Question about Sony STR-DE545 Receiver
It keeps blinking "PROTECT" and we are getting no sound. Sony receiver
Make sure none of the speaker wires are crossed I have the same reciever and it did this to me once. I checked the back of it and the wires were touching its a feature to protect itself from shorting out. If there are no wires crossed id reccomend trying to reset the unit by holding down video and cd then pressing the power button. The screen should say FACTORY which means its been reset. Good luck and hope this helps.
Posted on Feb 01, 2010
Sony STR-GX800ES receiver "protector" blinking - no sound
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Jun 11, 2010 | Sony STR-GX800ES Receiver
I have a sony receiver that keeps flashing "protect" what does that mean
hello it sound like the output transistor could have blown or a capacitor could have poped or bulged
regards
shaun
May 15, 2010 | Sony STR-DE475 Receiver
PROTECT MESSAGE
It senses an error or problem and shuts down. Try disconnecting all the cables and wires attached to it. Try it again. If it still shows protect message, it is an internal fault and requires a repair shop. If it clears up, then the problem may be a shorted speaker wire. Correct the short when reconnecting the speakers.
Mar 08, 2010 | Sony STR-DE545 Receiver
PROTECT DISPLAYED ON RECEIVER
This generally means you've got a short somewhere, and the received is trying to protect itself.
My suggestion is to disconnect all of your speakers at both ends, and reconnect them.
Most times this happens because a speaker wire is lose, and the positive and negative connections are touching each other, causing it to short out.
Mar 24, 2009 | Sony STR-DE485 Receiver
Sony home theater system started blinking protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Mar 23, 2009 | Sony DAV-DX250 System
My reciever is flashing the word PROTECT and will not function. It's a Sony STR-DE445
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
  1. Check the speaker wires and speakers for proper connections.
  2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
  3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
  4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
  5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
  6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Dec 15, 2008 | Sony STR-DE545 Receiver
Flashing message on my reciever
PROTECT, PROTECTOR or the letter P is flashing in the display of the A/V receiver. Solution
sp.gif sp.gif Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
  2. Reduce the volume level. IMPORTANT: Ifthe receiver is played back at maximum volume level it may enter theprotect mode. Maximum volume listening will cause the receiver to runvery hot and may drain the output capacitors.
  5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Somereceivers provide compatibility with the higher sampling frequenciesthrough alternate connections. Consult the owners manual for specificinformation.
Receiver Blinks PROTECT
how many speakers have you got on to it
Dec 07, 2008 | Teac AG-V8060 Receiver
Sound
my sony receiver has a message auto protect so i get no sound how do i remove the message and get sound
Jan 19, 2008 | Sony STR-DE915
Sony receiver
Disconnecting everything will only clear the short if it is not inside the receiver. It is likely one of the internal components has failed and will need to be replaced. If you can obtain schematics for the unit you can attempt to find the trouble yourself, otherwise this is a job for a professional and probably replacing the receiver will be cheaper.
Nov 19, 2007 | Sony STR-DE685 Receiver
Sony STR-DE545 Receiver Logo
420 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
