Question about Aurora Global AS702MX Shredder
I put in too many sheets of paper and it jammed. I was able to get the paper out but there are shredded pieces still in there. I have extracted a bunch with tweezers but the shredder still does not work. SOS
  • 2 more comments
  • pumicepal Nov 14, 2009
    HI Greg - I put it on reverse and the shredder miraculously spewed out some
    paper. It is looking much cleaner on the back. I turned it off as per your instructions and tried to get as much with tweezers as I could in the front and got a lot. I turned it on and it not only will not accept paper but now reverse does not work.
    Now what?
    How come reverse worked just a few minutes ago and now it does not?
    What do you mean by "good luck getting it repaired?" I sense your sarcasm, but do not want to read to much into it... can you be specific? I f I am unable to get it to work with your help then should I call it a day?
    Thanks.
    Jane
    Greg - since I sent that last email reverse now works and I do not see any paper in on top or bottom, but it will not accept any paper to shred.
    Now what?
    Jane
  • pumicepal Nov 17, 2009
    Hi Greg - thanks for your on-going feedback. I am almost there! The credit card part shreds. YAY!
    The paper part shreds if I have a bunch of papers (not more than 7!) but it will not grab just a single sheet of paper. Is that just par for the course? Shouldn't I be able to feed the sheets one at a time if I want and have it be functional? Thanks!!
    Jane in Boston
  • pumicepal Nov 18, 2009
    Greg - you are the best!! It is fixed and I am a very happy camper!
    Thank you!
    Jane from Boston
  • 1,959 Answers
Put the machine on reverse to back out any excess paper. Then, with the machine unplugged, using your tweezers and a tiny flathead screwdriver, you will have to dig paper out of the teeth. If after clearing all the paper you can see/feel (sometimes have to dig around down under near the top of the lip), plug it back in. If after all of this, you can't get the motor to work, then it's burned out. Best of luck to you on your repair.
Posted on Nov 13, 2009
  • 1 more comment
  • Greg Margossian
    Greg Margossian Nov 14, 2009
    Hi Jane, I was not being sarcastic, I was wishing you well on "your" repair of the shredder, not having to have it repaired. Based on your last post, the motor obviously works or reverse wouldn't have worked that last time. What happens is paper wraps itself around the gears/teeth both on the side you see, and on the other side. That's why it's important to get every last scrap out because you never know which scrap of paper is keeping your shredder from working. With the shredder head back in place on it's bucket (if you tested the shredder without it being in the bucket, it wont turn on) turn the switch back and forth from forward to reverse. Do this a couple of times to try to force the scraps of paper to where you can get at them and remove them. If during this process, the machine completely clears itself, you should be all set, if not, you need to unplug and dig some more. It can be a long process but assuming you get all the paper out, you should get it working again since we know the motor is good.
    Greg
  • Greg Margossian
    Hi Jane, there's a chance the switch isn't all the way in the Forward or Auto position. The switches are the cheapest part of the shredder and you will sometimes find that although the switch will read Forward (always on) it will actually still be in Auto. If you are able to put the machine in Forward (always on) try to feed a sheet of paper. If it won't feed, then the blockage is right in the feeder slot. That being the case, unplug it again, and go in right through the top this time instead of underneath. There really shouldn't be much there since you've already cleared it out both through reverse and by digging it out with tweezers. You're almost there, the motor works (that was my biggest fear, bad motor = new shredder) and you've got most of the paper channel clear, just clear the top out and it should work for you again.
    Greg
  • Greg Margossian
    Greg Margossian Nov 17, 2009
    Hi Jane! Im glad you have it working. It's possible the lens portion of the feeder got moved somehow while you were digging out scraps of paper. With the unit unplugged, feel around in the feeder channel for any "loose" parts or anything that feels or looks out of place. What may have happened is the sensor (basically 2 one on either side of the feeder channel) is out of alignment. To be perfectly candid, I'm not familiar enough with your shredder to tell you exactly what to look for, only in general terms. You can try feeding the pages sideways and see if it will take them 1 at a time or if it's a thickness issue, folding the page 2 or 3 times and feeding it that way. Apart from that, the fact that you have it running is a gr8 sign. Nice job, you should pat yourself on the back. A lot of people wouldn't expend the time and effort you did and would have thrown out a perfectly good unit.
    Greg from Haverhill
SHREDDER CONTINUALLY SAYS OVERLOAD EVEN THOUGH 2 SHEETS OF PAPER ARE INSERTED
It might need cleaning; mine had the shredded paper jammed in by cutters and some shreds got between the gears. First, try using a "cleaning sheet": a piece of paper lightly sprayed or smeared with vegetable oil or spray cooking oil. If that doesn't do fix it, the shredding mechanism, which has many parts, some of which are sharp as razors, might need to be disassembled and cleaned. Though I did that disassembly and cleaning, I would not recommend it to the casual DIY-er.
Sep 08, 2014 | Royal HG140MX Shredder
Qualcast manuals
Unplug it and look inside the shredding blades, especially around the spot usually near the center, where there is a pressure button. When paper hits it, it starts shredding. Chances are some pieces of paper have jammed just over it stopping paper from hitting it and switching it on. I have had to use long tweezers to work the jammed bits out... Once clear it will work again. Also using shredder oil every 50 sheets through will help it cut easier , and jam less frequently. Do not put too many sheets through together in a bunch. No staples...
