Question about Linksys Wireless-G Broadband Router
My computer wont connect with my router. It says "The Platform Service is not running" and "Error 227" All my other computers work, but this one wont. It shows there's no networks to connect to. I just got a new usb adapter for it, but it still wont connect! How do I fix this?
  • 557 Answers
Start - Run - services.msc - OK
Check to see if DCHP client is set to automatic and is started. On the dependency tab you can see what other services need to be checked.
Posted on Nov 14, 2009
Error 321
You get this error when you try to install the router using the CD.
This error shows that your computer is not connected to the router or the connection between the router and the computer is not working. When you run the CD , it will ask you to connect the computer and the modem to the router with the cable. You will see all the lights lit up on the router according to the instructions but still you will get error 321.
In this case you will need to check the firewall settings of the computer. If there is any firewall installed on the computer, then turn it OFF. Make sure that the Local area connection on the computer is not Disabled. The local area connection should not have any static IP address assigned. If there is any then set the IP address to automatic.
Try to run the CD again and see if that works. If that doesn't work then try to setup your router without the CD. You can setup your router manually.
from http://fixhomenetwork.com/blog/error-321-router-setup/
For help in setting up router without the cd go to:
http://fixhomenetwork.com/router-set-up.php
May 18, 2011 | Linksys WRT120N Router
I have a Belkin router F5D8236-4 v2. I got an error message "Platform Service is not running" Error code 277. I have no idea how to fix it, have just rebooted puter a couple of times.
You can reset the router and reconfigure the router Open IE Type 192.168.2.1 For Login leave the box blank and hit submit Towards extreme left side you can find an option called restore Factory default Click on it Restore Defaults> Ok (for discalimers) Then Click on connection type(towared the left side)>dynamic>your computer name>click 'SUBMIT' Click on MAC address> Click 'CLONE' Then Turn off both modem and Router Wait for 15sec and then Turn only Modem and wait for all the lights are steady then turn on the router ____________________________________________________ If you installed Belkin Router Monitor then, Uninstall the software and reinstall it.
Hope it will fix this Issue
Dec 08, 2010 | Belkin (F5D7230-4) Router (587009)
Cannot access the internet
I have looked at and reviewed your problem with your HP laptop DV6700Z and have the fallowing for you to aces.
First, if you are trying to access the internet via wireless, wait until you have established and wired connection.
If the blue light comes on in the front panel, the wireless is working, if not, you have a problem with the wireless modem.
Run a wire from your laptop to your modem and enter your my network, choose setup a internet connection.
Try to make a internet connection. Once you have established a connection, you can setup your wireless connection.
Hope this has helped you.
Sep 28, 2009 | HP Pavilion DV6700Z Notebook
I can't open Linky's easylink advisor(LELA). I have 2 error messages. One says object reference not set to an instance of an object, and the other error says cannot find platform service. Make sure service...
You don't really need the LELA. It is simply a wizard which guides you through the setup process, but you can always access your router's web interface through http://192.168.1.1 and configure your router from there.
On a side note: I get questions about the "setup-CD" a lot and my answer always is: throw the CD away or put it aside. Set up your router by hand studying the manual and if something goes wrong down the road, you know how to fix it. (If you don't have a manual, you can download it from here. Look underneath your router to find the version number or click the little "?" on the web page.)
If you can connect your main computer to the router with an Ethernet cable, then I would always prefer that to a wireless connection. It is safer but moreover faster (100 Mbps vs. 54 Mbps = almost twice as fast.)
You can also additionally enable the wireless option on this computer, but that is not really necessary. (I do it though...;-)
Well, I hope this helps, but if you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 11, 2009 | Linksys Wireless-G WRT54G Router
Belkin G Wireless router not connecting to net
Did you save the IP addresses ?You may have to configure the router manualy go to your network ,settings or type in run box IP config and see whats going on
Dec 27, 2008 | Belkin (F5D7230-4) Router (587009)
G router wont work through vista or satellite dish
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix and use supportcall as your promo code for 1 free technical support.
Jun 01, 2008 | Belkin (F5D7230-4) Router (587009)
Internet wont work
hello!
May 08, 2008 | D-Link AirPlus DI-524 Wireless Router
Belkin F5D8630 wont take my new log in details
check to see if all of the ssid's are all the same or if there is another wireless system interfering.
Sep 11, 2007 | Belkin (A3L85014BLS24)
Linksys Wireless-G Broadband Router Logo
1,796 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
