the palm of your hand
Nov 02, 2007 | Whirlpool GHW9200L Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
56 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
