Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
How do you plug the cable to bravio soney TV --it is a verizon cable box Thanks
  • 52 Answers
Get a an Hdmi cable if you don't already have one. and plung into the back of the TV where it is label hdmi.
Posted on Nov 14, 2009
We have just purchased this TV, plugged it in and attached to the cable outlet. We do not receive many stations. Does this TV have to be hooked up to a cable box as well? Our older TV worked fine just...
You probably have to rent a cable decoder box from your cable supplier. Comcast charges about 6.00 bucks plus the cable package about 40 bucks a month. Verizon charges about the same.
Dec 27, 2010 | Televison & Video
Tv turns on picture shows for 3 seconds then screen turns solid green. Sound is present even when screen is green.
I had the same problem on my Sharp LC-32SB24U Liquid Crystal TV. When I couldn't find any solutions on this site, I looked elsewhere on the internet. I found two credible leads.
First, supposedly, this is caused by a known problem with Verizon FIOS. Apparently, there's a problem that Verizon knows about that has to do with the signal between the Set Top Box (STB) and the TV, via the HDMI cable. Other posters on other sites said that the problem is more common with the 7100 series STB's and that the problem is not as rampant on the 6400 series STB's. (Mine is a 7200 series STB.) I have not called Verizon yet, but other posters said that Verizon just says that you'll have to use a set of basic red, yellow, and white cables, versus and HDMI cable, until Verizon gets the bugs out of the system.
The other credible lead revolves around unplugging the TV for two minutes and then plugging it back in. Simple.
Here's what I did, and it worked!
I unplugged the STB and let it sit for 5 minutes. Then, when I plugged the STB back in and powered itself back up, my problem was solved! (Before I did this, I tried just unplugging my HDMI cable to rely solely on my basic connector cables, but that didn't do anything for me.)
Good luck all!
Jul 04, 2010 | Samsung LN40B530 40 in. LCD HDTV
Green color of screen
Good luck all!
Jun 27, 2010 | Sanyo DP42848 LCD TV
I am having an on and off again problem with "no sound" just a picture on my Soney HDTV Model # KDL-46S2000. I have Verizon Fios and they have been out several times to try and fix the problem by changing...
when the sound goes out again ..try connecting a dvd with the same wires and input ...this will let you know if it is a tv problem ...and if it doesnt go out ...when you do this .. verizon need to check the sunrise readings to your set top box
May 20, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Now have verizon Fios and cannot get DVD player to play
Check the connection cable. If the Verizon box and the DVD player are connecting to the same TV input, ensure that the Verizon fios box is connecting to DVD input, and DVD output is connecting to TV.
If you connect DVD out to Verizon box input, and then TV , you will have to turn off the receiver box to see DVD.
If you use only one TV Input connect Verizon output to DVD input and DVD out to TV.
If instead you use separate inputs on TV, then try using the source/select input button on TV remote, and try different cables.
Regards.
Jul 25, 2009 | Sharp DVMX1U DVD Player
Significant volume decrease when using Comcast cable box
This low audio problem happened to me suddenly yesterday. I powered off over night - no change. I plugged the A/V cables into a second TV - no change. I called Comcast - problem solved.
Tap these buttons on the remote;
May 16, 2009 | Panasonic Viera TC-L37X1 37 in. LCD HDTV
HD feed problem
this tv can only process 480p and 1080i as hdtv signal. Check your motorola to see if it is outputing something like 720p....
Sep 17, 2008 | Philips 30PW850H 30" TV
Green Screen
Turn Tv off by power point unplug even for 30 or 45 minutes then turn back on. that way the tv has time to reset back to normal
Sep 07, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Verizon DVR HD Cable Box
Press the red button tha has a text of REC
Jul 13, 2008 | Televison & Video
Soney 32" flat screen tv. 2006
Try going into the television, and changing the audio setting to stereo, it sounds like it set to SAP (second audio program).
Feb 10, 2008 | Televison & Video
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
60 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
