Question about HTC P3470 Cellular Phone
USB reboot showed on my Moto cell phone screen. Now the phone is dead. Why?
How do I fix my Motorola Moto G after it has dropped into water?
if you immediate removed the battery and left it drying for a few days you had a chance. but now it is fried
Jun 21, 2015 | Motorola Mobility Moto G 8 GB Black...
Understand the numbers on my messaging screen
Can you tell me or show me what you are talking about?
Mark
Motorola Support
Sep 16, 2014 | Motorola Mobility GOOGLE 8GB MOTO G XT1032...
Motorola moto x
Tap the power button to wake it up. You may also press the volume button to wake the phone. Then you should be able to hide and show the keyboard.
Mark
Motorola Support
Sep 03, 2014 | Motorola Moto X XT1052 4G LTE 16GB...
My iPhone is flashing battery and beeping
I assume it is on the black screen with the empty battery. If it doesnt come up with the little lightning bolt to show it is charging then it is likely the cable or charger are dead. try laptop USB charging port instead. Note I have had faulty cables that would lock up each USB port tried until I rebooted. try a friends charging rig that you know works. Another thing to check, is pocket fluff in the charge port which may prevent you inserting charging cabel correctly.
Aug 04, 2014 | Apple Iphone 4s I Phone 4 S Factory...
My iphone doesnot turn on wben with the charger and with usb...it shows blank screen
Try holding the home button and the power button at the same time for at least 20 seconds. Does the phone reboot? If so, then your problem should be solved. If not, you may have a dead iPhone which is pretty rare. You can try schedule an appointment with the Apple Genius Bar at http://www.apple.com/retail/geniusbar or visit your local AT&T store to see if they can do anything for your phone.
Mar 02, 2011 | Apple iPhone 3G
Will not power "on", will not charge
Did the phone fall on water? Is the charger and USB cable still working properly? Notice that if the phone cannot charge, the battery will be dead and the phone cannot power on.
Check this out for more help http://deviceteck.com/blog/2017/06/11/phone-dead-revive-dead-phone
Jun 23, 2017 | Orange MOTO RAZR V3x GSM Mobile Phone...
My phone will not come on at all untill i plug it up, then it will only show a moto displaying blue screen bootloader usb
you need to turn off the phone then hold the pound and star keys and the power button untill that screen comes on again and then just turn it off and turn it on again the normal way and it should be fixed
Jan 02, 2009 | Motorola Mobility E815
Fell in the pool
the phone board is damaged it should be service or replaced
Dec 22, 2008 | Motorola Mobility RAZR V3
Not charging
either have bad battery or the plug in connection is loose or bad.
Oct 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Moto z3 problem
the usb port needs to be service then the phone needs to be unlocked and flash so take the phone to a mobile service center and have them fix it for you.
Aug 20, 2008 | Motorola Mobility RAZR V3i Cellular Phone
HTC P3470 Cellular Phone Logo
26 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
