Question about Motorola Mobility PEBL U6 Cellular Phone
Screen on Motorola Pebl wn't display anything...
Can you fix the display screen on the pebl
Depending on where you live you may find a Motorola Authorized repair facility to repair your device.
Mark
Motorola Support
Aug 20, 2014 | Motorola Cell Phones
Need unlock code for a motrola pebl
Get the unlock code for your Motorola PEBL U6 model mobile here http://www.theunlockspot.com/motorola-pebl-u6/rs10wp9/ , it gives the easy instructions for getting the code for your mobile ........
Nov 29, 2011 | Motorola Mobility PEBL U6 Cellular Phone
Hello, I have a motorola pebl u6 - black (t-mobile), and the front screen has cracked. Is it possible to repair?
It can be repaired,you can do this yourself or send the phone to a service center,of course first option is cheaper,you here a tutorial here if you want replace the lcd screen yourself:
http://www.formymobile.co.uk/Dismantle/u6disassembly.htm
Feb 16, 2011 | Motorola Mobility PEBL U6 Cellular Phone
How to change lcd screen on motorola pebl u6?
As on most Motorola phones, the lens that covers the main LCD must be carefully removed to access the screws underneath to pop off the exterior faceplate. Once that is done, there is a silver main casing that protects the LCD. Pry up the side to remove it. You will then be able to access the LCD for removal.
Mar 11, 2009 | Motorola Mobility PEBL U6 Cellular Phone
Motorola pebl screen blank
Yes , the flexcable is the problem but i do not advised that you do that yourself....it is best to take the phone to a mobile service shop and have them replace the cable for you.
Sep 30, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Reading deleted text messages o
deleted text's cannot be recovered by phone but your service provider can get you a copy of your text's that goes into your journals
May 13, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Motorola pebl u6 fitting new housing instructions
There ares 4 screws (#6 torq) on the back side where you replace the battery. take those out and the phone come apart. Be carefull because the main board, key board and all will come apart with careful prying. Also watch out for the ribbon cable that connects the LCD screen to the main board
Apr 05, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Motorola Mobility PEBL U6 Cellular Phone Logo
195 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
