Question about Smart Modular SV3170A
How to adjust the color ? Just brought this Monitor today..
Press the 1st button on the monitor. then press the 2nd button 2 times. then press 3rd button. then press 2nd button as many times u want to go through options
Posted on Aug 23, 2010
  • 43 Answers
1.Check if the Brightness or contrast control is at the appropriate position, not at the maximum or minimum.
2.Check if the specified voltage is applied
3.Check if the signal timing of the computer system is within the specification of the monitor.
4.Especially, check the horizontal frequency.
hope this can help
with regards,
JABEMS
Posted on Nov 14, 2009
I was using my laptop and left it for a while, when i came back to it again and brought it out of sleep mode my display was distorted and every place it was a light color or white was now a bright pink. I...
It is probably your the laptop monitor since hooking up an external monitor works fine. You could try reloading or updating the driver to your laptop monitor
Jan 07, 2011 | Computers & Internet
I am having issues with my monitor. My computer monitor on my desktop has gone almost completely black. I can make out a faint outline of the setting when they are brought up that allows me to vaguely read...
i think the picture tube of your monitor has some problem. go to a nearby vendor and replace it and also first make sure your adjustments of color and brightness are fine.
Apr 18, 2010 | Computers & Internet
Hansol710p 17"Monitor color adjustment problem
wich is factory colour profile from hansol 710p ? thanks in advance p.s. jovica.tasic@hotmail.com
Jul 25, 2009 | Hansol 710 P Monitor
I have no color red on monitor.
Confirm the "no color red" by testing with another PC. If the same condition check if a color adjustment on the monitor is possible... like maybe a default setting. If the monitor still produces a bit of red it might be possible to edit the color adjustments using the advanced graphics adjustments; or a graphics program that your computers' manufacturer has available on your computer.
If nothing works the monitor may need repairs.
Jul 08, 2009 | Computers & Internet
Cant figure out color issue with computer.
Well...it's a Dell and even when it's well...it's still a Dell.
Have you tried the monitor on different system to eliminate the tower being the problem? Some have updated and/or rolled back drivers to help cure this problem, which seems to be a common issue with this LCD. Personally i think the contrast ratio is inadequate.
Good luck with your Delllll...
May 14, 2009 | Dell E176FP 17" LCD Monitor
LG lcd computer monitor
try to connect your old monitor and adjust your screen properties down to 800x600 with medium color setting..or go to xp safe mode, adjust screen properties to the lowest setting, xp has not yet installed the monitor driver of your lg lcd monitor.
May 21, 2008 | Gateway FPD2275W LCD Monitor
The color of the screen is not correctly appearing.
if your monitor has color controls try them,if your monitor has auto adjust try that too.if you can test the monitor on another computer try that as well to verify the monitor is causing the problem.if none of this works its safe to assume that the color control circuitry in the monitor has failed and with todays monitor prices it is cheaper to replace than to repair.
Dec 26, 2007 | Chi Mei Corporation 221D-NBC Monitor
A white line across my screen
I got the same problem, I'm going to return it to the store today...
Nov 27, 2007 | ASUS VW192S Monitor
Color Problem
In rare instances it is sometimes the 15 pin connector that connects on the computer end. Could be at the monitor end of the same cord, if it is a connector and not hard wired to the inside. Check both possible sides for bent pins.
I once went through an extension cable and had to remove it as it was bad connections and I'd have constant color changes drifting in and out. Sorry, but most likely it is just a cheap monitor on the fritz.
Sep 07, 2007 | X2Gen MG19MY 19" LCD Monitor
Smart Modular SV3170A Logo
Top Smart Modular Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Are you a Smart Modular Computer and Internet Expert? Answer questions, earn points and help others
