Question about Sony Handycam DCR-SR62 Camcorder
Sony DCR-SR62, warning indicator E:31:XX. Does it mean that it's HDD is crashed?
Drawsalot
  • 38 Answers
SOURCE: error code sony dcr trv25 c:31:23
Sony says the unit needs a power reset (error 31). Unplug the camera, remove the battery and wait several minutes before re-attaching the battery and/or AC cable. Then power the camera back up. The 23 code says you need to use a InfoLithium battery-- apparently these are smart batteries that give data back to the camera. These error codes seem to be quite common however, and so a hardware issue may be the case. Some users have said that removing the battery while the camera is powered on will clear the codes. Others advocate "smacking" the camera, I would not however, recommend this. www.sony.com is a good place to look for more information.
Posted on Nov 21, 2007
ctf1800
  • 4402 Answers
SOURCE: sony DCR-PC5
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Jan 17, 2008
SOURCE: C:31:23 error with DCR-PC101 Sony camcoder
Had the same error message on my TRV-720, and could not come up with a solution for weeks until I found this website:
http://www.protechcam.com/wwwboard/messages/127.html
Now the fix you will not believe, nor did I at first, but requires you to power off the unit completely and "Smack it" a few times fairly hard.
Now you may do this at your risk, but I swear it fixed mine and all the other people listed at the above web site.
I thought it was a joke - but it works!!
Good Luck!
Posted on Jul 28, 2008
SOURCE: Sony DCRTRV 25 : Getting 31:23 error message
Andre62:
The error is code is for S reel fault. This is the left reel for rewinding the tape.
Posted on Nov 23, 2008
SOURCE: Sony cam LCD screen scrolling
Sony replaced the flexible board cables (FP-621 and FP-610) on my uncles camera. About 8 months after the repair the camera screen doesn't always turn on. I can get it ti turn on if the lcd is rotated towards the person being recorded. I think it might be a problem with a switch on one of those flexible cables.
Posted on Dec 29, 2008
Sony error hdd 31:00
I have Sony DCR-SR68 handi cam but it have HDD format error Or display E:31.00 what to do please help me for this problem
Sep 25, 2012 | Sony Handycam DCR-SR85E HDD Camcorder
The screen is damaged
Hi.
My name is Rick and I am the owner and technician of Discount Camera Repair. The problem you are experiencing can be repaired fairly inexpensively but will require disassembly by a qualified technician. If I can be of any help please call or email me. I'll be happy to repair the camera for you.
Jan 07, 2012 | Sony Handycam DCR-SR62 Camcorder
Sony Handycam DCR-SR200 e:91:01 means?
From page 32 of the user manual that is available for download here: (click here)
The error message that you are seeing requires that you to take the camera in for service, since a failure has occurred that the owner cannot fix themselves:
E:20:ss / E:31:ss / E:61:ss / E:62:ss / E:91:ss / E:94:ss
A malfunction that you cannot service has occurred. Contact your Sony dealer or local authorized Sony service facility. Inform them of the 5-digit code, which starts from E
Nov 26, 2011 | Sony Handycam DCR-SR200 Camcorder
The LCD screen of my SONY DCR-SR62 shows distorted image when i turn on the camcorder. How can i fix this issue?
First you have check on tv is there same problem as you see on the camera LCD? If no and only see on the camera LCD then there is one wire problem which is attached with Main board to lcd board.Its call flexable wire need to replaced this.
Nov 04, 2010 | Sony Handycam DCR-SR62 Camcorder
What does code C:32:20 mean
5-digit display Cause and/or Corrective Action C:04:xx You are using a battery pack that is not an "InfoLITHIUM" battery pack. Use an "InfoLITHIUM" battery pack. C:21:xx Moisture condensation has occurred. Eject the cassette and leave your camcorder for at least one hour to acclimatize. C:22:xx The video heads are dirty. Clean the heads using the Sony V8-25CLD cleaning cassette. C:31:xx
C:32:xx A malfunction other than the above that you can service has occurred.
  • Eject the cassette and insert it again, then operate your camcorder.
  • Disconnect the power cord of the AC Adapter or remove the battery pack. After reconnecting the power source, operate your camcorder.
Hope this helps
Apr 14, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
Hi. It is showing a warning indicaotr
E:31:00 shows problem with Hard Disk Drive.
Need to inspect connection wire that might be misaligned and if found OK then replace HDD
Its qualified tech job to do so because camcorder will be apart.
Thanks.
Nov 13, 2009 | Sony Handycam DCR-SR62 Camcorder
LCD DISPLAY SCROLLS Sony Handycam DCR-SR62
Had the same.after stopped showing anything and the rest was working perfectly. Changed the flex wire connecting camcorder and it's like new. got from the repair shop and did it by miself. Good luck
Meggita
Aug 04, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony Handycam  DCR-SR62 Camcorder Logo
69 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
