Question about Uniden CLX485 Cordless Phone
I'm getting an E4 error code on my Radio Shack phone base. All 5 phones say out of range on this sytem. What does E4 mean? My 2 regular phones work. We had a brief power outage. When the power came back on, our cordless phones didn't work.
  • mlhomeloans1 Nov 24, 2009
    Me too. As of today. I was hoping for an answer here. =-(
  • 18 Answers
SOURCE: E4 code on base station
i know that you dont want to hear this but that means it must be replaced. you should be able to get a replacment form where you purchased the phone
Posted on Jan 09, 2009
jonniewalker
  • 1031 Answers
SOURCE: Base unit displaying E4 after we experienced a power black out
e4 error code that means it ihas defective base unit. it happened due to a spike in the power lines that may cause this error
Posted on Feb 09, 2009
  • 16 Answers
SOURCE: E4 trouble condition comes up on screen after power up
Error #4, You probably need to reset the phone by unplugging the main unit from the power source then plugging it back in abd re registering the handsets by setting them in the main cradle for about 10 seconds each. if this doesn't work try the manual if you have it still and see what E4 error means. Good Luck. Sometimes with electronics all you need to do when they wont work is unplug then and plug them back in while holding the power button on. This is amazing trick that no one wants anyone to know about. it works great on VCR's and DVD players.
Posted on Feb 15, 2009
SOURCE: e4 error message
I have the same problem. Want to buy a new one, but would like to know if this can be fixed.
Posted on Jun 09, 2009
gopakumarg43
  • 75320 Answers
SOURCE: E4 - Erros My uniden phone
Hello
Connect the phone line and power UP the base unit. Place the handset on base to get charged. It must reset automatically when you place the handset on base to charge. If not; resetting both handset and base unit is necessary.
Resetting the Handset
You may need to reset your handset in the following instances:
You lose a handset and purchase a new one. When you try and register to your existing base you get registration
failure.
You are unable to register any handsets to the base.
You had a base which needed to be exchanged by the manufacturer. When you register your existing handsets
to the base, the handsets say #3 and #4, but you only have 2 handsets.
When you are instructed to by the one of the manufacturer's call center representatives.
To reset, do the following:
Press and hold [ ] and [#] for more than 5 seconds. Select DEREGISTER HS.
WHICH HANDSET? appears. Select the handset that you want to de-register, and press the OK soft key.
DEREGISTER HS appears. Select YES, and press the OK soft key.
ARE YOU SURE? appears. Select YES, and press the OK soft key. You will hear a confirmation tone. The
handset will clear its registration information from the base, and then delete its own base information.
MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER TO OWNER'S MANUAL. To
re-register the handset to the base (see page 25).
If the handset cannot contact the base, it will display OUT OF RANGE. Make sure the handset is in range of the
base and the base is connected to power.
Note: It is also possible to reset the handset back to its original factory settings. All changes including Caller ID information
will be erased. For more information on resetting the handset back to factory settings and when you need to
do this, see www.uniden.com or call our Customer Service Hotline. See back cover page for contact information.
Resetting the Handset without the Base
If your original base is not available for some reason (for example, it is lost or somehow incapacitated), you can still
reset the handset and use it with another base.
Move the cursor to select BASE UNAVAILABLE and then press the OK soft key.
BASE UNAVAILABLE appears.
Move the cursor to select YES, and then press the OK soft key. ARE YOU SURE?
appears.
Move the cursor to select YES, and then press the OK soft key. You will hear a confirmation tone. The handset
will delete its own base information without trying to contact the base. When the base information is deleted,
the handset displays MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER
TO OWNER'S MANUAL. Register the handset to the new base (see page 25). of its user manaul.
OK.
Posted on Sep 12, 2011
Microtel kx-tsc7431d2cid not connecting to cordless phone
test putting another phone in the plug for to see is working.
2) if is working the problem is your phone
3) recharge the batteries, or replace
4) use the adapter and mesure the output for to see if chargin to the phone batteries.
5) if this do not resolve the problem, you have problem with the base IC charger defective. hOWEVER try to clean with contacts cleaner buy it from radio shack or computer .Replace and go to the repair shop.
Jul 21, 2012 | Lands Phones
Phone flashing 88 8 now flashing e4 cannot get dial tone.
Your manual may have the E4 code, but Uniden certainly will, if you contact their support site. This symptom often indicates a power or function issue with the base unit, and so make sure the base has charging voltage, and the terminals are clean (use a qtip and alcohol). When you contact Uniden Support, have your model number ready, since different units can have the same or different error codes programmed into them.
Good luck, and hope this helps.
May 19, 2011 | Uniden Cordless Phone
Uniden power max 5.8 it says E4 wont work any help
After a power outage I receive an E4 error on my Uniden PowerMax 5.8GHz base unit. Is this broke beyond repair? Or, is there some sort of reset to get the phone working again?
Jun 19, 2009 | Uniden Lands Phones
Feb 09, 2009 | Uniden 5.8GHz Cordless Phone
Dec 29, 2008 | Uniden TRU9480 Cordless Telephone
No dial tone. No calls. Can't call out.
E4 IS AN ERROR MESSAGE, THE BASE IS NO LONGER GOING TO WORK, POSSIBLY A POWER OUTAGE COULD OF DAMAGED THE BASE.
Dec 28, 2008 | Uniden Cordless Phone
E 4 ERROR CODE?
Customer support 1 800 297-1023 told me that this means the base unit is defective and can't be repaired. I also was told that none of my remote units are compatable with other models.
Sep 26, 2008 | Uniden TRU9480 Cordless Telephone
E4 error code
Exact same problem. E4, sent uniden an email thru their website though I doubt Ill hear any response. Very disappointed as the 9485 was working great until all of a sudden E4 showed up.
Nov 29, 2007 | Uniden TRU9485 Cordless Phone
Radio Shack 43-3880 5.8GHz digital answering system - error codes
Well, bad news! After taking my phone to Radio Shack and allowing them about 30 min. to identify the issue, the result was that an E4 error means a non-repairable internal problem. If the phone is less than a year old, and you have a receipt, it is covered by warranty.
Oct 29, 2007 | Lands Phones
E4 error code
I called Uniden about the same problem.  They say it is a code that means it is defective base unit.  I had purchased it within one year and they will gladly send me a new one.  I don't know if they will offer anything beyond the one year mark.
They say it was a spike in the power lines that causes this error.
Oct 09, 2007 | Uniden TRU9488 Phone
Uniden CLX485 Cordless Phone Logo
190 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
