Question about Compaq Presario 700 470024-192 Notebook
Laptop will not power up. replaced battery and not not working. Any suggestions?
    Champion:
  • 206 Answers
Dead mb
Posted on Nov 13, 2009
My laptop wont turn on without a charger
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue. Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop. Third-party utility
Use a third-party battery utility to determine the total capacity of the battery. For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter. In most situations it's a bad battery.
Hope this helps.
Jan 21, 2013 | Dell Inspiron Computers & Internet
Tip
Laptop battery does not charging
Following could be the reasons for such failure:- <br /> <b>Computer AC/DC cable is bad not allowing the computer battery to charge</b> <br /> Verify that the AC/DC cable is not bad by removing the battery from the laptop and seeing if the computer can power on without the battery. <br /> <b>Battery is bad and/or old</b> <br /> If the power plug is good it's likely that your laptop battery is bad. If you're using a laptop with Microsoft Windows consider getting and installing BatteryCare on the computer to look at the total capacity of the battery. <br /> Try leaving the laptop connected to the power with the battery inserted for at least two hours. If the battery still doesn't seem to charge, i suggest having the battery and/or the laptop serviced or repaired. <br /> If the computer and/or battery is not in warranty i suggest replacing the battery as it's very likely that it is just a bad battery. <br /> <b>Battery charger board is bad</b> <br /> If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It's recommended that the laptop be sent in to be repaired. <br />
on Dec 24, 2010 | Computers & Internet
LG laptop battery
Third-party utility
hope this helps
Sep 06, 2012 | LG LB32111B, LB52113B, LB52113D,...
Enercell Laptop Battery Charger Doesn't Work When Plugged In?
Third-party utility
hope this helps
Sep 04, 2012 | Computers & Internet
Computer will not start up
Third-party utility
hope this helps
Aug 30, 2012 | Dell Inspiron 1501 Laptop
No battery is detected
Third-party utility
hope this helps
Aug 24, 2012 | Computers & Internet
Charjer is conected but bettary is not cherzing
Battery is bad or old
Try leaving the laptop connected to the power with the battery inserted for at least two hours. If the battery still doesn't seem to charge, we suggest having the battery and the laptop serviced or repaired.
If the computer and battery is not in warranty we suggest replacing the battery as it's very likely that it is just a bad battery.
Dec 26, 2011 | HP Computers & Internet
T23 laptop. Put in new battery. WIth battery in
poor battery contacts or dead battery cell doing this flickering
replace the battery if contacts are clean inside the computer
Jul 06, 2010 | IBM ThinkPad T23 2647 Notebook
Dell Inspiron 6400 laptop! I replaced my CMOS battery,I also bought a new laptop battery, The AC Adapter works [lights up when you plug it in] and when you press the laptop's power button, the 3 lights...
This was very keen of you to try. unfortunately, if you tried all of those things it is likely damaged to the power circuit on the motherboard itself.
This will require a tech to remove and replace it. This ranges in cost, but is usually $250-$400.
Best of Luck,
Sagacious1
Aug 07, 2009 | Dell Computers & Internet
Compaq nx6325 laptop will not power up
Perhaps try taking the battery completely out of the laptop for 5-10 minutes and then replacing it and trying again. My Dell wouldn't work on battery alone but was fully charged and leaving the battery out for a while before replacing it worked for me. Also keep your eye on how much the battery charges. It may be a faulty AC adapter also. Best of luck.
Sep 24, 2007 | Toshiba Satellite Pro L300 Notebook
Compaq Presario 700 470024-192 Notebook Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
