Question about GE Profile Spectra JGBP90 Gas Kitchen Range
My pilot light wont light and my oven will not come on the gas top burners are fine how do i fix this problem
  • 187 Answers
Later model ovens don't usually have an actual pilot light in the form of a flame. It is usually some type of a spark or heated coil ignition system. It is usually located under the flame spreader and bottom plate in the oven. It is a safety system to keep gas from collecting in your home. You can remove the oven bottom and see the mechanism close by to the gas inlet tube. When you turn the gas on, you should be able to see either a small spark or bright red coil. A replacement can be purchased and installed, but it is probably a job for a technician.
Posted on Nov 13, 2009
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
Hotpoint gas stove. burners work, oven and broiler do not.
Probably the safety valve. This unit broils and bakes off the same gas burner. A spark ignitor lights the pilot and this save gas because no standing pilot is needed. It takes a few minutes for the thermocouple bimetal combo to release the gas. When the temp gets to the desired rate then the bulb on the oven control closes off the flow of gas. To recap: The flow of gas comes from a regulator along a rail which supplys the gas to the top burners and the oven control. older models had pilot light tubing going down to the oven and to the top burners. This newer style uses a spark module to light off the top burners and the oven. So when yall turn the the oven on the spark ignitor lights the pilot first and then after the mercury bulf thermocouple heats up the bimetal inside the valve opens allowing gas to flow out to the pilot and ignite the gas burner. the temp rises and the mercury bulb oven control expands closing off the flow but not the gas safety valve. I would suspect the safety valve on this one.
May 09, 2011 | Hotpoint RGB528 Gas Kitchen Range
Gas stove top works, broiler works, oven does not
is it electronic iginition? are you asking about top burner pilots? if so there are under the top in the middle beteen each side of the burners 1 pilot does burners on right and 1 on left. oven pilots are underneath you have to remove bottom door look in there at back and look up and you'll see it. if its a electronis ignition range you have no pilots!! glow coils and sparkers....
Feb 06, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
The pilot light on my caloric gas oven lights, but the oven burner doesn't light. The oven is old, but only used for 2 months before being put in storage for 13 years. The stove top burners work fine,...
there is a thermo copler ( temp sensor ) that tels the gas sensor "pilot is on give me gas" the copler needs to be cleaned or replased
Nov 26, 2009 | Ovens
Gas oven Hotpoint RGA 720 I can't light the oven pilot
There is likely some kind of gas line blockage or valve problem. This is not a do-it-yourself fix. Call a repair person.
Oct 15, 2009 | General Electric Hotpoint® RGA720PKWH Gas...
DCS commercial range #36-6-1L running propane. 6 burner tops light fine, but the oven has just stopped lighting after 7 years. When I try to relight the pilot light (depress red button, click cliker) it...
You might need a new thermocouple. The thermocouple tells the oven that the pilot is lit and that it is ok to let gas into the oven. It is the metal rod that is connected to the pilot. They are fairly cheap and easy to install.
Jul 06, 2009 | DCS RGS-305 Professional Gas Kitchen Range
Gas oven not working pilot light is out
1 of 2 things will normally happen and most of the time both things will break. You have two main componets that will wear out 1)your igniter 2)the gas burner tube. Usually what will happen is the gas burner tube allows gas to come out of 3 very small holes-over time and with help from grease, the 3 small holes will turn into a large hole and will allow too much gas to come out and it will destroy your igniter also. Luckly RepairClinic.com sells both pieces in a kit. You can check you igniter with multimeter for continuity (if it is broke-safety kicks in and wont allow gas to work).
May 01, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Maytag gas oven doesn't heat, but oven's pilot light is on.
Get the oven checked out by a professional, if you have a gas leak you can easily blow up the entire house and you with it. I think you have a faulty gas valve based on what you wrote
Mar 03, 2017 | Ovens
Gas oven dosnt work
the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
Dec 14, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Lighting a pilot light in a 30 year old roper gas range
Lift the top lid and look for a cylinder or something similar with tubing going into it there should be a button of some sort on the side. if you are lucky the button will have a red cap on it. press the button in and light the pilot inside the oven. hold the button for a minute or so until the pilot stays on. kind of like lighting a water heater.
Oct 31, 2007 | Ovens
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
156 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
