Question about RPM Vox 750GB 3.5in USB 2.0 & eSATA External 7200rpm - EXSA-35C-750G5K 750 GB Hard Drive
How can i get in touch with VOX? The power cord has a defect.
  • yadayada
    yadayada May 11, 2010
    who is VOX?
I have the same problem...the power supply/cord went dead...not light on the power block. Tried all the contact information on the VOX website with no response. These guys are terrible! If you do find a way to get a hold of them please let me know. :)
Posted on May 25, 2010
    Master:
  • 956 Answers
Type in too Google search box (VOX) then go surfing entering details that you seek. There should be a free download and aftersales! Good Luck!
Posted on Nov 13, 2009
My Kobo Aura is not recharging. The charging unit seems "dead". Can the charger be replaced?
it can
Kobo Aura / Aura HD compatible Advanced Rapid Wall AC Charger ...
https://www.amazon.ca/Kobo-compatible-Advanced-Rapid-Charger/.../B00GNB08JS
Gomadic Powerful High Wattage wall charger for home or travel use. Customized circuit design is based on the latest in power regulation and is tailored to the ...
Kobo Aura One Charger, BoxWave® [Wall Charger Direct] Wall Plug ...
https://www.amazon.ca/Kobo-Charger-BoxWave®-Direct-Touch/dp/B01MA3NLF8 Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc 7 10 HD; Kobo Touch Glo Mini Aura Hd Ebook Tablet.... ... HQRP Micro USB Charger / AC Adapter for Kobo Arc / Arc 7 / Arc 7HD / Arc 10HD / Mini / Glo / Touch / Aura / Aura HD / Vox.... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid ...
Kobo eReader Glo USB Cable - Micro USB: Amazon.ca: Cell Phones ...
https://www.amazon.ca/Kobo-eReader-Glo-USB-Cable/dp/B00AXZVE48 Rating: 4.7 - ‎11 reviews
Kobo eReader Glo USB Cable - Micro USB: Amazon.ca: Cell Phones & Accessories. ... Cable for Kobo eReader Kobo Mini, Kobo Touch, Kobo Aura & Aura HD... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc ...
Chargers & Cables - Electronics: 146 products available ' chapters ...
https://www.chapters.indigo.ca/en-ca/electronics/chargers-cables/500151-cat.html Results 1 - 24 of 146 - Shop Online at Chapters.Indigo.ca for a wide selection of chargers & cables products, 146 items available. Enjoy free shipping on orders ...
kobo aura charger Google Search
Sep 24, 2017 | Tablets & eReaders
Vox transmits all of the time
Is there a VOX Sensitivity setting? If there is, try setting it lower. If not, it's probably defective.
Feb 19, 2014 | Yaesu Vertex/Standard VC27 Earpiece/Mic
I have a vox valvetronic 50, which keeps blowing fuses as soon as it is switched on and leaves a burning smell. any ideas?
One or more parts in the power supply section is defective. I would recommend taking/sending the unit to a repair depot.
Oct 20, 2013 | VOX Amplification Vox VT30 Valvetronix...
We recently purchased the Motorola MS350 radios with headsets. We plugged the headsets in and turned the power on, but are unable to communicate back and forth in handsfree mode. We can switch to PTT and...
The three things which come to mind are:
1) Is the headset the VOX headset intended for the radio model? Sometimes the rings on the plug do not match the internal points of contact if it is not the intended headset. Not all headsets are VOX capable.
2) Is the headset plugged in all the way. (You mentioned plugging in and then turning on. This is good. You must always have the radio turned off when plugging or unplugging an audio device.)
3) Try pressing the PTT on the headset cord one time before switching the dip switch to VOX. (Assuming you have a headset with the small box in the line.)
Lastly, if you continue to have difficulties, contact Motorola at the 800# provided in the user guide. They should be able to assist you.
Best regards.
Sep 23, 2013 | Motorola Ms350r Radio Pack
We recently purchased the MS350 radios and are trying to use them handfree with the headsets. We plugged in the headsets, turned on the radios, but are unable to communicated back and forth using the VOX...
Check your VOX/ iVOX settings. You will need VOX for using an audio device.
Best regards.
Sep 23, 2013 | Motorola Hands-free Headset,for 2-Way...
Maytag model mer6770awc keeps showing f1-1 error code
Hi rayrolls,
The F1 fault code indicates a defective touch pad or clock (ERC). To resolve this issue, you need to replace touch pad or clock (ERC).
The steps below will help you to determine whether the ERC or the touch pad is defective.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope it helps.
Thank you for using FixYa.
Sep 14, 2011 | Maytag Kitchen Ranges
Power to the outlet, but apparently no power at the touch pad - it is non responsive with no indicator lights on.
1. No power to the washer
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
2. Lid switch
The washing machine may not function if the lid switch is defective. The switch is usually located near the door. Replace if found defective.
If all the above checks out OK, replace the touch pad.
May 30, 2009 | Kenmore 2205x Top Load Washer
Okay on my 2 way radio i turn wox on and then turn the radio off plug the headphone in turn the radio back on and then the vox is turn off again
you miss to save your last program,after you turn to vox mode you must to save ,or the mode will back to before you change
Feb 27, 2009 | Motorola Talkabout SX700 2-Way Radio
Dishwasher will not do anything
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Nov 30, 2008 | Kenmore 15129 Built-in Dishwasher
Motorola T5622 VOX Not Activating with Autocom Sys I have an Autocom (Kit 300) motorbike coms system. I bought the accessory cord that interfaces to the Motorola T5622, for VOX I have followed the Motorola...
Hi Folks, two seperate checks to do - to check vox on autocom and transmit on motorola. With the T5622 unconnected to anything, does the push transmit button work - e.g. does it make the beep noise at the end of transmission?
Does your autocom work with any other sound sources - i.e. mp3 player so you can hear music. Does this mute when you speak ? (it should if vox is working). Note that in this setup vox is provided by autocom - NOT BY THE T5622. The instructions you mention are for the motorola vox kit.
Wire the two together and you should get the motorola beeping through your autocom at the end of transmit - that's what my kit 200 does with my T5622.
Mar 13, 2008 | Motorola Talkabout T6310 (14 Channels)...
RPM Vox 750GB 3.5in USB 2.0 & eSATA External 7200rpm - EXSA-35C-750G5K 750 GB Hard Drive Logo
260 people viewed this question
Top RPM Computers & Internet Experts
terminalcon
JonSnell Electronic
JonSnell Electronic
Are you a RPM Computer and Internet Expert? Answer questions, earn points and help others
