Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
How to disassemble doors - Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
  • 553 Answers
On the top of the Refrigerator, there is a hinges on both side covered by a plastic cover, take out the cover by fliping it and you will see the bolts on it, remove it one at a time, try to support the door so that it will not fall out. after romoving all the bolts, you can take out the hinges then full up the door slowly. This method is for removing the door from the body
If you would like to remove the plastic trays of the door, you see the rubber magnet around the side of the door, underneath that magnet are screws for attching the tray to the door, remove it all to detach the tray from the door
Posted on Nov 13, 2009
Model E130BM55HSC. How can I replace lower door handle bracket?
Hello Teresa, thank you for your inquiry!
I understand that you need assistance replacing a component on your Electrolux microwave. In order to replace the bracket you would need to disassemble the door. You should seek help from a professional technician for proper assistance with the disassembly. This will help you avoid any personal harm of improper disassembly of the microwave. Best of luck! -Matt
Mar 09, 2016 | Electrolux Microwave Ovens
2008 Hyundai Accent 2 door hatchback- passenger door is stuck and won't open from either inside or outside. What can I do without paying a lot?
Unfortunately not much. If the door will not open from inside/outside, it will most likely be a lock issue. In most cases, the door will need to be disassembled for access to the interior components. The door is not designed to be disassembled while closed. If put into the wrong hands for disassembly while the door is closed, you most likely will end up with interior panel damage which could cost more to repair/replace than having a pro complete the repair fist hand.
Mar 07, 2016 | 2008 Hyundai Accent
Door is loked on rear driver side want open
Won't open from outside? Won't open from inside? Equipped with power door locks? IF so, and won't open inside/outside, suspect stuck power door lock actuator. Sometimes working the lock/unlock button will make the door unlock. If not, the door will require disassembly from inside to determine what the failure may be. If the door needs disassembly while in the closed position, the paneling/clips may get damaged FYI
Dec 22, 2015 | 2001 Chevrolet Lumina
Model fxus6how. How do I remove the door to clean between the two layers of glass?
Moira,
Unfortunately you probably will not be able to clean between the glass. Those usually come as a sealed package and are not able to be separated. You can try taking screws out around the perimeter of the door and remove the glass pack, but I doubt that you will actually be able to separate that glass pack. Sorry!
May 15, 2015 | Ovens
DGE Microwave door disassembly for a JVM1790SK01
Normally you have to separate the door panels as shown in the below.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Jan 17, 2014 | Microwave Ovens
Need to replace battery door.
i have not replaced the battery door but have disassembled an S5000 following the service manual
it looks like once you complete the first step 'Removing the R CABINET ASSY' you can withdraw the hinge pin and replace the battery cover without any more disassembly [see attached image]
Nov 29, 2011 | Fuji FinePix S5000 Digital Camera
GR556LRKS How do you disassemble the door to replace the hinges?
If your Whirlpool is anything like my Kenmore,you just open the door to the first stop,(open about 6")and just pull up.If your door has a glass front,be very careful where you set it.I broke my glass.I was playing with the hinge.
Dec 08, 2009 | Whirlpool GR556LRKS Electric Kitchen Range
Key is stuck in door 2000 Volkswagen Cambrio
You basicly have 3 choices:
1. Take the car to a locksmith or have a mobile locksmith come to you and they can usually "pick" the broken piece out of the door lock and make sure that the lock will work properly with another key.
2. Disassemble the door and remove the lock and take it to a locksmith for repair.
3. Replace the lock entirely. (Which will also require disassembly of the door.)
Oct 18, 2009 | 2001 Volkswagen Cabrio
GE model PSC23SGRC SS refrigerator freezer door disassembly
Access from front of freezer door. Trim is just pushed into friction holders. Selector area snaps in. Phillip screws under that removes ice shoot.
Sep 16, 2009 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Food burned onto oven glass
you can disassemble door and clean glass,(if you can disassemble door).
Dec 27, 2008 | Electrolux 30" Self-Cleaning Freestanding...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
102 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
