Question about HP PSC 750 All-In-One InkJet Printer
How do I set scan option
I would like to scan paper documets to my computer. My computer is on (Vista system) and when I place documents on the scanner glass I get a message that says scan is not set. Lost instructions to printer. How do I set scan option?
  • HP Master
  • 5,126 Answers
Look at this URL: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=57769 for details
The scan options will depend on which version of Vista you are running. Since the Home Premium version is the most common, I'd suggest you look for Windows Photo Gallery or Paint and then under File look for the Import from Scanner or From Scanner (depending on the program).
This will work if your computer is directly connected to the scanner. If you have a router or print server that let you network your All-in-One, you need to look at the specifics for that product.
I hope this helps.
Posted on Nov 13, 2009
  • 460 Answers
On your desktop you should have a scan manager icon if you loaded in the driver disc properly and that will give you your scan options in there.. if you have none, go online and download for free the driver package.. make sure you supply the model # and look carefully on the website..good luck..
    President:
  • 1,335 Answers
You can download a user manual for the PSC 750 from
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=57769&lang=en&
Please rate this solution. Thanks.
Copy on HP Laserjet 200 Color MFP
If you just want a single copy of the document, place the page face down on the scanner glass or face up in the document feeder. Then press Copy on the all-in-one (for the M276 this is on the touch screen). If you need to adjust the image quality/size or paper size, press Settings. Then press Image Adjust or scroll down and touch Paper. When done adjusting any setting, press OK. Then press Black or Color depending on your source page.
If you want to scan to a computer first, you'll need to make sure that the full software is installed on that computer. Then launch a scan from the computer before using the touch screen's scan button. You need to set up the default scan options before the scan button works. (There is a monitor program "hears" the button and it needs to know the scan defaults and destinations to launch the appropriate parts of the software.)
Note: many all-ones will not work if there is a problem with the print system.
I hope this helps.
Mar 18, 2014 | HP Color LaserJet Pro 200 M275nw
I've got a all-in-one printer of HP LaserJet M1120 MFP. When I switch it on the screen shows "Scanner Error 20". And I cannot use the scan function. It can print when connected to computer. I've rea
Follow these steps to scan using HP software:Step one: Load the item to be scanned
  1. Make sure that the product is connected to the computer.
  2. Turn on the product.
  3. Load the item in the document feeder tray or on the scanner glass
Tip
Load the following items in the document feeder tray :
  • Single items
  • Items that are not easily damaged
  • Multipage, single sided items that you want to scan into one file
Load the following items on the scanner glass :
  • Single items
  • Items that are easily damaged, such as old documents and photos
  • Multipage, double sided items that you want to scan into one file
  • Option one: Document feeder tray
    1. Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first.
    2. Adjust the width guides to fit the item.
  • Option two: Scanner glass
    1. Open the scanner lid.
    2. Place the item with the print side down on the scanner glass. For the correct position, see the engraved guide near the corner of the glass.
    3. Close the scanner lid.
Step two: Scan the item Use one of the following methods to open the HP scan window:
  • Double-click the HP scan icon (c02436443.gif ) on the Windows desktop. note.png NOTE:If you have more than one HP product installed, double-click the HP scan icon (c02436443.gif ) for the product you are scanning with.
  • Click Start (c01827528.gif ), click All Programs , click the HP folder, click the name of your HP product, and then click HP Scan .
Click the scan option for the item you are scanning. note.png NOTE:Depending on your HP product, you might not have all the following scan options available. c02448891.gif
Save as PDF Use this setting to scan text documents that are not editable. Use the Save as Editable Text (OCR) option to scan text that you can edit. c02448892.gif
Save as JPEG Use this setting to scan pictures and images.
Hope this information will be helpful.
Let me know.
Regard
Oct 29, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
HP LJ 3030 w/ USB connection to a computer with Windows Vista Home Premium Svc Pack 2. 64-bit Operating System. Problem: When I feed legal size docs through the doc feeder, the scan is letter size. I...
Hello Steve !
The only way scanning Legal documents on this HP LJ 3030 willbe using the ADF ( Automatic Document Feeder) since the size of the flatbed its only for letter.
So, after placing the document on the automatic document feeder theres a few setting you will need to change on the printer.
Number 1 : Go to Main Menu on the printer and look for System Setup, under system set up look for Paper setup,hit ok and now look for "Def. Paper Size" and set it to "Legal"
Number 2 : you should have a button on the printer control panel (Physical printer) that says " Reduce / Enlarge" , hit it and make sure the one selected is "original=100%"
Now just hit "Start Copy" and it print LEGAL ! it worked for me
Hope this help !
