Question about D-Link DI-634M Wireless Router (DI634M)
My DI-634m Is not giving me an IP address - D-Link DI-634M Wireless Router (DI634M)
  • Hockeycave Nov 13, 2009
    It wasn't working wired OR wireless. It is fixed now I had to take the router apart and re-seat the antenne card. Thanks for the response
  • fkmJag May 11, 2010
    Can you connect to the network at all? Does it ask you for a passcode? If you dont type in the passcode correctly then you won't get an ip address.
  • 2,260 Answers
Are you trying to connect to the wireless network ?
If you are not getting the IP address then you might not be connected to the wireless network.
Make sure that you know all the correct wireless settings of the router.
If your network is secured then you have the correct network key.
If you are not sure about the wireless settings of the router then you will need to access the router set up.
Click Here for step by step solutions
Posted on Nov 14, 2009
Can I use a D-Link DI-634M as a repeater? how?
Sorry, no, the DI-634M does not have the repeating function.
Mar 06, 2011 | D-Link DI-634M Wireless Router (DI634M)
I'm using dlink di-634m router, now i'm trying to block facebook but i don't know how. i tried using schedules, firewall setting but still my staff can get access to it.
Step 1 Open a web browser and type the IP address of the DI-624M in the address bar (default is 192.168.0.1). Press Enter.
Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK.
Step 3 Click the Advanced tab at the top and then click Parental Control on the left side.
Step 4 Select Enabled below URL Blocking and configure the following:
  • URL String - Enter a domain name (such as microsoft.com)
  • Start IP - Enter the first IP address to apply URL Blocking to
  • End IP - Enter the last IP address to apply URL Blocking to
Step 5 Click Apply to save the new settings.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 20, 2010 | D-Link DI-634M Wireless Router (DI634M)
How do u access ur wireless setup instructions for d-link routers on internet explorer?
Heres a link to the support site http://www.dlink.co.uk/cs/Satellite?c=TechSupport_C&childpagename=DLinkEurope-GB/DLTechProduct&cid=1197319378173&p=1197318962293&packedargs=locale%3D1195806691854&pagename=DLinkEurope-GB/DLWrapper
Quick setup from here ftp://ftp.dlink.co.uk/di_broadband_gateways/di-634m/di-634m_qig_100.pdf user manual from here ftp://ftp.dlink.co.uk/di_broadband_gateways/di-634m/di-634m_manual_100.pdf
Connect the PC to the router by cable then to log into the router using the default settings
  • Open the Web browser.
  • Type in the IP Address of the Router http://192.168.0.1).
  • Type admin in the User Name field.
  • Leave the Password blank.
  • Click OK.
now goto the wireless settings on the router to see the settings being used
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 01, 2010 | D-Link DI-634M Wireless Router (DI634M)
Port forwarding of Router D-Link DI-634M
Yes this router has a port forwarding capability, to know about that and how it is done from this router check this link.
http://portforward.com/english/routers/port_forwarding/Dlink/DI-634M/DI-634Mindex.htm
Feb 23, 2010 | D-Link DI-634M Wireless Router (DI634M)
How to reset PW
type ip address of the router on the browser
put username and password
go to setup page
here you can remove old password
pls put new password
Nov 02, 2009 | D-Link DI-634M Wireless Router (DI634M)
Connecting D-Link DI-634M to HughesNet HN9000
Both units can not have the same Gateway IP.
Do this:
Hook your PC to the HN9000. Do an ipconfig /all
Write the IP info down.
Then open up the D-links set up page and set it to a static IP using the info you gathered from the HN9000. Select an IP in the range that the PC picked up. I usually use .100. Also, when you set it statically in the D-Link, make sure that you type in the Primary and Secondary DNS.
Once you set the D-Link statically , you should be able to browse the Net through the D-Link.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 24, 2009 | D-Link DIR-625 (790069292637) Wireless...
How to reset the d-link di-634m wireless router
go to this link to to reset your d-link 634m manually: http://www.retrevo.com/pdf/426bh043/6/Hardware+Overview#q=D-link+DI-634M
Apr 14, 2009 | D-Link DI-634M Wireless Router (DI634M)
What is the d-link part number for power adapter for D-link Di-634M router?
what is the d-link part number for power adapter for D-link Di-634M router? How can I get this?
Mar 28, 2009 | D-Link DI-634M Wireless Router (DI634M)
I hate it when ISPs give you devices that dictate how your network has to be setup. They should just give you a modem which give a public IP to whatever connects to it.
For this to work you have to connect the cable from the hughes box to your router on one of the four regular jacks on the back NOT the internet/wan jack you would normally use.
Set the IP of the Dlink to 192.168.0.254
Subnet mask 255.255.255.0
default GW 192.168.0.1
This SHOULD allow the router to act like a switch. I have a linksys that has an option to make it function as an access point , which is what you need for this modem, but I dont see any option for the d link you have to do that.
Hughes have a knowledgebase which may be of some use to you.
Here
Mar 05, 2009 | D-Link DI-634M Wireless Router (DI634M)
I can not connect to my vpn when using wireless dlink. i have no problem accessing my vpn network when direct hook up.
Try calling your VPN network provider and asked them for ports numbers and IP address that needs to be opened on your router and give that information to your router manufacturer and have them open the said ports.
Jan 17, 2009 | D-Link DI-634M Wireless Router (DI634M)
D-Link DI-634M Wireless Router (DI634M) Logo
152 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
