Question about Garden
Fuel tank is broken. part number is required - Garden
    President:
  • 2,220 Answers
There are probably 10 active chainsaw manufacturers today and in excess of 50 no longer in production. Each of them produce or produced 5 - 20 models. Which one of these do you need to repair/replace? A serial number is often needed to provide the required parts list.
Posted on Nov 13, 2009
  • dontbother10
    dontbother10 Nov 14, 2009
    A little math results in over 1,200 fuel tanks. Which one would you like?
Car dies on right turns, will restart, will not stay running
one of two things come to my mind in hearing this , 1st damaged inertia pump switch (this switch shuts off fuel pump in case of high Inertia-wreck) 2nd the fuel pick up or baffles inside fuel tank have broken off this will require the removal of the tank for a look at it
Mar 01, 2016 | 1997 Ford Thunderbird LX
Petrol per km
Note the odometer reading. Fill the tank completely. Drive for 500-2000 km, refilling the tank as necessary, and recording exactly how much fuel is required each time to refill. At the end of the test, refill the tank one last time - recording how much fuel it required - and note the odometer reading again.
Add up all the fuel used in the entire test, NOT including the first fillup but INCLUDING the last one. The result is the fuel consumed during this test.
Subtract your starting odometer reading from your ending odometer reading. The result is the exact number of km traveled during this test.
Divide the number of km by the number of liters (km/l) to get your average fuel efficiency.
Aug 12, 2014 | 2009 BMW 325Ci
1994 Oldsmobile 88 Olds stalls around turns
You either have a broken gas tank fuel pump well baffle or the fuel gauge is incorrect and you really are about to run out of gas. Both requires the fuel tank assembly be pulled out of the car and the baffle checked around the fuel pump or the fuel pump replaced if the baffle is ok.
Oct 03, 2012 | 1994 Oldsmobile 88
Fuel gauge only comes up when the key is turned off
Sounds as though you have a ground strap that has broken or is not making good contact.
depending on the year make and model of the vehicle in question , I would make some suggestions to correct the problem. Including , to run a ground to the sending unit or fuel tank...
Aug 21, 2011 | GMC Canyon Cars & Trucks
Mcculloch titanium 3000 multi-tool.Small fuel pipe has come adrift in tank with filter still attached.
When you say has come adrift, i can only think that the hose has perished and broken away from the top half of the pipe, and is now just floating around in the tank, this will now require a new hose from tank to carb.
May 20, 2011 | Garden
1999 Chevy Cavalier fuel gauge doesn't regulate the amount of gas properly. What causes this?
Hello
This problem is caused by a defective fuel gage sending unit, the sending unit is located inside the fuel tank and is part of the fuel pump module but is sold separately in a kit from ACDelco, to replace the fuel gage sending unit requires the fuel tank be removed from the car. Below is a price and part number courtesy of rockauto.com
ACDELCO Part # SK1189
SENSOR KIT, FUEL LEVEL PRICE: $102.89
Dec 22, 2010 | 1999 Chevrolet Cavalier
Do I require the fuel tank sending unit wrench number 310-123 in order to remove/install the fuel pump sending unit on a 2002 F150. Can a brass (non-sparking) punch be used instead? If the wrench is a...
i fixed my windstar fuel pump problem.. fuse number 5 was blown.. replaced the fuse and all is better.. however i do hear an electrical spark when the fuel pump disengages .. (turning the key to the acc position)
Dec 29, 2009 | 2004 Ford F150
2006 Chevy Trailblazer fuel gauge stays on empty
Could be a
1. Fuse - not likely, I'd expect other instrument panel problems.
2. Broken wire from fuel gauge
3. Bad fuel sender in fuel tank. Normally requires dropping the tank.
Vehicle is not that old, would think it is still under warranty?
Jul 31, 2009 | 2002 Isuzu Axiom
Fuel gage
Classic symptom of a failing sending unit. It's inside the tank and on most cars it's replaceable separate from the fuel pump. I usually see them in the $45-75 range. Some cars have an access panel under the rear seat or in the trunk, where others require the fuel tank to be dropped - I'm not sure offhand which your car requires, however.
Sep 29, 2008 | 2002 Oldsmobile Intrigue
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
