Question about Kyocera Verizon Wireless K323 Cellular Phone
I need to know how to find what tower a text on a cell phone has come from...
Tracfone call restriction 34
It relates to a problem with cell phone the cell phone towers. To resolve the problem you just need to disconnect and reconnect to the tower. The easiest way to do this is to:
1) shut the phone off
2) wait a few seconds
3) turn it back on again.
If this does not resolve it just call tracphone support and they can assist you further.
Sep 08, 2014 | Samsung Cell Phones
I am not recieving all my texts
sounds like a tower issue, talk to your cell phone provider.
Jul 31, 2014 | Samsung GALAXY Note Smartphone Unlocked
How can I report a Cell tower outage and loss of signal in 14025 zip code?
You need to contact your carrier and report your outage with them.
Carriers not only own towers, but they also rent them from third-party companies. You, trying to locate a specific tower to report could take days. You, contcting your carrier and letting them figure out what tower is down (if that's even the case) by the info you give to them, will probably take just a few hours to resolve, if that.
May 08, 2014 | Boost Mobile Kyocera Hydro Smartphone
How does a mobile network jammer work
A mobile phone jammer is an instrument used to prevent cellular phones from receiving signals from base stations. When used, the jammer effectively disables cellular phones. These devices can be used in practically any location, but are found primarily in places where a phone call would be particularly disruptive because silence is expected. A cell phone signal jammer is used to stop nearby cell phones from sending or receiving signals to and from the cell phone tower. A cell phone works by communicating with its service network through a cell tower or base station. Cell towers divide a city into small areas, or cells. As a cell-phone user drives down the street, the signal is handed from tower to tower.
Cell phone jammers block cell phone use by sending out radio waves along the same frequencies that cellular phones use. This causes enough interference with the communication between cell phones and towers to render the phones unusable. On most retail phones, the network would simply appear out of range. Most cell phones use different bands to send and receive communications from towers. Jammers can work by either disrupting phone to tower frequencies or tower to phone frequencies or both.
Cell phones are full-duplex devices, which means they use two separate frequencies, one for talking and one for listening simultaneously. Some jammers block only one of the frequencies used by cell phones, which has the effect of blocking both. The phone is tricked into thinking there is no service because it can receive only one of the frequencies. The jammer also stops Internet use through Wi-Fi network and even blocks Bluetooth connections. The cell phone signal jammer also puts an end to text messaging, so students cannot SMS each other, while the teacher is trying to teach.
Interestingly, jammers are life saving devices for military. Terrorists use cell phones to trigger explosives. Army can use a jammer to make mobile phones go dead, so that army technicians can deactivate the bomb.
Jan 28, 2013 | Cell Phones
A text ''New CB (50)'' is showing on my SAMSUNG CHAMP Cell phone. what does that means?
that shows ur positioning tower. . .if u open it, it will show u the places where the nearest tower is situated !
Feb 18, 2011 | Cell Phones
When sending texts to certain numbers i get an error code 96 and the message will not send
Error 96 means you need to dial in the whole phone number...example 17085551212, not just 5551212 even if you are sending text message to the same area code.
Nov 29, 2009 | LG RUMOR Cellular Phone
Cannot send/receive texts or calls.
Two things to try. One is remove the battery then remove the sim card make sure it is clean. Wipe it with alcohol. If it still does not work you may need to go to your nearest store and they should be able to check it for you to make sure there are no updates that your phone normally downloads and you never know it. Usually when they place a new tower. I had a similar problem. Also if your sim chip is bad ATT can replace it usually at no charge and that should fix the problem.
Mar 24, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Messaging
i have a problem with messaging, i can recieve text messages but i cannot send texts, when i try is says General: Memory Full. plz tell me now
Jun 05, 2008 | Nokia N81 Smartphone
Motorola mobile
you need to find cell info in your settings and turn this on
Nov 22, 2007 | Cell Phones
Signal strengh
I assume this problem was resolved. If not, please contact me and I will walk you through the solution. It always helps to know the provider name. Most cell phones are only as good as the towers they connect to. If your phone is not connecting to the local towers correctly you need to contact your service company for a tower update code.
Please let me know if I can help further.
Ken
Jul 29, 2007 | Motorola Mobility Moto Q
Kyocera Verizon Wireless K323 Cellular Phone Logo
22 people viewed this question
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