You can contact me at:
eliteprintersolutions@gmail.com
Bryan
Jul 16, 2010 | HP LaserJet 3030 All-In-One Printer
Scanner
Try updating the drivers. Take this link to Hp and either enter model number and then operating system or let Hp detect your hardware and select drivers.
http://www.hp.com/#Support
Aug 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
Unable to scan 0n my HP3110 photosmart since changing to vista
Download Vista drivers for your HP scanner and install the same.
Apr 02, 2009 | Office Equipment & Supplies
How to use the scanner on my Epson 60000
there are different type of scannig programs. I am not that particular with your epson scanner. You can try scanning the document and if you want to archive it you can try choosig the option of file type as compressed tif. If you do not have this option there would be times that scanning software will have the preview of the document you have scanned and will asked you if you want to reduce or enlarge size. If resizing option is not available in your scanner software you can try saving it first in your computer. After saving the document try to open microsoft word and create a new file. Then look for the document you have scanned and copy that document. Once you have copied it go back to microsoft word and paste the documet. you could now resize the document manually. but for further clarification you can try calling your scanner provider. they might have some programs for it and will give it to you
Nov 20, 2008 | Epson Stylus Multifunction Inkjet Printer/...
No Paper in Document Feeder
I just upgrated my Vista system as recomanded, and after that I am not able to scan documents, getting the messGE " NO PAPER IN THE DOCUMENT FEEDER " on my all in one laiser jet 3050
May 23, 2008 | HP LaserJet 3055 All-In-One Printer
I can't Scan 8 1/2 by 14. It cuts the scan to that of a regular paper. I can fax by 8 1/2 by 14 and it comes out alright. how i do the set up. I used the set up in the scan but it did not help.
I also had problems scanning legal size documents with a Brother MFC-7440N. The documents would scan but would not come out complete. A large portion of the text would always be left out and only an image of the size of regular page size would come out. I knew it had to be something with the settings, so after experimenting with my MFC-7440N I came to the conclusion that I was not going to find the solution on the actual machine. I had a "Hunch" that I would find my solution by connecting the printer to my laptop computer and use the software that came with it. After a couple of minutes I was able to scan Legal Size documents in a breeze... I should of done this months ago. All scanned docs came out in full size.
So I took some screen shots to post them up here to let everyone know how to scan legal size documents since I noticed that people are having trouble just like I did. With this instructions you will also be able to scan any available size documents with a Brother MFC-7440N. I will also guide you step by step. After step 4 the remainder steps are OPTIONAL unless you need to change the color or picture file types. Okay, here we go!
Step 1.
Make sure your MFC-7440N is connected to your computer and the computer has the software installed that came with the printer.
Place the Legal Sized documents/papers that you want to scan on the Paper Feeder Scanner located on the most upper area of the machine.
Step 2. On your computer, go to START then to DEVICES and PRINTERS, or CONTROL PANEL then DEVICES and PRINTERS. Locate the icon of your MFC-7440N. If its not your DEFAULT printer make it the default one. Then RIGHT Click on the icon. A menu will pop open. Locate START SCAN and click it.
Step 3. A small window will open that will give you various options to scan a multitude of sizes and different settings. Locate where it says SOURCE. The default setting might be FLATBED meaning the flatbed scanner of your machine. Click the drop down menu and select FEEDER. By selecting the feeder option your computer will tell your machine to use the automatic paper scanner located on the most upper area of your machine.
Step 4. Locate PAPER SIZE. Click on the drop down menu and then select Legal 8.5 x 14 inches (216 x 356mm).
If your documents are already located in the feeder you can now go ahead and click SCAN and your documents will begin to scan.
Your scanned documents will be saved in a file folder in your computer and that file will pop open for your convenience once all documents are scanned.
If you need to change COLOR or Black and White setting plus Picture File Types such as Jpeg or Tiff just click on their respective drop down menu before clicking SCAN.Here are some pictures to help me illustrate it.
I hope you find this helpful.
Thank You!
Visit me at:
Facebook.com/BestCreditRepairManualor at
BestCreditRepairManual.com 92c85b21-a89d-4f9a-bf67-a96f103f2c15.jpeg 6adfe3bc-45ef-4e80-a6b2-7b825e659868.jpeg da5aa6de-6531-4fb6-9f91-3a1b503ac89c.jpeg 36e97075-1229-4d28-b14c-e7371ad26589.jpeg 15d2f41b-30e0-42cd-9e6d-663e9bb17a3c.jpeg 6d240b8f-2360-4094-8d6b-0c8cd404332c.jpeg 4203c1e5-8b35-4dc9-a802-65652251f028.jpeg
Oct 20, 2007 | Brother MFC-5840CN All-In-One InkJet...
HP PSC 750 All-In-One InkJet Printer Logo
857 people viewed this question
Seeker5211
Seeker5211
