Clean the ramp and check for any burrs or edges that might be hanging the rounds up. The problem could be that magazine as well. Why did you get a new magazine? Is it a factory mag or third party? In my opinion, the 3rd party mags are junk.... Is this a new gun?
There are a few screws on the handle, remove them and it comes apart in 2 pieces, the trigger assembly will then come out. Disconnect the trigger from the wires and replace. Any Bosch service depot should keep this part in stock.
I thought I answered this a while back? You have a 30-30 win or marlin with a round stuck in the mag and you can't get it to move? Is it the right bullet? Take off the end screw and try to bump that thing out of there after removing the spring. You can try to drop the lifter out of the bottom of the receiver, and get to it from there, maybe after removing the end plug, you can get a dowel in there to push it through. Hope this helps.
I feel you need to learn a lot more about this weapon. The information you seek and a lot more is available at this site. Please be careful, this rifle was made to kill.
Check in the base of the torch and you will see the spare bulb. you need to pull the spring out to get at it. Next unscrew the top off the torch to expose the bulb. The bulb is easily removed by gently pulling straight out. Replace the new bulb in the same way, lining the two pins up with the holes (doesn't matter which way round) and wipe the bulb clean of any finger grease etc. Screw the top back on and replace the spring in the base before screwing the base back on.. Replacement bulbs, and all other parts for that matter, are easily sourced at any good outdoor store that stocks MAG.
Try putting the original magazine back in.The tapco mag probably does not have the vertical extension that holds the bolt open.Compare the two mags side by side.Good Luck
