Question about Toshiba E-STUDIO 650 Copier
How do you put in the staples for SHARP copier ID# 54107166?
My printer ran out of staples and I need instructions on how to load more staples in it
The staples are specific to your copier. You can purchase them from Skelton Business Equipment 281-351-5128.
Here is a video on how to install staples into your copier.
How to Replace Staples in Sharp multifunctional printer internal...
Apr 25, 2013 | Sharp Mx-3501n Color Copier Printer...
Replace staples Sharp MX-M363U
It depends on if you have an internal or external stapler. Staples are specific to your model and finisher. They can be purchased from Skelton Business Equipment 281-351-5128
here is a video for the internal finisher staples:
https://www.youtube.com/watch?v=rnppPLFNlzI
here is a video for the external finisher staples:
https://www.youtube.com/watch?v=FS8l2FxzqOs
Hope this helps.
Skelton Business Equipment Houston Copiers
Apr 16, 2013 | Sharp Mx-M363u mx-M363u
Our copier ran out of staples, where do i put more in
STAPLES WILL GO IN THE FINISHER UNIT.OPEN THE COVER AND REMOVE THE STAPLE UNIT AND PUT NEW STAPLE PINS
Jan 07, 2011 | Sharp AR-M350U Copier
Which toner cartridge do I need? Where can I buy one?
The Sharp AL1631 takes a Sharp AL 100TD cartridge (hi-yield), or a Sharp AL 110TD cartridge (standard yield). IBS still has them, there phone number is 800-8810226.
Mar 12, 2010 | Sharp AL 1631 Copier
Cant staple from driver but can staple directly from the machines panel ... particularly 8x14
Most Likely the issue is resolved by configuring the driver properly. If you right click the printer under Printers and faxes in your start menu you need to go to properties, then to the configuration tab and then to Auto Configuration. it will then communicate with the printer and find out what options are installed and then enable you to use stapling from your computer. Make sure to select where the hands are pointing also. thanks. you will understand.
May 15, 2009 | Sharp MX-3501N All-In-One Printer
Sharp copy/printer to staple Crystal Reports
this should be an option in your print driver make sure when you set up the print driver you added the accessories ie. a finisher
Mar 26, 2008 | Sharp AR-M550N Copier
SHARP STAPLES
For the AR-M335U/455U-they are AR-SC2,5000 staples                            AR-M550U/700U,N-they are AR_SC11 staples                     They are a box of three. Hope this helps
Oct 17, 2007 | Office Equipment & Supplies
Need to know were to reload the staples
you check the staple unit and staple pin and staple contro pwb
May 07, 2007 | Sharp SF 2020 Copier
201 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
