Question about Porter Cable-Cable No.BN125A 18GA1-1/4"Brad Nail Kit
Air is escaping from the top of the bn125a brad nailer. It won't fire nails.
  • 2,176 Answers
It sounds like you have a damaged o ring/seal that requires maintenance. You can go to Dewaltservicenet.com and download a breakdown for this tool and also order parts for it. When reinstalling new o rings don't forget to put a little bit of grease on them so they don't roll or pinch. Let me know if you need more help
Posted on Nov 15, 2009
Bn125a nailer not sinking nails all the way
The depth to which a fastener is driven is controlled by the depth adjustment
knob (A) Fig. 19 below. The depth of drive is factory adjusted to a nomimal setting.
Test fire a fastener and check depth. If
a change is desired, rotate the
adjustment knob (A) Fig. 19: the
adjustment knob has detents every 1/4
turn. Rotate the knob clockwise (see
Fig. 19), to increase the depth of drive,
rotate the knob counterclockwise to
decrease the depth of drive. Test fire
another fastener and check depth.
Repeat as necessary to achieve
desired results. The amount of air pressure required will vary depending on the
size of the fastener and the material being fastened. Experiment with the air
pressure setting to determine the lowest setting that will consistently perform
the job at hand. Air pressure in excess of that required can cause premature
wear and/or damage to the tool.
Good Luck
Nov 26, 2010 | Porter Cable Cable BN125A Factory -...
How do I adjust the depth of the brad nail on the porter cable BN 125A brad nailer
Hello. To adjust the depth of the nail you have to increase or decrease the air pressure from the compressor. Look at the compressor and you will see a knob or dial that you can turn to increase or decrease the air pressure. Do this adjustment in small increments testing the nailer by driving nails into a scrap of the same material you will be driving the nails into on the actual job. Increasing the pressure will drive the nail deeper and decreasing the pressure will drive the nail less deep. Joe
Nov 10, 2010 | Porter Cable Cable BN125A Factory -...
MY 18GA nailer will fire but it wont fire the nail.
Usual causes:
Driver doesn't move back far enough. Usual cause of this is inadequate lubrication. Load a bunch of air tool oil, say 20 drops and cycle unit repeatedly.
Wrong type nails.
Nails not properly seated in the tray. Check that they can move freely into the slot/path the driver comes down.
Jammed or broken nail in the path. Disassemble and clean out debris.
Broken nail parts up in the area below the piston. Disassemble and clean out debris
Mar 13, 2010 | Porter Cable Cable BN125A Factory -...
Porter cable brad nailer only fires brad on second trigger pull
The dent in the wood is not caused by the air. It's caused by the set that drives the brad. Are you oiling it consistenly? Are the brads the right manufacturer for your porter cable brad nailer? From the information you give it appears that the brads are not advancing correctly or that the air pressure is not sufficient to dislodge the brad from the brad strip on the first strike - it takes an additional strike to break it free. The standard for adding oil is to add ten drops of air tool oil for every hour of operation. That seems like a lot, but the correct amount of oil is a sure way to prevent most air tool problems.
Aug 29, 2009 | Makita AF503 2'' 18 - Gauge Brad Nailer
BN125A Nailer will not fire even after rebuild kit
low air pressure may be the cause ,make sure you set the outlet to 70- 90psi
May 27, 2009 | Porter Cable Cable Brad Nailer and...
Brad nailer not firing nail...can hear brief air noise upon pulling the trigger
Porter cable makes a number of brad nailers (18 gauge) that very quickly suffer from the problem that you are having. You did not mention the model number of your gun but if it is one of these, (bn125a, bn200a, ns100a) kit # 60061 will fix the problem. It costs between 25 and 30 dollars. Google that part number or order from www.dewalt.com. Dewalt owns the porter cable brand. Before you order the kit, check that the driver blade is not bent and stuck. The driver should travel freely down the cylinder. When you install parts, use Danco silicone grease to lube (availabel at Lowes in the plumbing department) If your model # is different from those mentioned above, please email me and I will recommend a repair.
Apr 27, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Bn125 brad nailer is jammed
I've had to remove the plate over the "firing pin" a couple of times (the allen wrenches come with the gun) to release it. Mine was caused by a bent pin, that happened when I hit the hose and knocked it off the bench.
When I finally replaced it (CPO/Porter Cable), it's been fine ever since.
Mar 31, 2009 | Porter Cable-Cable No.BN125A...
Porter Cable BN125A won't set nails below surface
Not sure about the seal, but I do know the pressure has to stay up for this nailer to be effective. Try oiling the gun to free up the mechanics and don't use old nails.
Jan 23, 2009 | Porter Cable Cable BN125A Factory -...
Porter Cable-Cable No.BN125A 18GA1-1/4"Brad Nail Kit Logo
566 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
