Question about Brother P-Touch 1180 Label Printer
Brother P-touch 1180 tape cartridge jammed
I pulled it out and fixed the jam but i have NO idea how to put it back in the feeder to print properly. There are three different feeds: 1) the laminate 2) the toner ribbon 3) the Label -- I don't know how to layer them so that it prints the right way. I feel so stupid.
  • 3 Answers
Man, that tape's a real b!%^ch. I just spent an hour figuring it out, so here ya go... In the center is a (larger that the rest) gray wheel, this is the "toner" take up reel. On the tape that's come out of the cassette, seperate the three layers, and start "reeling in" just the toner. (The laminate and label that have come out are just lost, no real hope for them) When you get close to the end of the toner, help it feed straight back in, and it will go all the way back in. You may have to hold on to the laminate and label so it doesn't try to follow the toner. once that done, it should look like the original cartridge, trim off the excess and you should be good to go.
Brian
Posted on Apr 01, 2010
  • 1 more comment
  • PCG01 Dec 20, 2010
    Like bwag01 said, there are 3 layers of tape. the middle one is the toner tape that goes back into the cassette the other 2 come out as tape (the color tape sticks to the clear top layer, after the print head has imprinted the text from the toner tape onto the clear layer).
    You can cut the color tape and the clear top layer and feed them properly later, but if you cut the toner tape, the only fix is to dis-assemble the cassette and re-wind the toner tape properly ( it can be done, I did... cut through the label at the seam and pry up the edges. squeeze the prongs in the hole on the bottom , and carefully keep seperating the top off).
  • kevinwlester Mar 19, 2011
    I cut the black toner tape, dang it. I'd like to fix it, but I can't quite picture what you mean by, "cut the label at the seam." Or "squeeze the prongs in the hole on the bottom."
  • qaz Dec 02, 2014
    Huh? The repair instructions are as good as the broken cartridge.
P-touch 1180 will not print, I type in what I want and hit print, and I get an error. how do I fix this error, what is the error?!?!
You did not specify the error you are getting. However, if you have an additional TZ cartridge, try replacing the cartridge as the current one may be jammed or out of tape.
Apr 17, 2014 | Brother P-Touch 1180 Label Printer
I tried printing and didnt realize i had papers sitting on top of printer it printed and crumbled papers as it was printing now i have it blinking error , i check for paper jam , its all clear i cant get...
    See below. It's the steps after 7 that is most likely part of you issue. Refer to your user guide (or see below for a link to an online version) for illustrations.
  1. Slowly take out the drum unit and toner cartridge assembly. Some of the jammed paper will be pulled out with the drum unit and toner cartridge assembly.
  2. Set the drum unit and toner cartridge assembly on a piece of disposable paper or cloth in case you accidentally spill or scatter toner.
  3. To prevent damage to the printer caused by static electricity, DO NOT touch the electrodes inside the printer.
  4. Close the front cover.
    Note: Do not put the drum unit and toner cartridge assembly back in at this point.
  5. Pull the paper tray completely out of the printer.
  6. Pull the jammed paper down and out of the printer.
  7. Open the back cover (back output tray).
  8. Still looking at the back of the printer, pull the tab toward you to open the fuser cover.
  9. Pull the jammed paper out of the fuser unit.
    HOT SURFACE
    After you have just used the printer, some internal parts of the printer will be extremely hot. Wait for the printer to cool down before you touch the internal parts of the printer.
  10. Close the back cover (back output tray).
  11. On the drum unit you set aside, push down the green lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
    CAUTION
    Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
    To avoid print quality problems, DO NOT touch the roller part of the toner. Try to keep you hands, fingers and everything else away from there.
  12. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the green lock lever will lift automatically.
  13. Open the front cover. Put the drum unit and toner cartridge assembly back in the printer.
  14. Put the paper tray firmly back in the printer.
  15. Close the front cover.
  16. Make sure that the Error LED is now off.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_2140_2170W_EN_1160.PDF
Jan 29, 2011 | Brother HL-2170W Laser Printer
DRUM ERROR - HAD PAPER JAM, CLEARED THAT AND NOW IT WILL NOT PRINT - KEEP GETTING DRUM & ERROR
Sorry to hear you are having problems. Printers can be very frustrating at times. Below is a description of how to complete clear paper jams paper can get jammed it there pretty tightly and in very small places. Ensure you've followed all the steps to clear your paper jam and you should see your printer start working again. Refer to your user guide (or download via the link provided at the bottom) for illustrations.
