Question about Compaq C3 1000 3 In One All-In-One Thermal Printer
Where can I buy the power supply/cord for c31000 printer
  • ckdalid Nov 14, 2009
    Am looking for the power supply pack. Or, perhaps a suitable or compatible replacement. I've check with ebay but found no match. not even at compaq.com
  • john regrut May 11, 2010
    is it a power card or the actual power supply pack?
  • 460 Answers
I need to know the dc voltage required to power the printer. but, you might have to find an adapter plug that goes into the printer. ive got a good sized collection of p.packs. here is my direct email addr. jregrutsr9304@gmail.com power packs are usually 12 -18 v. dc at 1000 milli. amp for printers talk at ya later
john
Posted on Nov 14, 2009
  • 685 Answers
You can go to ebay and get one for cheap.also you can check at wal mart or radio shack.but ebay would be the cheapiest
Posted on Nov 13, 2009
Power cord
Here is a replacement power cord for the printer mentioned. Just go to the attached link it's on Amazon for $12.00
Amazon com Super Power Supply AC DC Adapter Charger Cord for Canon Pixma...
Mar 17, 2016 | Canon Office Equipment & Supplies
Where can I find replacement power cord and adpater?
what country you need to state voltage that come out of power point - is it 120 volt or 240 volt because it has to match with power supply check with seller before buying anything and definately before plugging it into a power point .
. Try amazon see http://www.amazon.com/Adapter-Supply-Charger-Dell-Printer/dp/B00L1WTFCA/ref=sr_1_fkmr3_2?ie=UTF8&qid=1404525964&sr=8-2-fkmr3&keywords=DELL+AIO+V313+ac+power+supply or search in google with Dell AIO V313 ac power supply
Jul 04, 2014 | Dell V313w AllInOne InkJet Printer
My printer will not come on at all. i have the adapter in to the wall jack but nothing happens. i have checked to ensure the wall jack works.
Solution one: Make sure the electrical outlet works
Unplug the power cord from the electrical outlet.
Plug another appliance into the electrical outlet to make sure the outlet works.
If the electrical outlet does not work , plug the product into another outlet that does work.
If the electrical outlet works, but the product still does not turn on , continue to the next step.
Solution two: Make sure the power supply is compatible with the HP product
The term power supply refers to both the power module and the power cord.
NOTE: To make sure that your product and power supply are compatible, HP suggests you use the original power supply shipped with your product.
Example of a power module Example of a power cord
NOTE: The power module might have a permanently attached power cord, or the power cord might detach from the power module.
Make sure the voltage and amperage specifications printed on the power supply match the voltage and amperage specifications printed on the HP product.
Voltage and amperage specifications printed on the power supply Voltage and amperage requirements printed on the HP product
If the voltage and amperage specifications between the product and the power supply are compatible, make sure the connector on the power cord is the same shape and color as the connector on the HP product.
WARNING: Do not force a power cord into an HP product that is incompatible with the HP product (different shape or size).
If the power cord is not compatible with the product, replace the power cord with a compatible cord. To buy a compatible cord, right-click the following link, How to Buy HP , and then click Open in New Window .
If the power cord is compatible with the product, but the products still does not turn on, continue to the next step.
Solution three: Reset the power module and test the power
Step one: Reset the power module
The power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
Unplug the power supply from the rear of the product.
Unplug the power cord from the electrical outlet, power strip, or surge protector.
If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
Wait 15 seconds.
Reconnect the power cord to the power module.
Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
Check to see if the power module has an LED.
If the power module does not have an LED, continue to the next step.
If the power module has an LED, check to see if the LED lights up.
If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
If the LED lights up, continue to the next step.
Step two: Test the power on the All-in-One
Follow these steps to test the power on the product.
Reconnect the power supply to the rear of the product.
Press and quickly release the Power button to start a Power On/Off cycle. Do not hold the button down.
Figure 1: Press and quickly release the Power button
If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button again.
If these steps resolved the issue , there is no need to continue troubleshooting.
If the issue persists , see the next step.
Solution four: Test the power with a compatible power cord from a different product
If you have another available power cord that is compatible with your product, use the alternate cord to repeat the steps in Solution three: Reset the power module and test the power .
If the product turns on with the alternate power cord, the original power cord caused the issue. Contact HP to replace the power cord. Right-click the following link, How to Buy HP , to buy a compatible power cord.
If the product does not turn on with the alternate power cord, continue to the next step.
Solution five: Service the HP product
If you have completed all the preceding steps and are still experiencing a problem, service the product.
Mar 26, 2011 | HP PSC 750 All-In-One InkJet Printer
I have an HP Officejet 6500 Wireless All-in-One Inkjet Printer. As I was trying to print something, it just shut off, and I cannot get it to turn back on. Help!
Check the power-supply.
If it has a separate power "brick", take a multimeter, and check the output voltage/amperage.
If it just has a "plain" power-cord between the wall-outlet and the printer, then the power-supply "inside" the printer has failed.
It might be cheaper to buy a replacement printer than it would be to hire a qualified technician to trouble-shoot, find/buy a replacement power-supply, reassemble, and test.
May 13, 2010 | HP Officejet 6500 Wireless All-in-One...
I need to order a power cord for my hp psc750
Regarding on your problem you can buy a power cord in any hardware supply in your place or any computer shop in your place. Make sure that when you buy the power cord make sure that it is fit in your device.
Thanks
Sep 08, 2009 | HP PSC 750 All-In-One InkJet Printer
I have misplaced the power cord for my x1200 model printer
You may check on ebay for a power pack, otherwise you'll have to buy one from Lexmark or someone who sells Lexmark supplies.
Jul 27, 2009 | Lexmark PrinTrio X75 Printer
I need to know what the power supply cord is called and if i can buy a new one? my printer is a hp psc 1410 all in one
It is called a power supply cord. On the back of the printer it might til you the appropriate volts and mAmp you will need. You can probably buy a new one from HP, but you can certainly find used ones as well and probably less expensive. Try this website Printerfixer.net
If the power supply cord is not listed on their website send them an email to see if they have a power cord for your printer model.
Nov 14, 2008 | HP Office Equipment & Supplies
Lost cord
hi,
you can try looking at thrift stores, usually they have a "cord wall" or cord bin, that lexmark I believe has the power supply that kind of fits into the back of the printer so it should be easy to spot, but when you look at the power suppliy make sure it says lexmark on it before you buy it,
just an idea
J
Jul 29, 2008 | Lexmark X1240 All-In-One InkJet Printer
Usb cord
Each printer comes with power supply cord, install CD and user manual!!! USB cable must buy!!!
Jan 22, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Compaq C3 1000 3 In One All-In-One Thermal Printer Logo
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Greg Cann
Greg Cann
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