Aug 25, 2014 | Office Equipment & Supplies
Omnitech shredder ot-nxc10pa
You must first unplug it and look inside the shredding blades, especially around the spot usually near the center, where there is a pressure button. When paper hits it, it starts shredding. Chances are some pieces of paper have jammed just over it stopping paper from hitting it and switching it on. I have had to use long tweezers to work the jammed bits out... Once clear it will work again. Also using shredder oil every 50 sheets through will help it cut easier , and jam less frequently. Do not put too many sheets through together in a bunch. No staples...
Aug 23, 2014 | Office Equipment & Supplies
Why does my paper shredder make a clicking sound when I try to shred a piece of paper?
Try putting a piece of paper in enough to start it running, but not so far as to go into the shredder. See if it will run for a minute or two. Sounds as though it may be over heating.
May 03, 2014 | Generic aurora as1016cd heavy duty...
Paper Jammed
I have had the paper jam in my shredder which was not a Fellowes. I removed the power plug from the wall and used old dentist tools to pick the pieces of paper out of the shredding mechanism from underneath. I did not need to remove the cover. After extracting some paper try using the paper reverse option.
Apr 02, 2014 | Fellowes P70CM Shredder
How are you? My name's Richard Park. I put some paper into paper tray and click "ok" for printing.After arranging the printer, when it starts and slide in paper along the tray. But it has...
People, please use the correct product category, and provide the brand and model number of whatever device has you asking for help!
I deduce this is some sort of printer, but I can't figure out where the CD/DVD COPY comes from; I never heard of a printer that also copies optical disks.
Assuming it is conventional paper printer, there is probably a shred of paper stuck inside the printer from a previous jam. It isn't in a paper jam sensor, since the printer doesn't detect it. When the new sheet of paper goes in, it gets bent over by the paper shred and jams. You should be able to figure out just where the offending piece is by carefully noting how far the sheet went before it was stopped, and examining the folded-over part to identify how far from the edge of the paper path the foreign object is located. You may have to use a dental pick to extract the shred, paper clip or whatever it is. Be patient and be careful not to break anything. If the problem is a paper shred, you may have to tear it apart and pull it out in pieces because it is probably all bunched up and stuffed in tightly. If in doubt, consider partially disassembling the printer to get at the problem area.
Nov 04, 2010 | Computers & Internet
I was shredding and I put 2 sheets in and the shredder jammed.
You don't mention if its x-cut or not......however, try putting some lightweight shredder oil on a sheet of paper and then shred the paper with the oil on it...do this a few times to get oil into the cutting blades then see if that has helped.
Mar 10, 2010 | Royal Office Equipment & Supplies
My shredder won't continuously shred a piece of paper. I have to reverse it then turn it on again multiple times to shred just one piece of paper. Can I fix this?
If it is a x-cut shredder try oiling ( with a lightweight shredder oil ) onto a sheet of paper then shredding the sheet of paper to get the oil down into the cutting teeth....also try cleaning the "eyes" which are in the middle were you insert the paper..( they may be dirty.)
Nov 19, 2009 | Office Equipment & Supplies
Shredder is jammed
hello. follow these steps:
  1. Turn the shredder off at the wall and unplug it. You DO NOT want to be poking round in those sharp blades and have it accidentally switch on!
  2. Take the top off the shredder and place it on a big piece of newspaper, or somewhere you can easily sweep up mess.
  3. Begin by getting a pair of tweezers and taking pieces of paper from one end of the shredding blades. This will loosen it up and give you more room to get the rest out.
  4. Carry on tugging the strips of paper out. It helps if you don't just pull a clump, but wiggle it from side to side. This will get the whole strip out, not just the top.
  5. If any pieces are curled round and you can't free them, cut them with the knife and then tug them out.
  6. Once it's mostly cleared, put the top back on and switch the shredder on. Put it on Reverse mode so it will spit the last bits back up for you to remove.
  7. If it's clear, continue shredding!
[edit] Tips
  • Remember to wiggle the paper, not just pull.
  • Shake it occasionally to get smaller pieces of paper out of the blades.
  • Try not to jam it in the first place (avoid loading a lot of paper or thick sheets of newspaper).
  • Use oil paper or performance oil to lubricate the blades on a regular basis. For an office shredder, medium to heavy usage can require lubrication as often as every three days.
  • To prevent the shredder blades from dulling, remove paper clips and staples before shredding. Shredding CDs and DVDs also cause premature wear & tear. Use the Disc Eraser (www.DiscEraser.com) if you have sensitive discs.
[edit] Warnings
  • Always turn the shredder off at the wall and unplug it! You don't want shredded fingers!
  • Be careful with the blades - they are sharp and you could cut yourself.
[edit] Things You'll Need
  • A pair of tweezers
  • A small, sharp knife
Oct 23, 2009 | Office Equipment & Supplies
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
Aurora Global AS702MX Shredder Logo
99 people viewed this question
Top Aurora Global Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Aurora Global Office Equipment and Supply Expert? Answer questions, earn points and help others
