Question about Garden
Gas in oil , misses out till it gets warm,right cylinder is cold.
  • dontbother10
    dontbother10 May 11, 2010
    Dual ctlinder? Gas in oil? I cylinder cold? Could it bad a bad piston or rings? Comperssion test on cold cylinder will probably pin point your problem. Lou
  • 85 Answers
SOURCE: engine misses when cold
2 drops of soap in a spritzer bottle on your coils and wires to check for sparks leaking sound like a spark problem
Posted on Mar 11, 2010
Testimonial: "Have tried to eliminate any spark grounding. In two minutes all is good, which is not enough time for heat drying. Will try to observe when dark out"
  • 8909 Answers
SOURCE: cold running problem starts ok missing and jerky
Is the choke sticking?
Posted on Jan 23, 2011
  • 32 Answers
SOURCE: GTS 2007 Cold start misses
sounds like an electrical problem and the best place to start from is the spark plugs and the relevant wires. the best way to check if that is the problem is to use a water bottle and spray around the spark plugs. A blue arc will mean that you need to check the plugs and the wires. Distributor and valves could be the othe suspects but start with the plugs.
Posted on Mar 31, 2011
SOURCE: 1999 FOD F150 5.4 TRITON .THE ENGINE STARTS COLD
My truck dose not turn on I put a starter an I get nothing its a ford 2004
Posted on Sep 26, 2011
rbfaber90
  • 1178 Answers
SOURCE: right brake problem , cold does not work , gets better hot
Sticking caliper, when it is cold the piston or glides don't move but when hot they slide better
Posted on Jun 12, 2016
Testimonial: "Great, thanks for the help, I was thinking caliper, but when put air to it it seemed to work fine"
Tiburon 97 cold morning misses cant go pass 2000,3000rpm.idles till warm but still misses
Does it get to operating temperature? look at replacing the coolant thermostat and the engine coolant sensor. Clean the throttle body also. Inside.
Jul 25, 2015 | Hyundai Motor 1997 Tiburon
1994 chevy s-10 6 cyl 4.3l automatic starts and runs rough till it gets warmed up?
ALL SENSORS GO BACK TO THE ECM(COMPUTER), THE OXYGEN SENSOR IS EXTREMELY IMPORTANT, TELLS COMPUTER CHANGE OR ADJUST FUEL DELIVERY, AMONG OTHER THINGS, FIX THAT PROBLEM, PROPERLY, THEN U CAN MOVE ON. NEW AIR AND FUEL FILTERS FOR SURE ! IS BATTERY FULLY CHARGED ? THE GAS WE BUY IS GARBAGE, ETHENOL IS KILLING OUR ENGINES, ADD SOME PREMIUM FUEL, NEXT FILLUP, ADD STABIL 360 FUEL STABILIZER TO TANK, ARE YUR SPARK PLUGS AND WIRES IN GOOD CONDITION ? TUNE-UPS DO HELP. FUEL INJECTORS IF THATS WHAT U HAVE, GET DIRTY, CLOGGED, NEED CLEANER ADDED TO TANK, OIL CHANGE ALSO HELPS, GOTTA GET ENGINE RIGHT, AS U WOULD FOR INSPECTION. OR YOU'LL FAIL EMMISSIONS TEST, RIGHT ? GOOD LUCK MY FRIEND
Apr 29, 2014 | 1994 Chevrolet S-10
Cold start blazer
change your MAP sensor and clean the IAC valve
Mar 20, 2014 | 1994 Chevrolet S-10
Chevy troubleshooting
Spark, gas, and compression. And check timing. You've done the major work. Now you have to make sure you have done it right. By getting it running, you know. I'm pretty sure you can rent a fuel pressure tester and a cylinder compression tester at some national parts stores, Autozone or O'reillys, maybe others.
I don't understand your expression "...a little miss from bottom end" -an ignition miss, or a bottom skip or noise?
Start with checking ignition-a blue snapping spark-what you want to see at all cylinders. Then check that gas is getting into the cylinders. Fuel pressure and injector solenoid pulse. Then all you need after that is compression -good even compression in all cylinders-. Timing is right, spark timing is right, it should crank, er start.
