Question about HP LaserJet 3380 All-In-One Printer
Replacing scanner assembly
How do i repalce the scanner the HP 3380
  • fncarter Apr 10, 2008
    I have a similar problem. At power on the scan mechanism hunts for home
    position until an error is noted on the control panel. There is more noise
    from the drive which started weeks ago. The noise seemed to be less as the lamp assembly traveled down the rail, but now it never leaves the pre scan area.
  • 186 Answers
Honestly it is cheaper to buy a new machine. This is a very common problem withthat model. If you are technically inclined you could try removing the top glass, (not easy) and cleaning all the mirrors as well as the scanner. Many times if the scanner cant find home (because the optics are dirty) it will give you a scanner error message. Also HP has had many issues with this model and the scanner, so you may want to try calling them and see if they will repair it under warranty.
Good luck.
John
Posted on Jan 09, 2008
6ya staff
SOURCE:
Why would my scanner not work on my laser jet 3380 all in one printer?
If you are getting scanner error it is time to clean the scanner assembly.To do so you are going to need proffesion help beacause the scanner can be damaged easy .This error is verry common for the HP all in one printers.If you need any futher help pls replay. Vote if that was helpfull.
Oct 27, 2010 | HP LaserJet 3380 All-In-One Printer
HP LASERJET 3380 SCANNER PROBLEM
It will cost more to have it fixed than to buy a new one,
Oct 23, 2009 | Sport & Outdoor - Others
Hp laserjet 3380 - MS Vista - scanner error, copying is ok
clear glass, replace ribbon scanner cable if no result - replace scanner
Aug 24, 2009 | HP LaserJet 3380 All-In-One Printer
HP laserjet 3380 needs fuser replaced
Unfortunately, the scanner assembly must come off. It's all screws and covers from then on.Try buying a service manual from eBay.
Mar 07, 2009 | HP LaserJet 3380 All-In-One Printer
Scanner Error - Power On > Power Off
Sounds like the scanner has died. Sometimes restarting can help out. If you can print try printing out the configuration page and let us know what the error codes are.
May 27, 2008 | HP LaserJet 3380 All-In-One Printer
Hp 3380 scanner issue
I SUGGEST DELEATING SCANNER FROM YOUR SYSTEM AND RELOADING THE SCANNER DRIVER FROM THE INSTALL DISC THAT CAME WITH YOUR SCANNER
Feb 02, 2008 | HP LaserJet 3380 All-In-One Printer
HP 3380
It needs a scanner assy.
Dec 05, 2007 | HP LaserJet 3380 All-In-One Printer
Set up scanner to notebook
If you are a MAC user You need to use the cd that came with the printer for mac and then it will work, otherwise it will only print, and the scanner won't work.
Oct 21, 2007 | HP LaserJet 3380 All-In-One Printer
HP LaserJet 3380 All-In-One Printer Logo
192 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
