Typewriter keys only print half a letter - Office Equipment & Supplies
  • Dick O Reilly May 11, 2010
    A make and model? DickyO
  • dick davis May 11, 2010
    what brand and model?
    Scholar:
  • 49 Answers
In general, there are two possible causes for this symptom. 1. The ribbon is not fully in front of the typeface at impact. 2. The typeface is not in the proper position at impact. Depending on the model of typewriter there can be different causes for these two conditions, for instance, on a manual typewriter, that has a manual shift key, it is possible that the segment which travels up and down when depressing the shift, is not in the proper position, thus , when the typeface contacts the paper, the curvature of the typeface does not match the curvature of the platen. This can cause the top or the bottom of letters not to print. Likewise on an IBM Wheelwriter, it is possible for the platen itself to be loose which can cause just the top of letters to print. Observe the ribbon lift position and installation. Check the hammer, printwheel, platen,
Posted on Nov 16, 2009
Some letters like A print half letter
need to know the make and model of the t/w. could be the typeslug has broken or come unsoldered if it is a typebar machine. Look at the charachters on the key that are bad to see if they are damaged or loose or out of alignment.
Oct 16, 2014 | Royal Office Equipment & Supplies
Ibm wheelwriter 10 only typing half the letter
If it is only one letter, it could be broken in half. Pull the printwheel out and look at it. If it is all charachters, push down firmly on the platen on the side where the print is worse. It should click back down into place. Sometimes the platen unlatches.
Apr 04, 2014 | Brother GX-6750 Typewriter
Printing on the top half of the characters
Is your platen snapped down all the way? Can you look at the ribbon and see where the letters are striking the ribbon?
Apr 01, 2014 | IBM Office Equipment & Supplies
Wheelwriter 30 series II. was typing OK but now get only less than half of letter to print. replaced ribbon same thing. tried adjusted ribbon (now sure was in right area) and still only printing less...
If it is printing only the tops of the letters the platen has worked loose. Press down firmly on both ends it should snap into place. If the print is generally bad the plastic print solenoid cap is probably broken. We sell them for 20.00 includes shipping and instructions.
DickyO
Cleveland Business Machines
216-241-0027
May 21, 2011 | IBM Wheelwriter 30 Typewriter
I am only getting half of the letters, and it is stuck on del,typing how can I get it off delayed typing?
I'M assuming this is a wheelwriter 30 or similar. On the R. side of the keyboard is a key that says print mode press that and the dl prt will go off on the display. If you are only printing the tops of the letters the platen is probably not fully seated in the side frames press down firmly on both ends it should snap into place.
DickyO
Mar 16, 2010 | IBM Wheelwriter 30 Typewriter
Only a portion of the letters are printing on the paper.
Sounds like the platen has worked loose. press down firmly on both ends of the platen (black rubber rol) it should snap back into place.
DckyO
Jul 02, 2009 | Lexmark Wheelwriter 3000 Typewriter
Typewriter not working
Look at the ribbon. If only the top half is beig printed on then the ribbon lift is out of adjustment or the ribbon is in wrong
Apr 21, 2009 | Royal Office Equipment & Supplies
Keystroke on prints top half of letter
Most likely the platen is not fully seated press firmly on buth ends of the platen (black rubber roll) it should snap into place.
DickyO
Jan 29, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
IBM Wheelwriter 30 series II - prints only half a letter
If it types only the top half yhe platen is probably not all the way in. Make sure the 2 black latches are lined up with the side frames then press down firmly on both sides of the platen.
DickyO
Apr 14, 2008 | IBM Wheelwriter 30 Typewriter
Only typing half letters and numbers
On the WheelWriter series, sometimes the platen may pop out of position, causing only half the letters to print. If this is the case, easially solved... Using the left and right platen knobs, firmly push down to lock it back in place. Hope this helps....MediaMan
Jun 06, 2007 | Lexmark Wheelwriter 1500 Typewriter
263 people viewed this question
k24674
jasbo
jasbo
