Question about Canon PIXMA iP3000 InkJet Photo Printer
When I send my Word 2007 document to my Canon PIXMA IP3000 printer it won't print from the cassette tray but wants to default to the hand feed. When I run a printer test page it works fine. When I first print the Word document to Adobe PDF format and then print the PDF it again works fine. It would be much more convenient to print from Word instead of having to go thru Adobe. Can you help?
  • 863 Answers
Go on Canon web site and look for updated drivers for your operating system.  Also get updated drivers for your word 07 by clicking on check for updates in one of the top tabs when you got Word open.
Posted on Nov 13, 2009
Error code while trying to print
Slap the printer with your right hand from the right side of the printer.This process always solves the problem. I did, it worked
Apr 01, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Starts to feed paper and then stops and says it is jammed, it's not.
We have become aware of an incompatibility between the ZoomAlbum software and the Canon PIXMA printers listed below. This issue applies only when using the ZoomAlbum software to print Photo Album covers with Mac OS X.
Affected Models
PIXMA MP240, MP250, MP480, MP490, MP560, MP620, MP640, MP980, MP990, MX320, MX330, MX860, iP3600, iP4600, iP4700 Printers
Phenomenon
The affected PIXMA printers are designed to feed paper via the rear tray with a center-feed mechanism and two paper guides. However, the ZoomAlbum software was intended to feed paper from the rear tray in printers with a right-feed mechanism and a single paper guide. As a result, when using the ZoomAlbum software with Mac OS X to print Photo Album covers with the affected Canon PIXMA printers, the printed image may shift.
adv_zoomalbum_1.jpg Countermeasure
To remedy this problem, please use the following settings when printing Photo Album covers with Mac OS X:
1. Click System Preferences
2. Click Print & Fax
3. Select your Canon PIXMA printer as the default printer
4. Select DL Envelope for Default Paper Size in Page Setup
Note: Be sure to change the Default Paper Size back to Letter after printing the cover.
Jan 26, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I cant get the machine to grab the paper and it says its out of paper, yet its not out of paper.
Hi, the Ip3000 has 3 different feeding trays...
make sure that the printer is trying to "grab" the paper in the tray that you have chosen to use in the printer properties box...
when you give the print command can you see the rubber roller moving to grab the paper in the top feeder tray???
if the roller that feeds the printer is not moving you may have accidentally changed the settings to grab paper from the bottom tray...the one right under the door that opens to let printed pages out of the printer...
the 3rd feeder tray is the DVD/CD printing tray...
I suggest that you look at the printer Properties for remedial action...
hope this helps you with your problem...
cheers
haitchhcee
p.s.
suggest you place paper in the bottom tray before making adjustments to see if it is trying to grab the paper from there...
Dec 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My printer keeps printing from rear tray when i want it to print from the cassette. all settings for the print are set to cassette printing, and yet it still insists on trying to print from the rear. It is...
Most of those have a button marked feed switch and a picture with a LED that either shows rear or bottom tray. You need to select the right tray on the printer panel.
Oct 30, 2009 | Canon PIXMA MP540 All-In-One InkJet...
Canon pixma ip 3000 error message printer is offline
If the orange lamp blinking only it's the print head is not installed, or it is not properly installed.Open the cover remove the print cartridges then remove the print head and put back it on.If not help the print head is defective and need replace.
If the orange lamp blinking with green alternately it's ASF (cam) sensor error.The problem is in sheet feed unit.
Oct 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
FRONT PAPER FEED
Go to this site. In the search window in the center of the screen, type "paper tray" and click on the Search button. Select the link "How do I load the paper". When the document comes up, select the link "Cassette" near the top. You will see illustrated step-by-step instructions. If you are missing the cassette tray, contact Canon.
Feb 05, 2009 | Canon PIXMA MX850 Multifunction Printer
Pixma ip 3000
I think that if you use the bottom tray to load the paper, you can use the different sizes of paper to print. Make sure to click the second button inside the lid that shows the direction the paper is fed into the printer. hope this helps!
Jan 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Paper goes in squint drags to one side and jams
In my experience the usual reason for this is something (obstruction) in the paper feed. Make sure you have a really good look right down inside the paper path as quite small objects will stop a correct feed. The fact that it is one side makes me thing something is in there. I have serviced printers before with coins, paperclips etc that have found a way in.
Nov 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma ip3000 paper feed jam
try cleaning the rollers with alcohol, the tires are probably dirty and one side is not gripping the paper.
Jun 19, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Paper Feed
The problems are particularly frustrating if it's a Word 2007 document that you're trying to print. Open the document, go to the Page Layout tab, select Page Set Up > Paper and set your printer source to whichever tray you want. Apply to the whole document and voila !
Apr 08, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
124 people viewed this question
old marine
old marine