Just one thing about compression, on a cold engine you're just looking for gross irregularities, you can't depend on the readings to be very accurate. A good compression test should be done on an engine at normal operating temperature. It gives a more accurate picture of your engine condition. As long as compression is over 100 psi per cylinder on a cold engine might be a general guideline, I suppose, but take that as only opinion, not fact..
Feb 19, 2014 | Chevrolet 1500 Cars & Trucks
Ny nissan 1994 cefiro model has what you call hiccups when driving, fuel pump has been changed including spark plugs, change oil done, cleaned the air intake as well, still has the hiccups?
Did you change spark plugs wires? fuel filter? I do not know if your car has MAF sensor, but if it does, clean it. Use CRC- Mass Air Flow Sensor cleaner. also check Spark Plugs Gap and coil (s)
Jun 18, 2010 | Nissan Maxima Cars & Trucks
Engine misses and bucks till it warmes up then runs fine
EGR valve or system is bad. that is Exhaust Gas Recycling valve. It's a pollution device that recycles exhaust gas back through the engine once it warms up. It's not suppose to work while engine is cold so there is a thermostat system for it that closes off the EGR valve while engine is cool. Once it warms up then it opens the valve. If you're recycling exhaust gas while engine is cool it will run rough. This can be hard for the average guy to troubleshoot as you need check the vacumn switches and thermostat valve.
Dec 02, 2009 | 2000 GMC New Sierra 1500
2006 Impala, dealer negligence?
Not sure what you mean from a faint knocking. Faint Knocking noise refers to piston slap till the engine warms up and a Tapping noise refers to a noisy lifter, if it's a bad lifter. The noise would get louder as the engine's RPM rises. Most GM owners have the problem of Piston slap first thing in the morning when the engine is cold, it's common and was made that way. The tolerance clearance between the pistons and cylinder walls are quite large since the majority of people do not warm up there car, so as you get on the gas and the pistons expand to the right size and will not wear out the cylinder walls giving the engine a longer life. The side effect to this is piston slap till the piston expands, that's why they say that you just have to warm up the engine for 2 min and then drive. Personal I'm not one to get in and drive, I'll always warm up the engine enough to see the temperature gauge go up. My wife has a Montana with over 150.000 miles and no piston slap after the first oil changed. I found that adding some Lucas engine oil treatment and a can of Engine Restor every second oil change has kept the engine running smooth and quiet, And about 500 miles before the next oil change. I add a bottle of Marvel Mystery Oil, the Mystery oil is thinner and will clean out the internal oil journals to the crank shaft and lifters which would cause the noisy lifter if the oil passage ways are sludge up. The Mystery oil will also clean the Oil Pump Pick Up Screen, ensuring there is not oil restriction in your engine. I have a GMC jimmy with over 350.000 miles and engine still running 100% with this method of service. Good luck and if your due for an oil change soon, add the Marvel Oil and a few days later change the oil and filter and add a can of Engine Restor and some Lucas oil treatment. This should quiet down your engine and add a few more years to it's life. Keep me posted, be glad to answer any more questions you may have.
Nov 13, 2009 | 2005 Chevrolet Impala
98 saturn it won't start when the engine is cold i have to put the gas peddle to the floor while I turn the key till it starts. when it does start I get large cloud of blue smoke. once the engine is warm...
Replace The Throttle Positioning Sensor...When you put Accelerator to the floor ... It rolls the Position Sensor Cam to tell computer etc to put Injectors Etc..into cold start mode...as soon as the motor fires..injectors take over and do their job..The Black smoke is the Extra Gas Put it cylinders to Purge it in a cold Start Mode...Throttle Positioning Sensor..and Yes You Can do It.!!! AutoZone-O'Reillys Etc..Easy Fix !! And Remember Castrol GTX-5-30/ 10-30 !!!
For God Sakes DO NOT Run 5-20 Or 20-50 Tooo Thin- Tooo Thick !! -Thanks-Matthew
Mar 19, 2009 | 1998 Saturn SL
Warm up
The high idle is caused by the choke and the high idle on the carb. It is working normal and you do won't to warm up this motor before going. When it is warm and you hit the gas it activates the choke pull off to bring the idle to normal. Your mechanic is used to fuel injection that will control the fuel/air mix according to temp. I still let my injected cars warm up so the oil can thin a little. If you jump on the highway with cold thick oil it can all wind up in the to of the motor.
May 16, 2008 | 1990 Chevrolet Camaro
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