  1. Open the front of the printer.
  2. Slowly take out the drum unit and toner cartridge assembly. Some of the jammed paper will be pulled out with the drum unit and toner cartridge assembly.
  3. Set the drum unit and toner cartridge assembly on a piece of disposable paper or cloth in case you accidentally spill or scatter toner.
  4. To prevent damage to the printer caused by static electricity, DO NOT touch the electrodes inside the printer.
  6. Pull the paper tray completely out of the printer.
  7. Pull the jammed paper down and out of the printer.
  8. Open the back cover (back output tray).
  9. Still looking at the back of the printer, pull the tab toward you to open the fuser cover.
  10. Pull the jammed paper out of the fuser unit.
    HOT SURFACE
  11. Close the back cover (back output tray).
  12. On the drum unit you set aside, push down the green lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
    CAUTION
  13. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the green lock lever will lift automatically.
  14. Open the front cover. Put the drum unit and toner cartridge assembly back in the printer.
  15. Put the paper tray firmly back in the printer.
  16. Close the front cover.
  17. Make sure that the Error LED is now off.
Jan 27, 2011 | Brother HL-2170W Laser Printer
I have a Brother HL 1440 that had the paper jam in the front and back, crumbling up in the process. I cleared both locations with no success. The ready and alarm continues to flash and the printer still...
Check the following steps for fixing Brother Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Nov 15, 2010 | Brother HL 1440 Laser Printer
I got a Brother HL 2140. Paper jam. What can I do? Thank you for your help, vVcky
    HOT SURFACE
    CAUTION
Oct 04, 2010 | Brother HL-2170W Laser Printer
Printer jam
Title:
How do I clear paper jams?
Description:
If a paper jam occurs, the Paper LED will flash as shown below.
c_panel_cover_open.gif Caution
    After you have used the printer, some parts inside the printer are extremely hot. When you open the front cover or face-up output tray of the printer, never touch the shaded parts shown below.
  1. Remove the paper tray from the printer.
  1. Pull the jammed paper up and out of the printer.
  1. Open the front cover.
  1. Pull out the drum unit and toner cartridge assembly slowly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
c_hl20_03221.gif Caution
    To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
  1. Open the back cover.
  1. Pull the tab toward you to open the rear chute cover.
  1. Pull the jammed paper out of the fuser unit. If the jammed paper cannot be pulled out easily, push down the tab with one hand as you gently pull the paper out with other.
  1. Close the back cover.
  1. Push the lock lever down and take the toner cartridge out of the drum unit. Take out the jammed paper if there is any inside the drum unit.
  1. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
c_hl20_025121.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Put the drum unit and toner cartridge assembly back in the printer.
  1. Put the paper tray firmly back in the printer.
  1. Close the front cover.
    Make sure that the Paper LED is now off and the printer is ready.
Apr 05, 2009 | Brother HL-2040 Laser Printer
Paper jam on Brother HL-1270N
Title:
Description:
Feb 23, 2009 | Brother HL-2040 Laser Printer
Hi there I have a brother HL-2170 W and have a page in the machine that is jammed. I actually turned the power off in the middle of a print job. What do I do? when I turn the power on the error light...
You should be able to solve your issue by following the first 7 steps below for clearing paper jams. After that put your printer back together and see if it starts working. If not, follow the rest of the steps and you should be fine.
    HOT SURFACE
    CAUTION
Jan 11, 2009 | Brother HL-2170W Laser Printer
JAM
The tape can't be rewound into the casette once the label has been made because the clear portion has been laminated to the label back.
Jul 28, 2017 | Brother P-Touch 1180 Label Printer
Label Maker HELP!! Brother ptouch 1180
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Computers & Internet
Brother P-Touch 1180 Label Printer Logo
6,549 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
