Question about Maytag MTB1891AR Top Freezer Refrigerator
I have a Maytag mtf2195aes model refrigerator. I paid some guy $160 to fix the defrost timer. It is not fixed. The problem is that the freezer part is building up water droplets at the top of it. The back of the freezer is frosting up. I just defrosted the refrigerator for 24 hours and it still happening. What is the problem or does it sound like I need a new refrigerator?
  • 553 Answers
It is not that defrost timer or the thermostat control if this part are faulty, your fridge may not run, your problem is in your fridge system
try to have this check:
1. see the pipes all around the back and inside the freezer (underneath its wall) see if there is a part oily (cause: possible leakage due to use of sharp pointed object that hit the pipes)
2. possible leak at the back pipes near compressor due to vibration
Result:
Under charge or loss of refriferant (freon gas)
Solution:
find the leak and fixed it, charging of freon
Posted on Nov 13, 2009
Maytag refrigerator model number rsw22eo having problem with freezer not defrosting
You have a=>68233-3 Defrost Timer mounted somewhere behind the kick plate at base next to floor. Can you turn the timer slowly clockwise until the compressor and fans stop? I want you to force the refrigerator into defrost. If after 30 minutes the refrigerator does not restart running again replace the defrost timer. Once you place the refrigerator into defrost the elements should melt the ice that has been building up. If placing the timer into defrost does not help you will need to replace the=> 61001846 Defrost Heater Assembly . I am here if you have questions, John Tripp Appliance 911
Contact me here.
Jul 31, 2014 | Maytag Refrigerators
Fridge not cooling. freezer is still working
this usually happens when your Defrost (heater) is not working, Firstly Get your Defrost Timer Checked. If that is the problem then the timer is much easier to be replaced. Depending on the models the Timer prices differ from $10 to $115.
If this is not the issue then Inside the freezer is the Defrost Heater Placed, and you will figure out that this unit is having the problem due to which the channels to pass the Cool air into the Fridge is blocked and not keeping it cool. You will have to check if this Heater can be fixed or replaced. *Again this cost will Differ based on the models*
Mar 18, 2014 | Maytag MFD2562VEB Black 24.8 Cu Ft...
Fridge not cooling but freezer is maytag model mtb1553ar
Your MTB1553ARA Refrigerator sounds to me like it is not defrosting properly. Look inside the freezer along the back wall and see if a layer of snow is building from top to bottom. To test if defrost will work open the fresh food compartment and look for a small opening were you can turn the defrost timer slowly clockwise until compressor and fans stop running. Click here=> MTB1553ARA Fresh Food Section Control Panel and in that photo you will see the=> 68233-2 Defrost Timer that has a dial in the center I need you to turn clockwise. After the compressor and fans stop I want you to allow the refrigerator to remain off as it is for 30 minutes. The freezer should now be defrosting and if after thirty minutes the refrigerator does not restart on its own then again turn the timer again slowly until it does restart. If you need to restart the fridge this way then the problem is the 68233-2 Defrost Timer Next I will detail how to install the 61001946 Defrost Heater and the=> 61005254 Defrost Thermostat
if the defrost timer is not the reason for this happening. Here is a MTB1553ARA Parts Manual PDF Let me know here how the defrost timer test goes, Thanks Sea Breeze
Jun 21, 2012 | Maytag Refrigerators
Maytag refrigerator not cooling and freezer has frost over coils/vents
Your refrigerator is not defrosting.
3 parts that can be contributing to your issue.
1. Defrost Timer/ Defrost board. Without knowing the model, if it is older, you have a timer, newer ones have a control board that does the same thing. Lots of maytags with the boards have issues.
2. Defrost Bimetal- found at the coils, the bimetal could be bad-cheap part.
3. Defrost Heater- least likely for a maytag to have a problem with the heater.
May 18, 2012 | Maytag Refrigerators
Freezer and refrigerator blow warm air
Some maytag refrigerators came with Adaptive defrost systems some with timers ahd some have a problem getting the compressor started. Would you by chance have the model number of your Maytag? If you want a service manual and see if we can fix it here send me the model number, Thanks Sea breeze
Jan 03, 2010 | Maytag Refrigerators
Maytag freezer icing up
If is just one spot in the whole back wall like snow ball (small) ,the unit is leaking refrigerant and the leak has to be fixed and only after that recharged.But if the back inside the freezer gets all ice up and won't defrost by itself the problem is with the defrost system ,timer ,heaters or defrost terminator.
Aug 09, 2009 | Maytag MTB1976HR Top Freezer Refrigerator
Defrost Timer?
depending on model thats either your timer or cold control would be about 200
Mar 19, 2009 | Maytag MBB2256GES Bottom Freezer...
Broich Commercial freezer ~ manual lost
I just turned it off and pulled out the super defrost button. I used towels not the drainage plug since I couldn't find a pan of any sort.
Also...very funny comment about my husband taking care of it!
Feb 08, 2009 | Arctic Air 22 cu. ft. Commercial Freezer...
Maytag MTB1891AR Top Freezer Refrigerator Logo
164 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
