Question about ATSI Holdings Cognitive Blaster Advantage Thermal Printer (P/N BT422003-013)
We have a BD24200-012 that shows the green power light, however the "ready" light flickers and then stays red. Any suggestions
  • wbgeorgia Nov 18, 2009
    Thanks so much. You have been a great help.
  • ATSI Holdings Master
  • 19,396 Answers
Hi.
Ensure that you are using original ribbons from ATS. Paper ribbons have marks at the back, and this printer will get stuck using non original ones, even if they have same size.
Ensure that ribbon has been placed on roller in the proper way and following right orientation.
Ensure that the first label in the ribbon had been inserted on the holder at the front of the printer in the right way, test ejecting one label.
Test using a different data cable (USB). If possible test the printer on a different computer.
Try disconnecting the power adapter from printer for one minutes to reset the printer, also restart the computer.
Try uninstalling and reinstalling the printer software. Start software installation with printer USB cable not connected.
If still no luck, then the printer may be faulty. Call manufacturer at the number listed on the owner manual, or on the site below, to get further instructions, or to have the printer replaced.
See also: COGNITIVE SOLUTIONS.
Regards.
Posted on Nov 18, 2009
  • 3,741 Answers
Check whether the paper roller in the thermal printer is properly adjusted .also check if there is enough paper roller in the printer or it is got empty.also if there is proper paper and properly adjusted.then its a problem in fuser assembly.which actually gets heated.if the assembly gets faulty it will not get heated.so it needs replacement.get it replaced by any local printer repair shop.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
  • charlymonty Nov 18, 2009
    thanks for keeping updated.please do rate the solution posiotively if helped.
    President:
  • 2,777 Answers
Does the unit turn on and operate without issue?
Thanks
Tim
Posted on Nov 16, 2009
My sharp tv wont stay on, it flashes green
Hi i have seen this before sharp hdtv's are known for having the internal power supply go faulty
Feb 01, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
My whole screen is green and the blue and red projectors flicker but the green one stays on
Your TV is showing to be DLP which means Bad Light Engine optical unit Try UED for part TS-COP5A
1-800-648-6657
Dec 03, 2009 | JVC HD-61Z575 61" Rear Projection...
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Monitor light flickers on orange never goes to green.
Sir,
You are suggested to check if you serial cable is in fine condition and it properly pluged into the Monitor and VGA. and do also try changing the serial cable .
Aug 30, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Akai dlp
i have a similar tv, with 5 blinking red lights on the power off. is that a power board issue? (I see the small green light ionside the tv, flashing green.,,) the outer light stays red or flashed red when i power off. i replaced the fuses, still same issue.
Mar 18, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Philips 30PF9946 D/37
You have sound but no picture. Green power light is on and NOT flashing. You get a screen flash or flicker on power-up or even a minute of screen before going all black. It is your inverter board. Common problem on LCDs (maybe more so on Phillips?). They are easy to replace (unplug-plug) and are available on the net.
Veritas
Feb 24, 2008 | Philips 30PF9946 30 in. HD-Ready Plasma...
Will not stay on
Hi, this printer needs a repair, which unfortunately will cost more than the printer is worth. I agree with HP
Oct 28, 2007 | HP PhotoSmart 7660 InkJet Printer
ATSI Holdings Cognitive Blaster Advantage Thermal Printer (P/N BT422003-013) Logo
47 people viewed this question
Top ATSI Holdings Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an ATSI Holdings Office Equipment and Supply Expert? Answer questions, earn points and help others
